Question about HP Computers & Internet
My pc works properly in safe mode but not in normal mode
    Master:
  • 545 Answers
Formatting and reinstalling your operating system would be easier than finding the registry error or other problem causing this. One solution might be to run ccleaner
Posted on Nov 10, 2012
hockeyguyJC
  • 133 Answers
SOURCE: PC won't Start windows normally
You can attempt to undo this through the use of System Restore.
I am going to assume you are on Windows XP, So start your computer in safe mode without networking.
Once you are in the desktop you are going to use System Restore. Choose a date in time on your computer before the incident happened.
For more information on the system restore utility go here:
http://www.microsoft.com/windowsxp/using/helpandsupport/learnmore/systemrestore.mspx
Note : If you have Windows Vista ,read about this utility here:
http://windowshelp.microsoft.com/windows/en-US/help/9f6d755a-74bb-4a7d-a625-d762dd8e79e51033.mspx
Posted on Aug 20, 2008
siawolf
  • 749 Answers
SOURCE: Computer will not start past safe mode screen
In safe mode, hit start button -run, and type "msconfig" in the box , hit enter.
the system configuration utility opens.
select startup tab at the top
when the startup screen opens, UNcheck all the boxes, press APPLY, then OK
the computer will prompt you to restart, when it restarts it will give you a message saying you have use the system configuration utility to change the way windows starts, this is normal. Check the box that say dont show this again and click OK.
doing this will keep the programs set to start when windows starts from starting untill you start them manually. If one of them is causing the freeze, this will make the system accessible.
Keep in mind, you may want to turn some of them back on after you get the computer going and when you do , turn them on one at a time and restart the computer after each change. this way you can identify which program is causing the problem.
Hope this helps. please repost if you have more questions
Posted on Oct 08, 2008
Buschchris1
  • 474 Answers
SOURCE: HP a1620n- Will not startup properly
alright, i can help you.
First, do you have you XP CD?
You will need one, any one, or the instaltion disk that came with it that has the recovery files.
1. put xp disk in cd drive, reboot and boot from CD. You may have to hit F12 to get to the select boot device screen.
2. once the cd boots it should go into the blue winxp install screen and start loading.
3. once its done, press " R" it should be an option for repair.
4. allow system to do its thing and it will go to a command prompt. If it asks for admin password, do so and hit enter.
5. You should now be at the C:\ command prompt. Typ exactly: chkdsk C: /p and hit enter.
It should run a system disk check and repair missing files.
6. once done, type EXIT and hit enter, then when it restarts, remove the disk and when it gets to the black and white asking to choose startup. just hit Enter and it should work fine.
Let me know if it doesnt work and we can try something else.
Posted on Dec 01, 2008
  • 109 Answers
SOURCE: My home Pc wont boot up at all in safe mode or
hit F8 repeatedly at startup to go to safe mode, then try and re-install drivers.
Posted on Dec 24, 2009
SOURCE: I started my pc in safe mode to attempt to remedy
TYPE MSCONFIG at cmd prompt or run
at boot menu check if safe mode is ticked thn untick it
Posted on Mar 05, 2011
My safe mode has been on 3 days,I have tried to turn off power,and restart.Also tried to turn and tap power off.Any other suggestions how to get off,and why did it appear
A laptop or computer in safe mode normally suggests a corrupt file caused by switching off before it has closed down properly. Run safe mode and check for faulty files.
Jan 10, 2016 | Computers & Internet
Get safe mode off
Windows sometimes automatically runs on safe mode if the computer was not shut down properly the last time it was used. There is no turning safe mode off, you just need to restart your computer and everything will be back to normal.
Jul 17, 2013 | Gateway ZX493131e Notebook
I stop my laptop on save mode by the push bottum and now it start up and go back to save mode and want open windows
Let it boot in Safe Mode. It is showing you the safe mode and other options because you did not shut it down properly. Once safe mode boots up all the way, click Start/Shutdown or Restart and let it come back on normally.
Apr 01, 2012 | Computers & Internet
My dell dimmension e521 won't load to window screen.....i can't even get in to safe mode.......help
How did you try to get to safe mode. Have to tap F8 continuously for a while as soon as pc starts to boot. Holding key down might not work so it's better if you can keep tapping key quickly. If you have tried several times and can't get it to start in safe mode windows will normally put up an error screen to say windows didn't start properly with a few options. If you see this screen select last known good configuration and it might start to load windows normally if you are lucky.
Jan 01, 2011 | Dell Dimension E521 PC Desktop
Dell Inspiron 1545. When booting to vista the screen goes black. When booting to safe mode the screen works normally.
Please reinstall the Video Driver and check if the same issue persists. If the issue started within last 90 days, you can try the System Restore
Jul 01, 2010 | Computers & Internet
Sony Vaio will Won't start on normal mode.
Ok startup in safe mode but choose System Restore, do that and follow instructions. Restore it to a time when it worked, ya should get a choice of restore points.choose the most recent one. If that doesn't work ya gonna have to reinstall ya operating system from DVD again.
Jan 26, 2010 | Sony VAIO Notebook
Frozen cursor
do you have a wired or wireless mouse?
Have you tried attaching a different mouse to your computer?
What is the brand name of your mouse?
Try booting your computer in Safe Mode. To do this, after turning on the computer, press F8 button several times. You will see a screen that will ask you to boot normally, boot in Safe Mode or boot in Safe Mode with Network Connections. Select Safe Mode.
See if your mouse works then.
Check back with me for further help, if needed. There are additional things you could try.
Oct 08, 2009 | E-Machines eMachines Desktop PC
Your computer stopped responding, restarted unexpectedly, or was automatically shut down to protect your files and folders. Choose last known configuration to reverse to the most recent setting that...
Choose safe mode and see if you can get into it. If you can then go into system restore and choose the last date that you remember the computer working properly.
At this point the computer will restore the computer back to the earliest date that it was working properly.
Once you do this the computer will reboot and it should go back into windows normally and work just fine. If for some reason it doesn't then windows is corrupted and you'll need to wipe out the hard drive and restore the computer back to factory defaults.
Aug 21, 2009 | Sony VAIO PCV-V210P PC Desktop
Start Normally (black screen with options)keeps re-loading itself
If you can't get into windows normally or into safe mode to try to restore the system back to a date when it worked properly then you'll need to wipe out the hard drive and start the system from scratch.
Feb 08, 2009 | Compaq Presario SR1050NX (DW257A) PC...
Won't boot up properly
Try choosing Safe Mode. Then shut down windows properly, file shutdown, then start up again and see if that works for you.
Dec 17, 2008 | Dell Dimension 4600 PC Desktop
Computers & Internet Logo
14 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
