Question about RTO Weight Watchers Glass Precision Electronic Scale WW34
To clear all data stored on the scales
The scales were given and I want to clear all data to store my own details.
My scale is a taylor 5751 bc how do i reset all memories?
Easy way is to remove the battery. Or individually;
Press and hold the "Power" button in the center of the scale. Your scale will then list the information you have saved for each memory number.
Hold both the "Up" and "Down" buttons for about three seconds. This will clear the information for that memory number.
Repeat the process for each memory number that has information stored on it.
Remove the battery from the scale. Leave it out for five minutes. Reinsert the battery to finish resetting your scale.
https://healthfully.com/reset-taylor-scale-5033705.html
Oct 05, 2017 | Taylor Health & Beauty
When trying to download the assistant app for Android I receive this error ?
Go to settings >application > Play Store >Clear Data & Clear Cache.
Go to accounts >Google >Remove account.
Reboot device.
Details here :
http://wikitechsolutions.com/1222/error-while-retrieving-information-from-server-rpc-s-3-aec-and-rpc-7-aec-0
Apr 16, 2016 | Android Cell Phones
My phone keeps saying google play services error
Not sure how old your phone is but it will do that when your phone is outdated. May need to update your phone
Mar 09, 2016 | Google Cell Phones
Problems with Azpen A727 tablet.
Soft Reset Press the reset button on the back of the tablet with a fine point object for about two seconds. This will not erase data store on the tablet. This may help if the screen is frozen or not responsive to touch.
Nov 24, 2014 | Tablets & eReaders
Google play won't load it always says that there: z no connection
Clear the Play Store cache. The Google Play Store app on your Android device stores some cache data on your device which could be one of the reasons why you are not able to connect to Google servers using the app and keep getting the "No connection - Retry" error message. How to fix it? Read the quick and easy steps below:
  • Go to Settings > Apps.
  • Scroll to All apps and then scroll down to "Google Play Store" app.
  • Open the app details and tap on the "Force stop" button.
  • Then, tap on the "Clear cache" button.
That's it. Now start the Google Play Store app on your phone / tablet and it should load and work absolutely fine!
Oct 13, 2013 | Computers & Internet
I keep getting a pop-up screen on my 47LW5700
The TV should be set to factory defaults to clear all the system data stored. To do this, you've to enter its service mode option. If you wish to get more details about how to enter and adjust items in service mode options to LG brand TVs, check this link. Service mode entry and exit methods to several brand televisions are given in detail. http://electronicshelponline.blogspot.com/
Jun 09, 2013 | LG Televison & Video
Play store app will not work
Try clearing your Play Store cache and data.
Go to Settings -> "Apps" or "Applications Manager" -> "All" or "All Applications" and look for Google Play Store. Force Stop and then Clear Data.
After it's done clearing data, try to open the play store again.
If that doesn't work, try removing and re-adding your google account in Settings -> Accounts.
May 26, 2013 | Android Apps
Avery H500/L200 Avery Weighing Scales For ForkliftTruck When scales powered on, screen displaying ''balance limit''. Scales will not function.
The zero capture is out of the 2percent tolerance so the cell is either faulty or requires zeroing. Open the unit and press the micros itch on the left of the board. The display flashes s. Press the zero key to change to flashing E. Press store to scroll to zero balance. Press semi auto tare. This captures zero without clearing the span calibration. The display will scroll around for a short period when complete press store.. Release the micro switch and scale will go thru warm up routine then display zero. Hope this helps, regs Darren.
Sep 28, 2011 | Health & Beauty
Data will not stay stored
I assume that the data clears when you turn off the T/W, if so the batteries need changed. Depending on the age of the machine they are either on the R. or L. on the base just beyond the keyboard, they will probably be corroded so be sure to clean the holder contacts.
DickyO
Feb 11, 2010 | Lexmark Wheelwriter 6 Series II Typewriter
How do you program users?
Storing and Recalling Weights
1. Your scale can store and recall up to 5 weights. If your scale has one button,
weights can be stored for one user. If your scale has two buttons (User and
Save/Recall buttons), weights can be stored for multiple users.
2. Tap center of scale platform with foot and wait until "00.0" appears.
3. Stand on the platform without shifting or moving until weight is displayed.
4. For single user scale: When weight reading appears on screen, step off the
scale, press Save/Recall button and hold for about 2 seconds to save the
reading.
For multiple user scale: When weight reading appears on screen, step off the
scale, and press User button to select a user number. Then press Save/Recall
button for 2 seconds to save the reading.
5. Weight reading blinks twice, then becomes stable. A small number (1-5)
appears in the upper right hand corner of your display, indicating which of the
5 weights is displayed. (Once you have 5 weights in memory the current weight
always saves as "1" and the oldest reading is eliminated.)
6. Weight reading is saved. Press Save/Recall button to review the last 5 weights or
let the scale shut down automatically. (Note: until you have 5 weights stored in
memory, the display will show the number and "–" for each weight for which
no data point has been stored yet; i.e. "3 –", "4 –", "5 –" if only 2 weights
have been saved.)
Hope this helps!!
Feb 09, 2009 | Precision Camera Weightwatchers WW70 Body...
RTO Weight Watchers Glass Precision Electronic Scale WW34 Logo
22 people viewed this question
Top RTO Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a RTO Health and Beauty Expert? Answer questions, earn points and help others
