Question about Charles Leonard Masonite Clipboard Brown 9x12.5 Letter Package Of 12
I would like to take clip off to decorate then put it back together again
  • 61 Answers
It's riveted on there, you will need to drill them out, then re-rivet it
Posted on Nov 09, 2012
Singer sewing machine Model 9134, problem trying to put the bobin case back in after cleaning, how do I put it back together?
make sure the needle is in the upper most position and the clip on the bobbin case is facing you
It should just clip in on the shaft
May 01, 2015 | Singer Sewing Machines
Tod's money clip loosened
1. Fold the bills in half again to fill the clip.
2. Use a pair of needle nose pliers to squeeze the two halves of the clip back together again at both ends where the bend is accessible.
Sep 06, 2013 | Clothing Accessories
Droped the remote in a pint pf beer will it work again
It will work again if you take it apart and clean the entire circuit board with alcohol. Clean also the keypad. Let dry and put back together. Some have screws holding them together and some have plastic clips that you have to take a knife to pry apart and unclip.
May 29, 2011 | Toshiba 32A30 32" TV
WAS MACHINE FILLS UP WITH WATER AND THEN WHEN THE SPIN CYCLE TRIES TO START IT MAKES A HUMMING NOISE THEN BLOWS THE CIRCUIT BREAKER.
You have a bad motor. 8528158 Is the part number for it, the average price is around 87.00 and is very easy to put on. You can order this part from apdepot. When you go to put it on, the control heading has two screws that you have to take out and the left the heading up and toward you if you were standing in front of it. Next disconnect the lid switch, take the two brass clips out, then pull the case toward you once again if you are in front of the machine. Once you have it apart, at the bottom at the center you will see the water pump connected to the motor by to clips. Remove the pump and then you will see the motor held on by two clips with a 1/4" screw in each clip. Disconnect the plug that goes to the motor, take the clips off and slide the motor out. On the back side of the motor will be a motor coupling you'll want to put on the new motor. Put the coupling on, line it up with the empty slots on the rubber wheel thats on the transmission coupling and slide it back it and put it all back together. Once you start you'll be amazed at how easy it is!
Nov 02, 2010 | Roper RAX4233PQ Top Load Washer
KEY BOARD DOSNT WORK PROPERLY
Take the back panel off by undoing the screws ,then un-clip the keyboard & under it you will see a ribbon cable going to the main board theirs two little clips on both sides where it joins, lift them up with your finger nails then push the ribbon in untill it's straight & all the pins are back in then clip it back down.test it before you put it back together.
other than that clean under the buttons with some contact cleaner & a cotton bud..
GOOD LUCK........
Sep 04, 2009 | Lenovo 3000 N200 Notebook
C clip is broke / now how do I put it back togather
There are two "C" clips on a Hayward EC40. Both on each side of the tube sheets. Attach the clips, put the head back on by slipping the shaft up into it and secure the handle to it with the pin and nut, then pop the cover back on.
Aug 03, 2009 | Hayward EC-40 DE Pool Filter with pump
I do not know how to remove the top from my whirlpool washing machine to replace the lid switch
Unplug the machine.
There is a screw at the bottom of the console on each end of the machine, remove them.
The console should then lift up and roll over the back(just make sure its supported or suports its self).
At the center of the machine there is a white plug, for the safety switch, unplug it.
On each side of the machine there is a brass colored clip, use a flat screwdriver and insert it into the front of the clip, push back smartly, this will release the clip. PAY ATTENTION to the way the clip comes out. (which end is the front of the clip) mark things if your not too handy so it goes back together easly.
This machine is put together alot like a puzzle so paying alot of attention to what you do will alllow you to put it back together.
The whole cabinet rolls forward, the sides along the bottom sit on an edge on the bottom, but the front is hooked UNDER the bottom edge. try to notice this. as you rotate the cabinate the front will fall free after you rotate the whole thing over about 45 degrees. The back will kinda float.
Apr 08, 2009 | Kenmore 24032\24036 Top Load Washer
The Decoraters house on Professer Layton & the curious village
105rooms.gifTry this
Both Rooms should look like this
Any problem please let me know and i will help
JonnieC
Mar 19, 2009 | Nintendo Professor Layton & the Curious...
Nintendo ds shell replacement
you may have something that is touchign the screen, or the wiring may have been disconnected accidentally. try taking it apart and putting it back together again.
Jun 02, 2008 | Nintendo DS Console
Charles Leonard Masonite Clipboard Brown 9x12.5 Letter Package Of 12 Logo
76 people viewed this question
Top Charles Leonard Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Charles Leonard Office Equipment and Supply Expert? Answer questions, earn points and help others
