Question about Kirby Ultimate G Bagged Upright Vacuum
Why won't my kirby shampooer suck up water
Shampooer wont pick up water
  • 7 Answers
SOURCE: kirby sentria carpet shampooer
you dont **** out the water....if you use the reccomended Kirby shampoo there is no need to **** out the water because it is a semi dry liquid ...it will dry by its self in about 1 hour....I,ve been with Kirby for 16 years now ...i will know
Posted on May 19, 2009
SOURCE: kirby diamond edition - shampooer
1. Raise the vacuum head all of the way up. 2. Remove the vacuum head by removing the belt and releasing it. 3. Place the shampooer head on the vacuum by securing the clamp and them put the belt on 4. Take the bag off of the vacuum by twisting at the base just slightly outward and lifting upwards and unclamp it from the handle 5. Put water and cleaner into the water resevoir. 6. Put the reservoir on to the kirby where the bag was by holding it parallel to the vacuum then using both hands, twist it outward slowly until it goes down onto the unit then twist back to parallel position. 7. Put the coil looking piece on the shampooer head on top where the hole is...it will only fit one way successfully. 8. Put the other end on the under side of the water reservoir. 9. Lower the shampooer head all of the way down on the carpet just like you would the vacuum head 10. Turn on the vacuum and reach down and turn the knob at the top of the reservoir, this will begin putting cleaner (tons of foam) onto the carpet. Just work in 3' x 3' sections, turning off the foam intermitently until you are finished. I hope this helps.
Posted on Sep 03, 2007
b0sslady2001
  • 357 Answers
SOURCE: shampooer instructions
Here's my online guide for using the Kirby shampooer....
http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
HOPE IT HELPS!!
Marci
Posted on Oct 23, 2007
RockyNR1
  • 324 Answers
SOURCE: kirby Sentria shampooer
HERE is the shampooer manual. There is no suction involved picking up the water. It simply scrubs the solution off the rug and throws it in the tray in front of the Kirby vacuum.
Posted on Nov 25, 2008
RockyNR1
  • 324 Answers
SOURCE: have kirby g4 carpet shampooer, need instructions for shampooer
Check out the online shampoo manual HERE
Good Luck,
Rocky
Posted on Mar 28, 2009
Kirby G3 vacuum shampooer is not picking up water.
Belt may be slipping or wore out. Are you running the brush too low to the carpet. That will prevent it to work.also you have to take the cap off the container when sucking the water up.
Sep 01, 2016 | Kirby Vacuums
Kirby shampooer not sucking water up
Your belt is not properly connected. Here is the instructions to properly install the belt on the main power nozzle. It works exactly the same way as the shampooer head, so this should be of help...
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
Marci
Jun 13, 2009 | Kirby G6 Bagged Upright Vacuum
NOT SUCKING UP THE WATER
The Kirby shampooer isn't designed to be a extractor.What the shampooer does is create the foam,and the brushroll on the shampooer works it into the carpet.After the carpet is dry,(about an hour,)switch to the vacuum,and the vacuum picks up the dry foam.
Dec 15, 2008 | Hoover SteamVac F5914-900 SpinScrub...
My G series kirby carpet cleaner will not **** up the water or foam very well
The Kirby shampooer deposits the foam onto carpet,and works it into the carpet with the shampooer brushroll.After the carpet is dry,use the vacuum itself to pick up the dry foam and dirt.The Kirby Shampooer is not an extraction shampooer
Nov 14, 2008 | Kirby Vacuums
Kirby Sentria shampooer
Jul 19, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Help with shamppoer for kirby g4
this site may be helpful
make sure the brushes on the shampooer head are spinning and that you have the shampooer head lowered all the way down to its lowest setting.
Jan 07, 2008 | Kirby G4 Bagged Upright Vacuum
Kirby sentria carpet shampooer
Jun 13, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Ultimate G Bagged Upright Vacuum Logo
233 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Gerry Harvey
Gerry Harvey
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
