Cq26-214nr laptop screen display only works when open half way
When opened all the way the screen show random vertical colored lines ,, but if moved back to the halfway open it will work ... think it is a bad cable ,, part number ???
5 Suggested Answers
  • 41 Answers
SOURCE: Screen only showing vertical lines after being dropped
The damage could be either in the LCD screen or the connection cable. Open the screen assembly and check the connection cable first.
In case it doesn't work you can find replacement LCD screens here.
www.piezas.biz
Posted on Jul 06, 2008
SOURCE: Dell Inspiron 1501 screen half black
Had the same problem. Fixed it though. Here's how:
You'll notice that the screen comes back to life if you press down on the very top of the green line. This is because a controller circuit board behind the LCD screen (at the top) is pressure fit flat-surface-to-flat surface to the contacts on the back of the LCD. Eventually, the sticky substance that holds this circuit board in place wears thin, collects dust, etc.. and the connection between the circuit board and the lcd contact is lost. The line appears where this break in contact has occured.
So, the solution is to increase the pressure at that point to reestablish the connection. I wasn't able to remove the circuit board to clean beneath it as it seemed too likely to cause damage. Nor would I have had the right adhesive to connect it back, so I simply removed the LCD and put a bunch of tape at that point so that it would "push" with a little more pressure when screwed back into place. Worked great.
To remove the LCD, pull off the 6 feet around the screen. Remove the screws behind them. Carefully pry off bezel with a small flathead screwdriver working your way around it. Once removed there are simply 4 screws on the left and 4 more on the right of the LCD to remove. Pull out screen carefully and start stacking bits of tape on the spot where pressure seems to work best. Put it back in and see if you've made any difference. I did this with the computer on so I could verify my results. Just be careful not to short out any naked contacts.
If this doesn't work for you, at least you'll know you just need to replace the LCD, not the video card. Easily found on ebay.
Posted on Mar 12, 2009
coupondeal
  • 76 Answers
SOURCE: Dell 710M display has vertical colored lines instead of info
I suspect that the flat wire between you keyboard and screen is coming loose. It is within one of the himges and is about 1" wide and very delicate. You can not fix it and should take it to someone who works on laptops. Sorry that is the best I can suggest
Posted on Jul 15, 2009
Firetree
  • 179 Answers
SOURCE: There are multi colored vertical
Unfortunately, you're not going to be able to get a new cable as Toshiba will not sell OEM replacement parts to anyone but an authorized repair center.
This may just as likely be a problem with the sockets/plugs as with the cable itself, as they are rather fragile. It may be worth spending a few bucks for a used cable just to see if it will solve your problem. Also be sure that the thin plastic shim found on the top of most of these cable ends is still there, as they can come off rather easily, and the lack of it will cause a poor connection.
Your other alternatives are (1) Toshiba repair center, or (2) using the external monitor.
Hope that's helpful.
Posted on Dec 31, 2010
Display shows lines and color not displayed properly
A line vertically down the screen (usually bright green) is a failed column strobe. This can be caused by the connections at the top of the screen failing or the strobe chip starting to die.
Random colours can be caused by a cracked screen or a failed video card.
Best to take it to a repair shop for it to be assessed.
Jun 23, 2014 | Toshiba Satellite C850-BT2N11 Laptop
Vertical lines on laptop screen
problem with either display or the display cable...call cust service to diagnose and fix the issue
Mar 15, 2014 | Dell Studio 1555 laptop
Vertical line down screen
This problem can be caused by a lose connection between LCD and motherboard, however you can check it by opening the LCD or hinge bezel to ensure if there isn't any lose connection.
Oct 28, 2013 | Dell Vostro Computers & Internet
Two vertical black lines on the screen of my ps50b430
Unless someone played with the TV and disconnected the plasma display from the address buffer boards that go under the screen the prospects aren't good.
All vertical lines in all plasma TVs I have seen are operated by chips embedded in the fabric of the display as well.
When they fail they'd either short or burn open.
In the first case they'd prevent the TV from coming up, in the second they'd typically manifest as either black or a random color vertical line like you have.
This is not repairable...sorry.
The odds of this being something else is fairly minimal in my opinion.
Please don't kill the messenger...
bobby @ coppelltvrepair . com
Aug 25, 2012 | Televison & Video
Price of Dell Inspiron 9200 lcd panel?
Yes! but it is a good idea to hook a spare monitor to the video output first to make sure there is no problem, if okay! replace the LCD screen. Go to www.ebay.com Type: make and model of the laptop and refine search to screen, a list of sellers will pop up showing the prices.
Apr 10, 2012 | Dell Computers & Internet
My dell laptop is showing a blue colored vertical line in screen,i want to replace my laptop.....how?
You can go to support.dell.com to order just the screen. If you are technically inclined, and can follow a service manual (that you can also download from support.dell.com) you can actually replace the screen yourself.
Its not too hard. Without getting into too much detail:
Turn the laptop off.
Remove the battery.
Remove the Power Button display plate.
Remove the keyboard.
Unscrew the hinges holding the screen to the base of the laptop.
Pry open the border of the screen.
Remove the screws holding the screen and replace with the new one.
Apr 06, 2010 | Dell Studio 15 Laptop
Jul 14, 2009 | Computers & Internet
www.piezas.biz
Jul 02, 2008 | Toshiba Satellite M55-S135 Notebook
Gateway laptop vertical dotted lines across the screen
Sounds like a problem with the LCD assembly or cable. You may want to reseat the LCD cable at the LCD end. It could be a loose internal connector in the LCD assembly.
Ron-
Dec 13, 2007 | Computers & Internet
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
