Question about Dell 926 All-In-One InkJet Printer
CAN'T GET FAX WORKING.
I have a dell 926 all in one. I have 2 phone lines , one for house and one for fax. I have tried hooking it up many ways but it still answers through my house phone. I have internet with cox cable and my phone lines are also with cox. I use a modem to hook up to the internet and my phone line also hooks up to this modem. Can someone please help, I am not that familiar with hooking things up and still have a lot to learn about computers. Please explain in simple language that I can understand. Thanks!
  • shirlm519 Jan 06, 2009
    Thanks for the info. I now have ir working.
    Master:
  • 461 Answers
If it's answering on your main number, then you are not plugged into the fax jack. You should have a separate phone jack for fax. If you have internet phone there should be a second jack on the back of your phone box. You can test that you have a functioning second line by plugging the fax into it and using the fax unit to dial your home number.
Posted on Jan 05, 2009
All In one Dell printer 926 can't get it to send a fax. There's no place for a phone line to be hooked into it and it tells me there's no phone line but I have dsl and the phone line for home phone and dsl...
You can find information on your product here:
http://support.dell.com/support/topics/global.aspx/support/kcs/document?docid=266274#Issue0_3
I recommend you check to make sure you have the most current drivers for your PC modem and that you also download the User Guide for your printer for the guidance on using your printer to send and receive faxes.
You need to setup your system to use the modem in your PC.
Here is how your system should be setup:
http://img144.imageshack.us/img144/6615/nonstandaloneprinterdiaab7.jpg
Note that you will need a DSL filter on the phone line to your computer.
Feb 11, 2011 | Dell Photo 926 All-in-One Printer
Need to hook up a fax for an all-in-one printer
The user manual for your printer is located at the following website; you can download it and store it on your computer.
You simply need to plug the phone line into the printer in order to use the fax feastures
http://support.dell.com/support/edocs/systems/prn926/en/index.htm
Nov 10, 2009 | Dell 926 All-In-One InkJet Printer
Will not fax. says I have a phone problem. Need to know if it is hooked up right
You may hae your phone line plugged into the wrong phone port on the fax. There are typically two. One is for the line coming from the wall, and the second is to connect a phone to the fax, which isnt necessary.
Oct 29, 2009 | Dell 926 All-In-One InkJet Printer
All-in-one926 printer fax won't work
get all phone lines and connections checked or replaced also usb connections
Oct 03, 2009 | Dell 926 All-In-One InkJet Printer
To use my dell printer all in one for faxing documents
make sure the phone cord is in the line jack on the back of the machine.
Jul 31, 2009 | Dell 926 All-In-One InkJet Printer
Photo 926 fax no dial tone
ALL fax machines are ANALOG devices and will not work reliably on DIGITAL phone lines.
Jun 30, 2009 | Brother IntelliFax-2820 Laser Fax
Setting up fax feature
get a separate telephone cable and attach it to your fax, switch line over from phone to fax manually at the phone line input on the wall, it's the ONLY way I can manage that same problem. If you forget to "switch" your lines over, unplug the fax from the wall & answer your other house phone that's plugged into the wall. Works every time. It takes a little effort, but why pay for more phone lines when all you have to do is plug/unplug an extra phone line?
May 16, 2009 | Samsung CLX-3175FN Color Laser All-in-One...
Fax won't send
Hallejuia!!! Someone from the Dell community forum posted this....it worked!!!
Yes. It has something to do with the time change. I had to go into the time in my pc and manually adjust (take off automatic daylight savings) the time. Once you do this you need to restart your system. That should take care of the issue.
Mar 10, 2009 | Lexmark X4270 All-In-One InkJet Printer
Will not fax
Hook a phone to the fax line and try to dial out... a fax line is no different than a phone line at your house ,, don't use a multi line phone like the ones at the office use a phone like you would have at the house to hook the the fax line .. If you are able to dial out call someone and check the line for static and pops they can cause the fax not to work either.. Good Luck
Mar 31, 2008 | Ricoh 2050L Laser Fax
Dell 926 All-In-One InkJet Printer Logo
174 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
