I have a arirang karaoke 3600 HDD, where can reinstall the software for it's harddriver ?
I purchased your karaoke software for my phone and love it...I got a new phone and cannot find the path for my songs..the phone is a zte grand x max+...I have a sdcard with a karaoke directory...I have...
"your karaoke software"?
We are not who you think we are. We are Fixya, a self help website, people just like you helping others just because we can.
You problem is simple. Your songs on on your old phone, not on the new one! You would have had to back up and restore to the new phone after installing the software to the new one. The app may have an Import command.
May 14, 2017 | ZTE Cell Phones
How to install a new harddrive in an acer 23" all-in-one?
If you replace the HDD you will have to do a reinstall of Windows or clone the drive. If you have the Factory Revovery DVD's then you can reinstall to Original Factory Condition. All you data will be lost. If you clone the drive, it will be as it was when you removed it. That said, is there a problem with the HDD? Why are you replacing It? The HDD hardware replace is the easy part.
Dec 11, 2012 | Acer Aspire All-in-One Desktop PC - Silver...
HARDDRIVE ERROR ON SONY RDRHXD860 DVD RECORDER
http://www.avforums.com/forums/attachments/blu-ray-dvd-recorders-media/68631d1198812029-succesful-upgrade-hdd-rdr-hxd970-how-upgrade-hdd-sony-x70-series-dvd-recorders.pdf You shouldn't use a computer to format the drive as the dvd recorder will do that for you.
Oct 25, 2012 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
My Tiny 755C10 laptop has 44 pins slot and standard ide hdd has 47 pins. what can I do to fix it?
Standard IDE (PATA) HDD connection is 44 pins for a laptop.
(40-pins for a desktop IDE harddrive. Only 39 are used, though. One pin is removed)
http://www.av8n.com/computer/htm/disk-pinout.htm
What manufacturer, and model of HDD, do you have that has 47 pins?
(48 with one pin removed?)
http://pinouts.ru/HD/Ata44Internal_pinout.shtml
SO, the question is,....what is that 47-pin Harddrive?
Post back in a Comment.
Regards,
joecoolvette
Jan 28, 2012 | Computers & Internet
I want to burn a karaeoke disc
The problem isn't the burner. You need karaoke software to burn and view cdg files. Below is a link to free karaoke software. Install the software (or a software package of your choosing) and re-burn your files.
Karaoke Builder
Dec 27, 2011 | LG GSA-H22N DVD±RW Dual Layer Burner
When i start up my note book it just comes up no bootable device insert boot disk and then press any key.? there is no disk slot to put a disk in.?
Hi there!
This error messages means that you don't have any functioning bootable device. Since you don't have a disc drive, then it is possible that your harddrive crashed or needs to be replace. What you can do is to check in the BIOS if the harddrive is detected or not. If it is, then you just have to reinstall the operating system of your computer. If not, you may have to replace it.
Best regards!
Jun 29, 2011 | Computers & Internet
Hi I've Vaio VPCSC1AFM with Win 7, boot is impossible -"Operating System Not Found", HDD is also not visible in BIOS. I can hear that HDD is working.
* Look in your BIOS, I've it can detect the HDD.
( Press the F1 or F10 key after restarting the computer) * Make sure all the cables are connectedproperly.
* It might be a jumper setting.
I've you have 2 HDD's on 1 cable, you need to have 1 Master & 1 Slave,or else your HDD(s) wont show up & other problems.
Jumper settings below (Yourjumper settings might be different !)
I've this all didnt work, either your HDD or your MOBO is broken.
Jun 03, 2011 | Computers & Internet
I have a gateway one with a western digital 4000aajs harddrive that will not load windows
Your question is vague. If the HDD is bad, you will see a notice that computer cannot read HDD. If you have a bad installation, then you can try to recover it with your Windows software disc.
If you don't need to save anything on the computer, format the HDD and reinstall Windows
Nov 03, 2009 | Gateway ONE GZ7108 All-in-One Desktop PC
I USE CANON CLC 5000 CMYK MACHINE, BUT THIS FIERY HDD IS ONT CONNECT, HDD IS CRUPED I WANT SETUP SOFTWARE AND DRIVER MY E MAIL:- PARFECTDL@YAHOO.COM PLS. SOLVE MY PROBLEM SATISH GHETIA
sounds like your harddrive is corrupted and i would recommend you reinstall a new install of windows or if you have the recovery original disk then try running it to see if it solves your problem.good luck.
Jul 31, 2009 | Computers & Internet
Can't reboot dell 4100 dimension desktop
First put the hdd installation cd into the cd drive and try to boot. This should install the hdd driver as well as start formatting the new hdd. After the drive is formatted take out the hdd cd & insert the Windows installation cd into the drive. Boot. Windows should start installing on your new drive. After Windows is installed check the Dell support site for updated drivers for your system. Install drivers as needed. Any other software you had on your old drive will need to be reinstalled to the new drive. Hope this helps & please rate my answer. Thanks.
Dec 27, 2008 | Dell Dimension 4100 (-JM0TB01) PC Desktop
Computers & Internet Logo
104 people viewed this question
David Payne
David Payne
