Question about Kenmore 22622 Top Load Washer
Machine will not wash on cold or warm only on hot
Checked the water line and cold water comes out.
  • Kenmore Master
  • 5,568 Answers
First I would suggest you remove the hoses from the back of the machine and use a mirror to peer into the connections of the machine to make sure it doesn't have an accumulation of grit blocking either connection.
The connections to which you attach your water lines are extensions of a mixing valve. If you are lucky, this has failed since they are not expensive to buy or difficult to replace with a few common tools.
If you aren't lucky, then the programmer has failed and that is far more costly.
This may not work on your machine but is worth a try:
- Turn off the water supply at the wall. - Turn on your machine to any program segment as if you wished to use the machine - Switch the cold-warm-hot switch back and forth while listening closely near the hose connections.
Some mixing valves will make a little noise when changing over between wash/rinse temperatures. If you can hear distinct clicks from inside the machine, then you may have a failed programmer.
Posted on Jan 05, 2009
gdmisp
  • 66 Answers
SOURCE: hot water doesnt work, switch to warm and warm comes out.
If the cold works on cold wash but the hot don't work on hot wash . Then yes the switch is bad.give What model is it?
Posted on Jan 16, 2009
  • 213 Answers
SOURCE: washing machine water control
remove the cold water hose from the back of the washer. look inside the area where you unscrewed the hose from. there is a screen in there. if its clogged with sediment remove screen and clean. if that doesnt fix it or if theres no sediment youll have to replace the valve to fix the problem
Posted on Nov 27, 2007
AlmostBob
  • 550 Answers
SOURCE: kenmore heavy duty washing machine 70 series
The most likely cause for water fill temperature problems is the solenoid has burned out, usually cold first, it gets used more. Not a repairable item , easy to replace
Posted on May 25, 2008
WRMtech
  • 70 Answers
SOURCE: Kenmore Washing Machine - no cold water coming in
most likely cuase would be the inlet valve
you would need the complete model number to make sure you get the right part for that unit.
Posted on Feb 24, 2009
SOURCE: LTE6234DO Whirlpool Thin Twin-No hot water
The inlet valve that the hoses attach too the solenoid for the hot side may be stuck closed or clogged with sediment. May need new inlet valve.
Posted on Mar 18, 2009
No cold water coming into machine
Follow the cold water line inside the washer where it connects to a 'Fill Valve' which is a valve/solenoid. Using an electrical test meter check the two wires at the solenoid for 110 volts when the machine is calling for cold water. If there is voltage but no cold water the valve is most likely bad. You may also want to pull the hose to make sure you have water running through the hose from the spigot. With the hose off at the valve look to see if there is a screen at the valve that might be clogged.
Dec 04, 2013 | Roper Washing Machines
Error code of NF (no fill) on samsung top load washer (WA422PRHDWR/AA) even after checking lines for restrictions and ensuring clean line filters (red and blue). Now, when it does work, it will only do a...
Put the temp select switch on HOT, start machine. If water comes out check the flow amount. If no water flow, replace inlet water valve. If there is water flow switch to COLD, start machine. If water comes out check the flow amount should be approximately equal or slightly more than flow on HOT. If no water flow, replace inlet water valve. Move selector to WARM, start machine. Now there should be twice the flow of water than there was with HOT and COLD temps. I suspect it is the HOT side of inlet water valve that has failed because machines usually rinse with COLD water.
Jan 20, 2013 | Samsung WA422PRHDWR 4.2 Cu. Ft. VRT Top...
Wa422prhdwr
either the hot water valve solenoid is bad or not getting power and not opening to blend hot and cold water to get the warm wash water the hot water hose has a screen in line and could be plugged with sediment and restricting hot water flow remove hot water hose and check this first
Oct 27, 2012 | Samsung WA422PRHDWR
I am getting warm water when we have selected colc/cold. I have checked the cold water intake and it works. In fact, if I shut the hot water intake, I only get cold water for the wash. What is causing...
If you turn off the hot water line, and you have cold water then suspect the water inlet valve. Unplug the unit and turn off the water to disconnect the water hoses. Pull out the washer and remove the back of the unit by the water hose inlet. The new valve is around $65.00 and is on connectors, which make it an easy fix.
Feb 22, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
The washing machine won't start if "cold water" only is selected. It will only work when "warm water" or "hot water" is selected (and even then there is only hot water filling the machine, the cold water...
Check the cold water solenoid. If a meter is not available you can swap the hot and cold wires and see if the symptom changes to hot water when cold is selected. If so the mixing valve needs replaced. If no then further testing of the wire harness and timer circuit are needed.
Eric
Apr 13, 2010 | Kenmore 13202 Top Load Washer
Possible Mixing valve Problem
I would pull the lines off the back and check the inlet filter on the hot and cold sides of the water inlet and clean the screen style filter. If you just use cold is the water cold if the cold water valve was bad then you would get no cold wate when set to cold.
Jan 20, 2010 | Maytag PAV2300 Top Load Washer
Warm Wash: Force it to be cold?
you will need to put a "Y" in the cold water line and remove the hot water hose otherwise the hot water solenoid will open up and let in hot water,if you have cold water to both solenoids then you can get done what you want to accomplish,wash and rinse in cold water on all cycles
Dec 24, 2009 | Washing Machines
Hot water doesnt work, switch to warm and warm comes out.
Jan 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Cold water valve won't turn on to fill washer
either the valve has failed or the water line screen is blocked.
Aug 31, 2017 | Maytag Neptune MAH5500B Front Load Washer
Kenmore 22622 Top Load Washer Logo
46 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
