Question about Canon imageRUNNER C3220 Color Copier
My canon Image Runner C4080 do code E748-4875 what can be the interpretation of this error code
  • 47 Answers
SOURCE: Canon 210S Image Runner
It is a fixing film position error. The fixing film is probably damaged or is just tracking off center. If the fixing film is ratched then replace the entire upper fixing unit. You can get just the film but its a job even experienced techs cringe at. Check the lower roller and bushings while you are at it. If anything is worn there it can cause the film to track off center.
Posted on May 07, 2008
  • 67 Answers
SOURCE: Canon Image runner C 3200 printer gives error code E000677-0080
your quickbooks file is in the wrong format example tiff or pdf let your it know they can change it to the correct file format
Posted on Aug 19, 2008
SOURCE: about error code
cannon ir 5000 copier give me error e 0061 & e0069 what the problem and the solution
Posted on Oct 15, 2008
  • 168 Answers
SOURCE: error code e000800-001
not the fan open the front door pull out number one unit check the assymbly behind the frame it will move when you move the handle if its bent tou will get that code when you close the door
Posted on Dec 08, 2008
57 varieties
  • 1653 Answers
SOURCE: canon image runner error code E000000-0000
Note that clearing the error may not necessarily fix the fault.
Press the * with a circle around it then press 2 and 8 at the same time.
Then press * again.
Press copier touch button / function / clear / error /ok button then switch off.
Switch the machine back on.
The error code indicates that the machine doesn't sense the temperature of the fuser getting hotter. Usually this calls for the fixing film unit to be replaced because the thermistor has gone bad.
Posted on Oct 13, 2009
Canon image Runner 2202 error code E000-0000
Aynalem, Canon image Runner 2202 error code E000-0000
Aug 10, 2016 | Canon Office Equipment & Supplies
Error code e000007 canon 2420
MY CANON IR 2420 WITH ERROR 000007-0000 HOW CAN ISOLVE THIS PROBLEM
Dec 06, 2012 | Canon Office Equipment & Supplies
Image runner 2200 its showing code error E000007-0000 what can i do sir/madam
image runner 2200its showing code error E000007-0000what can i do sir/madam
Feb 24, 2011 | Canon (6981A002AA) for imagerunner 2200,...
We have a CANON IR C4080 and are coming across a little issue which could become quite annoying : Some Technical pdf come out with some blacken schematics, like the image is treated as a block (filled...
Hello thierry,
Wow, alot of variables here.If you are using PS drivers then you of coures MUST have a Fiery,or a Canon option that emulates PS.This can be as simple as it's onboard limited ability to emulate PS(which although is onboard is locked out unless you have prchased a special "license" to use it) or one of Canon's external print contollers that again "emulate" PS.This is a given,anything less than the 2 external controllers Canon offers (ImagePass H1/ColorPassGX100) will not provide full interpretaion of PS.And even the the high end controllers may misinterpret certain graphics data in the PS format as they are emulators of the Fiery controller.If you have niether of the 4 options (onboard licensed controller,H1,GX or Fiery) then you have inherent limitations.A simple PDF document would be better presented using the UFR II print driver available at Canon's website.Just as an Adobe PostScript document may not output properly using an inferior driver and/or controller,a PDF file may be ouput poorly using a PS driver.I hope I have been of some help to you as that's what I try to do,help. Best wishes and GFL ! :-)
Jan 14, 2011 | Canon imageRUNNER iR C4080 Color Copier
Image runner 4570
it might just be a power spike in which case your machine just shot an error while it protected itself...
try the following...
press additional functions
press code error
press copier
press function
press clear
press error
press ok
press reset
if that doesn't work then call a tech... it might be very serious...
Dec 21, 2009 | Canon ImageRUNNER 3570 Copier/Printer
Canon Image runner photocopier
It is very easy... What code is it? It may not be resetable with out replacing a part... Need more info...
Jul 07, 2008 | Canon imageRUNNER 210S Copier
Image Runner 210S
it is a fuser problem:-you have to check-.
1-low temprature due to blown lamp(change it).
2-thermal switch(reset it)by pressing on it.
3-ac driver problem(heater control board.
Apr 20, 2008 | Canon Image Runner 3320I Copier
Canon imageRUNNER C3220 Color Copier Logo
145 people viewed this question
old marine
old marine
