Question about Troy Bilt Tb320bv Spring Assist Blower/Vac
Correct torque on flywheel nut for troy-bilt tb 320 blower
Rebuilding a troy-bilt tb 320 blower and need to know the correct torque for the retaining nut that secures the flywheel to the crankshaft. Also the correct method to hold the crankshaft while torquing the flywheel retaining nut. Appears one of the two holes in the crankshaft counterweights can be used to install a 0.170" drill rod that would lock the crankshaft against the connecting rod while torquing the flywheel nut? Some of the other methods discussed at other websites sounds crude (jam a rope into the cylinder head?, etc)
  • 68 Answers
SOURCE: blower wont run at full throttle
Start with the spark plug it is the easiest.
But sounds like the carbourator is dirty, Probably fouled with old gas varnish. When it is idling give it a little throttle, flip the choke on and then full throttle. If it goes full throttle and doesn't conk out, it is a fuel issue.
Good Luck
Posted on Dec 11, 2008
  • 41 Answers
SOURCE: TROY BILT TRIMMER MODEL TB70SS. HOW DO I REPLACE
Is the pull rope in the front or rear of engine.Thinking that the string is in the front,you must throttle housing and shaft from engine. remove starter housing. There sould be a screw holding the string and spring in place.
Posted on May 07, 2009
#1 Taper
  • 1040 Answers
SOURCE: Troy Bilt TB 465SS Pony 4 cycle weed trimmer won't start
Sounds like you need to take the carb. apart and clean it. I like to use a Den Tek Brush, (used for cleaning teeth), to clean the small ports in carb. they work great for this job. Make sure to either clean or replace the small screen in thcarb. as well.
Jim
Posted on May 26, 2009
#1 Taper
  • 1040 Answers
SOURCE: Troy Bilt in Hell String Trimmer TB465SS Running Problem
You need to clean the carb. or you may need to buy a carb. kit. But do a cleaning on it first. If you need tips on how to best do this, just let me know. Also check the fuel lines for cracks. As they age, they become brittle.
Jim
Posted on Jun 04, 2009
#1 Taper
  • 1040 Answers
SOURCE: can not remove troy bilt weedeater head
Once all the bolts are removed, tap all the way around, (with a rubber mallet), where the head meets the bottom portion of the motor. It should come right off with a little coaxing.
Jim
Posted on Jun 10, 2009
Troy bilt tb 240 mower revved out of control about 30 seconds, stopped running then immediately seized up
sounds like the spring on the governor or carb came off and went wide open. that will lock an engine up quick. pull the spark plug and see if you can turn the engine over. if you have to take off the shroud that covers the flywheel, pull rope assembly. try to turn the engine over by hand. squirt some oil in the spark plug hole. you may be able to free it . the starter cord should be free off the engine. maybe it just got jammed.
Jun 01, 2016 | Troy Garden
I just replaced the auger belt and the auger cable has no tension. What do I do to fix it?
Here's some silly questions: Did you put the belt on the correct side of the Tensioner?
Is it the correct sized belt?
Is there a spring on the cable for the auger that can be lifted up the cable to expose the adjustment nut ?
Feb 08, 2016 | Troy-Bilt Troy Bilt Storm 3090XP Snow...
Which gas line goes to the top of TB 320 BV troy built leaf blower. 41DS320G966 carburetor 753-04338?
I suspect it is the one from the gas filter in the tank. If that doesn't work switch the lines around. Hope this helps. If not let me know if it has a primer bulb or not and I will try to help. Hope this helps.
Nov 20, 2015 | Troy Garden
Flywheel on tb horse model
you should use a puller put if you must pry against the back of the flywheel and hit the crankshaft with a lead of brass hammer thats only a last resort
Aug 12, 2012 | Garden
PULL ROPE IS STUCK ON A TROY BILT BLOWER
Partial disassembly of the machine will be required to access/diagnose the exact problem. The starter/recoil unit goes on top of the flywheel and the flywheel is on the engine shaft. The obstacles will be removing the main cover (and getting it back on correctly). If you have never done this, them maybe take pictures as you disassemble it to help you reassemble. Once you reach the starter/recoil unit, you will see how it works and be able to resolve the problem. Some of these units have inferior design and engineering flaws where they mate nylon parts with metal and of course, the nylon doesn't hold up. Post back for more help if needed once you get to the starter unit.
Feb 10, 2011 | Troy-Bilt 31cc 2-Cycle Gas Powered...
Replacing the pull cord on my Troy Bilt blower/vac (TB320BV), & I can't get the nut off the crankshaft extension, the last thing keeping me from the starter housing. I've tried clasping the flywheel...
Same problem here.After snapping a couple fins off the flywheel trying to lock it with a screwdriver, I had an idea that worked quite well.I used an oil filter wrench (designed like pliers) Item #36778 at harbor freight.The thin design held the flywheel well (very tight fit,had to force past the plastic housing) while I used a socket and power handle.Worked for me and used it when torquing the crankshaft extension nut tight again.
Oct 31, 2010 | Troy-Bilt 31cc 2-Cycle Gas Powered...
Troy-bilt trimmer TB 490 BC
Turn the bump knob clockwise to loosen on my tb490bc.
May 29, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
My troy-built blower will not start
CHECK THE SCREEN ON OUTPUT OF THE MUFFLER. ITS CALLED A SPARK ARRESTOR, THESE GET OIL FOULED AND MAKE EM A BEAR TO RUN . CLEAN IT UP AND SHE WILL RUN LIKE A CHAMP, THE CARB MIGHT NEED REBUILDING ,FUEL FILTER AND A SPARK PLUG IS THE FIRST THING TO REPLACE .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
May 26, 2010 | Troy-Bilt 31cc 2-Cycle Gas Powered...
Troy-Bilt Mower is running real slow like its clogged dont know not a mower expert, need help please before I take it to a mower expert.
If you can, check the flywheel key. If it is bent but not quite broken, it can cause slow operation. To do that, take the starter off the top of mower. Take off the big nut on the flywheel. Find a nut of the same size and place on the thread you took the nut off, but only a few turns. Hold the flywheel with one hand, lifting a little, and tap the nut with a hammer with the other hand. The flywheel should come off. Look at the key, it holds the flywheel to the shaft. If it is bent or broken, that is the problem. Replace it and go about your day! Good luck...Lee
Sep 25, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Troy bilt tb320bv wont start. only two months old.he cord won't pull out completely like it used to and it won't let me start the thing any longer. It is like something is jammed in the system.
It seems to be a usual problem with troy bilt trimmers and leaf blowers. There should be a half moon piece of keystock that holds the flywheel on,sometimes its known to sheer off. Could also be one of the keepers that hold back the plastic disk for the cord comes loose,it gets in a bind. Either way,you have to open up the case and see whats going on.
Aug 05, 2009 | Troy Bilt Tb320bv Spring Assist Blower/Vac
Troy Bilt Tb320bv Spring Assist Blower/Vac Logo
104 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
