Question about NTI Backup Now EZ
External drive can not be installed on external drive
Tip
How to Install an Operating System on an External USB Hard Drive:
You may have an external hard drive you want to use for more than just document backup.
In this situation, you can install an operating system onto your external hard drive. By doing so, you will be able to run your external hard drive as a fully functional operating system.
If your primary hard drive ever crashes, you will have a backup option unavailable to those who simply use their external hard drives as file and document backup.
1) Plug your external Hard Drive into your Computer using the USB cable. Insert the installation disk for your Operating System into the CD/DVD Drive. Turn on or restart your Computer.
2) Boot from the installation disk. You may have to press a key once prompted to boot from the installation disk.
3) Accept the license terms and conditions. Read through these carefully if you wish to understand your legal rights as a user. If you disagree with these terms and conditions, you may want to purchase a different Operating System.
4) Choose your destination drive. Your external Hard Drive will likely be the E: or F: drive. By default, the C: will represent your main Hard Drive and the D: will usually represent your CD/DVD Drive.
5) Begin the installation. Your external Hard Drive will install the Operating System. You will now be able to run that Operating System off of your external hard drive.
Hope this helps.
on Sep 03, 2010 | Computers & Internet
Toshiba external drive won't instal on Windows 7 Home Premium
Will the external drive work on another computer? Has the external drive been dropped, bumped, jarred? If it works on another computer, shut down the Win7 laptop, unplug, remove battery, remove the USB external plug, plug into AC, reboot, when it is finished, plug in USB.
Jan 13, 2013 | Computers & Internet
My WD 1tb harddrive is no longer showing up on my computer. When I plug it in to the USB my computer states the drivers are installed correctly but it is not showing on "My Computer" or any other...
Connect the external drive to another computer and observe if it's going to work perfectly on that computer.
Which ever the case may be, here is what you need to do on your computer;
Insert the external drive into your computer
Go to device manager.
Go to the name of the external drive.
Right click on the external drive and click 'Uninstall"
Allow the external drive uninstall from your computer.
If possible uninstall every other device under the "Universal serial bus controller (usb).
Once this is done, disconnect/remove the external drive from your computer.
Restart your computer.
Wait a while for the computer to boot computer. Also whatever you have uninstalled from the device manager, might install automatically. Which ever the case maybe, make sure your computer has finished booting or installing any device before you attempt to insert the external drive into the usb.
Now insert the external drive and wait for the computer to install the external drive, then observe if it will open this time around.
By now it should open. But if it doesn't open, please let me know so that I may direct you further on what next to do.
I wish you good luck.
Regards.
Jun 12, 2011 | Western Digital My Book Essential Edition...
Installing 7200.10 with a Windows 7 Home Premium Service Pack 1, 32 Bit OS,. Have placed drive into an external case with USB connection and external power source. Laptop Computer does not recognize this...
it is impossible to install windows 7 to an external drive on any PC. to install it you will have to remove the drive you have in the laptop and then run the setup for windows
Apr 07, 2011 | Seagate Barracuda 7200.10 ST3250310AS SATA...
I bought a seagate 500 But I don't know how to put pictures on it
Yes. Its possible.
  • Step 1: Analyze the system requirements of the Windows operating system. Windows XP requires 1.5 gigabytes of free hard drive space. Windows Vista requires 20 gigabytes (for the Home Basic edition) or 50 gigabytes (for all other editions). The system requirements for older, outdated versions of the Windows operating system, such as Windows Me and Windows 98, can be found on the official Microsoft Windows Web site (link in the Resources section).
  • Step 2 :Connect the external hard drive to the computer with which you plan to use the hard drive. Use the hard drive's original cables included by the drive's manufacturer. It does not matter what connectivity standard you use. Windows will automatically detect the external hard drive.
  • Step 3: Click the Start menu in the lower left-hand corner of the PC screen and select My Computer.
  • Step 4: Right-click the icon for the external hard drive. Click Format from the pop-up menu. Format the external hard drive in the NTSF format.
  • Step 5: Insert the original Windows installation disk into your computer's CD-ROM drive. Close the Installation Wizard when it appears on the screen.
  • Step 6: Return to the My Computer window from Step 3. Write down the drive letters assigned to the CD-ROM drive and the drive of your external hard drive. For the sake of this article, we will use the example of D:\\ being the external hard drive and E:\\ being the CD-ROM drive. These are typically the letters assigned to CD-ROM and external drives in the Windows operating system.
  • Step 7: Click the Start menu button and select Run.
  • Step 8: Type "E:\I386\winnt32.exe /syspart:D: /tempdrive:D: /makelocalsource /noreboot" (without quotation marks) and click OK. This launches the Windows installer file on the Windows installation disk in drive E:\\ and commands it to install on the D:\\ drive (your external hard drive). The Windows Installer Wizard screen will appear. (Change the Drive Letter as in your Machine)
  • Step 9: Select the Full Install option in the Windows Installer Wizard. You will then be guided through the Windows installation disk. Follow the on-screen prompts to complete the installation. Depending on the speed of your computer's processor, this may take several hours. Be prepared to enter important information, such as your Windows registration key to register your copy of the Windows operating system. Do not close the installation window until the installation process is complete.
Please rate the answer if you feel that this solution solved your issue.
Thanks for contacting Fixya!
Step 10 Shut down the computer and disconnect the external hard drive. You can now use the external hard drive to boot up another computer using the installed copy of the Windows operating system.
Jun 29, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My computer doesn't recognize my external hard drive and I don't have the CD to install it again. What do I do?
Try the external hard-drive in another computer.
If that computer also refuses to recognize it, then there is something wrong with the external hard-drive.
Apr 03, 2010 | SimpleTech SimpleDrive Pininfarina 500GB...
How to install os in portable external drive in eee pc 4G
Select USB Portable External Drive to Boot Priority on the BIOS...
Inserting Operating System also needed.
Sep 29, 2009 | Computers & Internet
Run windows xp from external hard drive
you can install windows in external hard drive..but after installation u have to make change in BIOS as 1st boot device as USB.....
Dec 12, 2008 | Lenovo T400 Notebook
Computers & Internet Logo
41 people viewed this question
Top NTI Computers & Internet Experts
Tproverb
Level 1 Expert
Mari Criss
Mari Criss
Level 1 Expert
Vladimir Frolov
Are you a NTI Computer and Internet Expert? Answer questions, earn points and help others
