Question about Dryers
Kenmore clothes dryer will not heat, but runs w/cool air - Model # 110.96591440
Dryer air is not warm - dryer tumbles clothes and blows cool air and shuts off
    Top Expert:
  • Dryers Master
  • 9,472 Answers
Posted on Nov 10, 2012
4 Suggested Answers
  • 1122 Answers
SOURCE: maytag electric dryer model mde308dayw not heeting up
CHECK YOUR WALL VENT AND DRYER VENT AND MAKE SURE THEY ARE CLEAR,ALOT OF THE TIME IF BLOCK THEY HOLD THE DAMP HOT AIR IN THE DRYER AND WILL TAKE FOREVER TO DRY,IF NOT THAT IT CAN ONLY BE YOUR HEATER BOX OR HEATER BOX FUSE,IF YOU HAVE A METER YOU CAN CHECK BOTH,LET ME KNOW-MIKE
Posted on Dec 06, 2008
  • 530 Answers
SOURCE: dryer heats, tumbles clothes, blows air out exhause vent, but wont dry clothes
what type is this electric or gas? have you removed the exsaust from the wall and ran a load like this? if you have heat and this is an electric dryer it sounds like you have a blockage in your house. if the dryer runs fine without the exsaust attached then that is your problem. let me know
Posted on Jun 02, 2009
heatman101
  • 43501 Answers
SOURCE: dryer is tumbling clothes but there is no heat to
Check out this tip... it will help you with your problem.
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
Heatman101
Posted on Mar 23, 2010
Kenmore Gas Dryer does not dry clothes.
If this is the electric version then after 15 years you probably need a new heating element, they are not difficult to install and are not terribly expensive as a DIY project.
Jan 12, 2013 | Dryers
Wed9200sq0 heats, tumbles but does not dry at any heat setting
You are correct. Pull the dryer out and disconnect your venting from the back of the dryer. Turn your dryer on and check to make sure your dryer is blowing air out of the dryer duct. If it is then leave your dryer out at least 2 ft from the wall and run a load of clothes through the dryer. If it dries your clothes normally then you have a venting restriction. Check to make sure your venting is clean, not kinked or smashed, make sure your outside vent is opening an doesn.t have something blocking it. Check your lint screen filter by running water through it. If water is not flowing through it, you have a build up of fabric softener on your screen, blocking air flow. Scrub your screen off and test again. Good Luck, Appliance Specialists
Dec 30, 2009 | Whirlpool WED9200SQ Electric Dryer
I have a 30 year od (Sears) Kenmore Dryer and just
Haven't found a solution nor any help. The only thing I saw was an ad to "upgrade" for a fee to get assistance
Dec 29, 2009 | Kenmore Dryers
Kenmore Gas Dryer Model # 97281800 - will not turn on. The dryer will not turn on, does this machine have a Fuse?
kenmore 97281800 drum turns good ,all vents are clear,only blows
very little.take the cover off blower compartment blows a lot.only warms the cloths. runs very well just does not dry. WHY does the blower not blow very much when its all together? is that the reason the heat cycles mostly off? three hours to dry a well wrung out load
KEN
Dec 23, 2009 | Kenmore Dryers
My dyer heats and tumbles, but doesn't dry
I'd check first for clogged vent hose or clogged lint filter or clogged vent flap on wall (outside).
If that's not a problem, it may be a faulty thermostat. Heating element is probably okay if it heats some of the time.
More info, let me know.
Charlie
Oct 01, 2009 | Kenmore Dryers
5 Year old Kenmore Elite Electric Dryer will not heat.
limit switch either the one on the heating element or the one in the air duct they are easy to check if u know how to use a meter they should read continuity when they are cold and open up at a certain temp
Aug 24, 2009 | Kenmore Dryers
Model DLE7177RM, takes about 3 hours to dry a load of clothes. Dryer is NOT overloaded.
Does the dryer heat up or is it just cool air drying the clothes ? If it does actually dry the clothes eventually then it sounds like it is heating up. First thing to check would be exhaust hose. Is warm air blowing out of it ? If warm you got heat. If cool then your heating element isn't working. It should be fairly strong current of very warm air. If weak but warm, then somewhere between lint filter and end of hose you have a blockage caused by lint buildup or hose is bent and blocking air flow. Check hose first. You can disassemble lint trap and go beyond the lint screen into metal duct within dryer and clean with a long brush and vacuum. You can also disconnect exhaust duct flexible hose at back of dryer and work through metal duct from that end too. If you notice increased air flow then it should solve problem,
Aug 05, 2009 | LG Dryers
Dryer heats, tumbles clothes, blows air out exhause vent, but wont dry clothes
Jun 02, 2009 | Kenmore Dryers
Dryers Logo
149 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
