Question about Water Heaters
My heatline vizo 24 combi boiler wont fire uo , fan and pump run but no flame
2 Suggested Answers
mrhotandcold
  • 248 Answers
SOURCE: hi. my heatline vizo 24 boiler not working
overheat stat or fan best of luck
Posted on Oct 24, 2009
My ideal logic combi 30+ is saying ignition lockout and my radiatiors arent heating up as well as my water not turning hot. How can i fix this please?
Lockout is a safety feature. Usually a latching condition and needs to be investigated rather than blindly reset. (The Combi has a bit more intelligence.) With the ignition locked out, you can't hi-fire the boiler, so no hot water of either type. The 'L' should also show a code number - check your user manual (google) for more guidance.
I've had a lockout on a non-combi: it was caused by lack of circulation of central heating water through the boiler.... The system boiled and the trip tripped. The pump WAS running, but wear in a valve actuator resulted in the valve feedback saying valve open while it was physically shut.
Dec 31, 2016 | Water Water Heaters
My central heating turns off when i turn the hot water tap on. when i turn it off the central heating doesn't come back back on until i turn the power off and on.
Combi-boiler-turn hot water tap on/off and the heating stops for ...
singletrackworld.com/.../combi-boiler-turn-hot-water-tap-onoff-and-the-...
Combi-boiler-turn hot water tap on/off and the heating stops for 20secs ... hot watertakes priority over central heating so when you run the hot tap, heating is ... Yeah onmy worcester combi there is a diverter valve - it feeds either the heating or ...
My central heating works but I have no hot water - 24'7 ...
https://www.247homerescue.co.uk/my-central-heating-works-but-i-have-...
Diverter valves switch heat between the hot water and the central heating. When youturn your hot tap on, the diverter valve temporarily shuts off the water supply ...
Does your boiler keep switching itself off? Here's why ...
www.dhs-uk.com/does-your-boiler-keep-switching-itself-off-heres-why/
Jul 7, 2015 - ... Bathroom Suites, - Showers, - Wet Rooms, - Taps and Accessories, Information and ... Low water pressure can cause your boiler to turn itself off. ... boiler is not turning off, you aren't getting the amount of hot water you require. ... If there is air in your central heating system, then your boiler may shut down.
Feb 09, 2016 | Water Water Heaters
Heatline vizo 24
Your cold water fill tube inside the tank is broken off near the top of the tank. Replace the fill tube.
Aug 26, 2014 | Water Heaters
Need to decrease pressure on a heatline plus 24 vizo? any ideas? also leaking small amount of water under boiler!
There is a pressure adjustment on the gas valve...make sure you set it with a manometer. If the water is just condensate, its ok except if you don't have enough combustion air for the btu rating of the water heater. If it is a leak, replace the water heater
Dec 11, 2013 | Water Heaters
Combi boiler (vailant), pilot light not igniting; boiler firing etc o.k
hi there
does the fan start up?
sounds like a faulty gas valve. has there been an interuption in your gas supplie?
hope this steers you in the right direction
Dec 19, 2010 | Water Heaters
Hi. my heatline vizo 24 boiler not working
Oct 13, 2009 | Water Heaters
Protherm 100EC boiler not firing up
You likely have a flame sensor problem.
If you can wath the ignition proccess, see if you ever notice a flame. If yes, and it then shuts downm, you have a flame sensor failure, replace the sensor and clean the flame burners and orifices.
If no flame at all, then your ignitor is failing, or you are not gatting gas to the ignitor.
Aug 23, 2009 | Protech Systems FasNSeal FSWMKE4 4" Vent...
Hot water
there are two main faults with combi boilers not giving hot water. one is a faulty flow sensor, the other is the most common which is a blocked heat exchanger caused by debris and scale in the system. this needs to be flushed out or may require a new heat exchanger depending on the age and condition of the boiler some plumbers may suggest a new boiler.
Mar 02, 2009 | Water Heaters
Pilot light on boiler
The plumbers repair should be guaranteed, give him a call back.
It sounds to me that the pilot flame needs to be adjusted or the thermocouple is not aligned properly or there is a draft that is blowing out the pilot.
Good luck...
Feb 22, 2009 | Water Heaters
Combi boiler problem
most have an overrun built in for a few minutes. if much longer have you got a room thermostat anywhere to turn down
If it never turns off check the switch which controls ON/TIMED/OFF and turn to timed or off. if it still continues on timed then it's the timer
Jan 22, 2009 | Whirlpool Aquatic Millennium VII -...
Water Heaters Logo
134 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
