Question about HP Pavilion a1410n (ER890AA) PC Desktop
When booting get msg: system fan has failed...
Some mornings when I turn on pc, I get the above message. It then says: hit F2 to avoid damage to system. I do so and the pc then starts normally - if I reboot during the day, I do not get this message. Also, it doesn't happen every day. I am on an HP A1630N, xp service pack 2. Is a system failure in my future or is this some kind of wierd fluke? Thanks in advance. Patricia
  • 2 more comments
  • pvnorton Jan 05, 2009
    Thank you for quick response. Yes, I can hear the fan "whirring" so to speak. I will try your recommendation tomorrow. Will let you know. thanks again.
  • pvnorton Jan 09, 2009
    Since I cleaned the dust out (jan 5), I have not received that msg upon booting SO, I guess your suggestion really worked!! Thanks again.
  • johnn71 Apr 05, 2009
    Same problem same computer. Blew it out replaced CMOS battery unplugged both fans and put back. Worked fine for about two weeks and the same message returned . Thinking possibly the power supply but at this point will take anyones suggestions short of throwing the computer in the trash can!
  • Twerp1 May 11, 2010
    Can you hear if the fan is working or not?
    You should turn the pc off at the mains and open up the pc unit ..... clean any dirt/dust/debris from the fan very carefully and not touching anything on the motherboard etc ....... then try again to boot the pv.
    Scholar:
  • 60 Answers
That is correct. Also, while you are inside the Pc check the connection to make sure it is tight. If the inside case is dusty, blow it out with a can of compressed air from wal mart. Most modern motherboards have sensors built in and software that monitors temperatures of your hard drive(s), CPU's, Inside case, and even video cards. It's nice to know that the software notified you as it was suppose too. Oh by the way, nice system! Hope this helped.
Posted on Jan 05, 2009
New case fan running but still getting error message system fan failed.
Did you try;
Power off, power unplugged to computer.
Press the Power On button, and hold it in. Hold for a count of 10 seconds.
Let go.
Do this procedure two more times.
Plug the computer back into power. WAIT 1 minute, turn the computer on.
This method clears CMOS Error Codes, and sets BIOS Setup back to the factory default settings.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00864946&tmp_task=prodinfoCategory&cc=us&dlc=en&lang=en&lc=en&product=3340228#N436
CPU fan spinning at required minimum RPM's?
Not talking about the SYS_FAN (Case fan)
Regards,
joecoolvette
Jan 18, 2013 | HP Pavilion a1720n PC Desktop
When I started my DELL Inspiron 1525 running Win 7 Ultimate, I got a white-on-black screen which questioned the voltage from power adapter. Diagnostic program run.. Stopped with the following msg: Error...
2000-0142 and 2000-0146 are hard drive SMART errors, indicating the HDD will fail.
To boot message about the AC adapter was a BIOS level message that normally appears when a Auto/air ac adapter or other 65 watt ac adapter is used to power the system.
Jul 16, 2011 | Dell Inspiron 1525 Laptop
When the computer boots up. It makes almost a grinding noise and I get an error msg, saying the fan is failing. But it does boot up by hitting f2 which is one of the options after the error msg. The other...
The only resolution other than replacing the fan by sending the PC to repair, is to clean the fan.
Power Off the desktop
Open the side pannel using the thumb screw or the philips screwdriver
You will see two fans in the unit, one on the processor heat sink (CPU Fan) and other on the back (System Fan)
Try to clean the fan by blowing air using a hair dryer or a vacum cleaner (in light mode)
Put back the side pannel
Power on the PC to check for error message
If it's still there, you need to replace the fan if it wont allow you to pass through using F2
Regards,
Shrey
Jun 01, 2011 | HP Compaq Presario SR1830NX PC Desktop
I have an HP M7100Y Media computer runnign XP and replaced the cooling fan but when I boot I get an error message System Fan Failure press F2 to continue. How do I avoid the error message?
Does the fan spin up? There is a third wire on the fan that is interogated by the uProcessor to determin how fast it is spinning. If it is spinning but not registering, there is an interface problem, maybe poor connecion on the socket it plugs into?
Hope this helps.
Dec 31, 2010 | HP Pavilion m7100y (PX189AV) PC Desktop
Can't turn on laptop at all. Lights come on momentarily then off
how far does it get into the start up sequence? what operating system?
It it starts to load up then when you boot hit f5 repeatedly to get the boot menu the select start with last know good configuration. If that fails start in safe mode with networking, to gain access to the net and your files.
install an antivirus like microsoft security essentials when your system is running next
Jan 11, 2010 | HP MINI 2133 NOTEBOOK PC - 1.6GHZ PC...
Dell 8400 boot up problems
There could be problem with the motherboard. You can try resetting the same.
1.Press F2 to enter the system setup.
2. Use the down arrow key and go to the option that says maintaince
3. Press enter and key down to the option CMOS defaults
4. Hit enter and reset defaults
5. Press escape and save changes and exit
6. check if the system boots up.
Before you perform the steps given above, unplug all external peripherals from the system like printers and webcams speakers etc. Your information is safe and there would not harm done to the information stored on the hardrive .
Thanks
proton
Nov 01, 2008 | Dell Dimension 8400 power supply ** FREE...
Security Problem Message on PC
You have a spyware infection, plan and simple. Those security warnings (asking you to scan) are not part of the Windows security center.
Download Spybot [ http://www.spybot.com ] for free, scan your system and pray that the spyware has not done irreparable damage to your system files.
Sep 28, 2008 | HP Pavilion dv6000z Notebook
Emachine t3882 will not boot
there is a big possibility that your System fan is damaged or worst is that it's your CPU fan that is not working properly. If you can still enter the bios by pressing F2, try to check your settings and disable fan control for the system fan. If the problem persist then you need to replace the CPU Fan.
Hope this helps.
Please vote if it does. Thanks!
Apr 11, 2008 | Intel D865GVHZ Motherboard
HP Pavilion a1410n (ER890AA) PC Desktop Logo
487 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
