Power is on but no display in the screen - Computers & Internet
  • 7,627 Answers
You didn't give much info to work with, but, Could be a couple of things. 1) The backlighting (CCFL) may be out. If you can see the desktop as a faint image in a very bright light I would suspect the CCFL, there is a tiny switch that shuts down the backlighting when you close a laptop, sometimes it can get stuck. Also if the laptop is dropped, jarred, etc. 2) the wiring to the CCFL could be pinched, broken, and the obvious the Light itself may have burned out. 3) There is a ribbon cable that connects the monitor to the motherboard that may have a bad connection.
Posted on Nov 10, 2012
Black screen but i didnt hear any beeps
Dear frnd,
its looks like Operating system problem. some times its happens that you power on and its display nothing except a black screen. you need to re-install the os but before it you have to confirm that your display screen is working. for that check the display in dark place so that when you power on its screen going to slightly white if its happens than its screen is ok if its doesn't than you have to change display screen cable inside of the laptop.
Jan 15, 2014 | Dell Inspiron Mini 1012 Netbook...
Hard reset motorola atrix dual core smartphone
  1. Power off the phone.
    NOTE: If unable to power off, remove and reinsert the battery.
  2. Press and hold the Volume Up + Volume Down and the Power button.
  3. The screen displays Boot Mode Selection Menu; press volume down key to cycle through choices until Android Recovery is viewed. Press the Volume Up key to boot in this mode.
  4. Wait for the triangle ! / Android screen to display, then proceed to step 5.
  5. Press both Volume up and Volume down key simultaneously. A recovery menu displays.
  6. Tap on Volume Down key until Wipe data/factory reset is highlighted, and tap the Power button.
  7. Another confirmation screen displays. Tap the Volume Down key until Yes displays, then tap the Power button.
  8. After user data is cleared, the reboot system now option is highlighted by default. Tap the Power button.
  9. The phone reboots to the initial setup screen.
Wireless
Nov 23, 2013 | Motorola Mobility Nice Atrix 2 4g Hd At&t...
Rheem pool heater there's no power to the display
ensure proper supply voltage to the heater....either 12 or 240 vac. display screen should get 24 vac.....if screen is supplied 24 vac then replace the display screen board.....if not getting 24 vac problem is occuring before display screen
Sep 13, 2013 | Pool & Spa
Aspire 5542g
When the following conditions, namely the need to replace the LCD inverter:
No image on the screen, but the power light stays on
Dark display but still readable
Between the screen flashes on and off 1/2 to several seconds
Power light stays on, but no display and sound
No image on the screen, but LCD TV still has sound
Picture cycle on and off, as well as high-power LED lights
Jul 26, 2013 | Computers & Internet
Desact monitor
When the following symptoms, that is, to replace a laptop LCD screen:
Jun 07, 2013 | Computers & Internet
My hp mini 210-1000 boots up well both on battery and adapter but it displays faintly on battery while it display well on power adapter
the problem is that its set in the power saving options. i mean on battery its set to power saver . while on power adapter it changes to hp recomended or high perfomance. So if you want to change it go to the right bottom of your screen and click the battery symbol it should give you the option to 1> change screen brightness 2>more power options. Go to more power options and select "change plan settings" beside the power saver.(not the one beside the other options) and change ur brightness. but its always better to keep it at ur minimum(with what ur comfortable) as its helpful to save battery
Jan 10, 2013 | HP Mini 1000 Netbook
It shows power saving mode
Power saver modes on the monitor has several functions. First the power saver preserves the devices from consuming current while viewer is mometarily away. Screens that display power saver modes returns to regular viewer mode soon as the remote controls or buttons are manipulated slightly as indication of request to regualar views. The power saveer mode of the screen can be disabled. Obser ve the feature functions of the device iether on the remote controlof device buttons. Power savers perform simialr to screen savers or device feature manipulations. Access the devices settings or menu buttons to display the entire list to buttons for disactivation of power savers modes. Usually the power saver mode may be onsctruting viewer experiences for situation that momentary displays ate idleness requiring to retore to viwer display screen. Refer to the devices userguide to attain details.
Feb 08, 2011 | LG Computers & Internet
Remote control not working with tv
The remote control is an acess to the TV device for example only from a distance. A remote controll for functionality would require to insert batteries a power source making possible communiction with devices requiring reception transmittion of signals. The remote is handheld pointed to the direction of TV requiring signal before button pressed woudl achieve response. a common button to start the remote control experience is pressing on the power button, that displays a signal on the TV. The TV should momentarily produce a sound and lighting effect,, and displaying on the dark screen a light blue screen. The initial signal response from remote control to TV indicates devices are functioning as required. Additional buttons on the remote controll could perform functions of several available.
The remote control has master button, menu on which every additional function is deriveable. Once the menu button is pressed with remote pointed in the direction of TV, should dicplay a list of options on the blue screen already established by power button. Every additional remote control device functionality is achievable by only after the first two buttons have been powered and pressed to display option results on a screen of TV. The remote controll buttons remaining perform complementary functionalities. For example, the arrow keys on remote control make movement of the options displayed on the screen, where a comfrimation button or identified as select allows to confirm remote functions displayed on the screen. A remote control could have several functionalities only accessible once made to display in screen. The three most common buttons on a remote control are First power button that powers on the TV, menu button that displays a list of functionalities on the powered on bl;ank blue screen, and using the arrow buttons on the remote would moves an indicator arround the screen area options. The selection button makes confrimation of the option.
Dec 02, 2010 | Philips Televison & Video
My screen doent dispaly at start-up.
Try connecting and external display screen to your laptop's external display port. If the external display is working, then try to access your laptop display connector (usually can access by removing the top power button access cover and/or the keyboard assembly) to the motherboard and disconnect and reconnect to motherboard. Power laptop back on, if still doesn't work, then could be the display invertor pcb or the actual display. If you have to order a display, make sure the display invertor board comes with it. Hope this helps, Ed.
Aug 25, 2009 | Dell Latitude D820 Notebook
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
