Question about Toys
Bobcat S185 no lift / TILT AND NO CODE - Toys
2 Suggested Answers
  • 3519 Answers
SOURCE: How do you bleed the hydraulics on a Bobcat 751 skid steer loader?
Hi Joseph:
Usually hydraulic components will "self clear" any air in the system just by trying to cycle through the functions a few times.
Have to ask the question............
Did you remove and replace the hoses one at a time, or did you take them all off at the same time?
The reason I ask is............ Could there be a remote possibility that any of the hose onnection locations were switched?
Posted on Sep 23, 2015
Testimonial: "I did remove three of the hoses at one time simply two of the hoses were rubbed through and to remove one of the ones I had to remove another to get at one rubbed through. However I am 100% sure they are installed correctly because only two of the hoses are the same diameter and they run parallel to each other and one has to be installed before you can install the other. Thank you for your help. I see I need to get more hydraulic fluid as my level went down after trying system. Joe"
I have a 753 f series bobcat and the lift and tilt stop working after about a minute after start up. its like it stops working after the pressure builds up.
problem flow control valves locking off flow
they are valve used in hydraulic to control the operation of hydraulics should a hose or cylinder fail by blocking of flow if it exceeds a set rate
discus it with the technician to determine if they are faulty and to get a proper diagnosis
Sep 18, 2017 | Cars & Trucks
BOBCAT BUCKET WONT LIFT OR TILT
Low on fluid or a bad solenoid.
Jan 03, 2017 | Toys
Bobcat T450 with 9hrs. Code M1732. Faulty lift/tilt lock solenoid?
Hi Randall:
With only 9 hours on the machine I would be going straight to the service /warranty dept of the company that i bought it from.
It should be under warranty and repaired promptly and happily.
Cheers
May 13, 2016 | Toys
Hi Joseph:
Sep 23, 2015 | Toys
Bobcat s185
Make sure your battery is in good condition. It sounds like your glow plug cycle is taking all of the battery power and after the glow plugs kick off then you have enough power to crank the engine.
Apr 26, 2013 | Cars & Trucks
I get code 32-49 Lift actuator short to ground.Does this mean I have to replace the actuator?
Switch lift and tilt actuator plugs and see if problem changes to tilt actuator fault. If so yes replace lift actuator and calibrate actuators.
Feb 08, 2010 | RTO Construction Bobcat by Woody Click
Toys Logo
62 people viewed this question
Top Toys Experts
Tom Chichester
Are you a Toy Expert? Answer questions, earn points and help others
