Question about Swisher T14560 T - 60" Trailmower with 14 - 1/2 - Horsepower Briggs & Stratton I/C12 Volt Starter
14.5 briggs no spark
Beginning trouble shooting. Machine has been sitting for awhile and never has had many hours.
  • Andy Hamilton Nov 21, 2012
    THanks for following up. Sorry that I have not gotten back to you sooner. I had to back up a little before checking in to the sparking problem. Turns out the solenoid is bad and I am waiting for one to show up. Once I get that in I will again be tracking the spark around. Thanks again and I will let you know.
  • 430 Answers
To test for spark remove ground wire from ignition module and test for spark with a proper spark tester. If you have spark the module is good and the problem lies elsewhere. No spark and the module is bad and should be replaced
Posted on Nov 19, 2012
  • Andy Hamilton Nov 28, 2012
    Thank you for the help. I am now getting spark and after replacing the solenoid can now crank the motor. It now seems that I am not getting gas. IF I prime the carb with a little gas it will start right up but stop immediately. Any ideas? Thanks again for all your help.
  • Jeff Hagemann Dec 03, 2012
    Since it runs on a prime you have narrowed it down to a fuel problem. Since it has been sitting for a while the fuel has likely gone bad and guimmed up the carb. I would rebuild the carb and drain the fuel tank and replace with fresh fuel. You should be ready to go then.
Got 2000 buick regal wont start turns over trys to start but doesnt
Could be multiple issues.
#1 Is there gas in the tank? #2 is it bad gas ? (car sitting awhile) may need to put HEET in it and put in some good gas. You may have water in your fuel line. #3 is your fuel pump working? Your fuel pump relay may be bad. Hard to answer online.
Sounds like your battery is good and you are getting spark? I'd ask a local mechanic to take a look & trouble shoot.
Nov 16, 2016 | Buick Cars & Trucks
1997 5.7L c2500 suburban. I have replaced ignition,coil,distributor,fuel pump,fuel filter,plugs,plugwires,crank sensor,egr,spider injection. After it sits for awhile, hard to start Need advice please
Sorry dude but did you test anything before replacing parts ? There is a step by step diagnostic path to trouble shoot a problem like these. Does it have spark, does it have fuel pressure an is there compression in the cylinders ? After all that you should take it to a ASE certified repair technician !
Aug 30, 2015 | Cars & Trucks
Briggs and Stratton 14.5 OHV 287707
You need pull spark plug so it can over. Let sit awhile be for trying to start.
Mar 10, 2014 | Garden
2004 Jeep liberty runs hot while sitting idle
start with check fluid level --cooling fans operation --water pump to start
Apr 29, 2017 | 2004 Jeep Liberty
Briggs and stratton 875 series
Engine hunting is fuel starvation, dirty fuel, partly blocked main jet.
Jun 02, 2012 | Swisher T14560 T - 60" Trailmower with 14...
After running for awhile the engine begins sputtering and dies out. I generally have to keep it a full throttle to keep it running. I tried spraying down the carb with cleaner which allowed me to run with...
always check spark and compression first spark needs to be blue and compression should be 120 but will barely run on 80psi if both are fine rebuild and acid dip carb the adjustment is 2 full turns out
May 19, 2012 | Briggs & Stratton Briggs Stratton Intek V...
My 1992 dodge dakota truck will crank but not start
The basics, make sure battery has a full charge. If it cranks good but won't start, have a helper crank it while you check for spark at the spark plugs. If spark everywhere, use a gage and check proper fuel pressure. Also check fuel injector pulse. Any applicable trouble codes? Your obd1, you should be able to check some codes, yourself.
You can try cycling the key on and off several times before you crank it, when problem is ongoing, if that helps, I think it's a fuel issue.
Jun 11, 2017 | 1991 Nissan Pickup
Our Vanguard 14 hp was idling and stopped. It
If this engine has been sitting for awhile I would guess the carb. is gummed up and need a good cleaning. First thing I would do is try a fresh spark plug. Just because the plug looks good doesn't mean it is. If you have a fuel filter check this also. If it is getting fuel into the carb and has spark and compression I would remove the carb and clean it.
Hope this helps
Bob
Oct 23, 2009 | Briggs & Stratton Tools & Hardware -...
Motor runs erratically
Try cleaning the air filter and the fuel filter. Sawmills are dusty places and timber dust can clog-up air filters. Air filters in chainsaws are cleaned hourly for max efficiency.
Oct 09, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Swisher T14560 T - 60" Trailmower with 14 - 1/2 - Horsepower Briggs & Stratton I/C12 Volt Starter Logo
177 people viewed this question
Top Swisher Garden Experts
lnbn1975
Jim Parker
Jim Parker
Tim Whalen
Are you a Swisher Garden Expert? Answer questions, earn points and help others
