Question about RCA RP8070 5-Disc CD Changer
I have removed the five screws on the back of the cover. The cover can now be lifted a little bit in the back but wont come free from the front. Are there tabs that have to be released in the front?
    Master:
  • 689 Answers
If you can,t get it apart don,t evan waste your time on it any more , You can get a good used one for $7 to $30 at the most now a days, that is better then a (RCA)
Posted on Nov 10, 2012
How to remove safely plastic casing on Krups XP9000
Remove book holder at back by pulling it off by hand. Undo the screws visible at the back cover, there's about 4 or 5 or so there. Unclip that centre back panel now screws are out. Remove clear beans cover, remove water tank, lift up the lid to drop grounds direct to brew chamber. Both side lids in open position. Now firmly grip the top cover and try and slide it directly backwards. If it is stuck a firm thump against the front side of the cavity you removed the water tank from while still pulling the top cover backwards will free it up. The sides lift directly upwards to get them off. When replacing the water tank side panel you need the front door open to clear a little spring leg.
Oct 19, 2014 | Krups Coffee Makers & Espresso Machines
How do i remove the control panel cover to see why the control lights wont come on? the inside light works and the breakers are not thrown so i checked the door switch and it clicks when i push it so i am...
UNPLUG UNIT remove three screws in back of dryer holding top, from in front of machine slide top to back of unit to remove, now you will see secrews securing panel to unit also two secrews come from inside unit to the front after these 4 screws lift user innerface panel straight up..
Now after that ck for connectors loose or unpluged hopefully, if not your going to need the tech sheet and a elec . meter to test system
Aug 06, 2010 | Whirlpool GEW9250 Electric Dryer
TI BA II battery change How do I do this without ruining the calculator!
Turn off the calculator and turn it over with the back facing you. Using a small Phillips screwdriver, remove the four screws from the back cover. Carefully pry off the back cover. Using a small Phillips screwdriver, remove the screws from the metal battery cover and lift the cover off the battery. Tip the calculator slightly to remove the battery. Caution: Avoid contact with other calculator components. Install the new battery with the positive sign (+) sign down (not showing). Replace the battery cover and the screws that hold it in place. Align the screw holes in the back cover with those in the calculator, then snap the back cover onto the calculator. Replace the screws.
The battery is a CR2032.
May 26, 2010 | Texas Instruments BA-II Plus Calculator
How do you take the cover off the canon i90
first remove the 4 screws at the back. then remove the top cover of your printer. tilt the printer with the front going upward. u will see two screws on the middle of front portion of the printer. remove it along with the screw on the side of it. then slightly lift up the back portion of the cover put a stopper in between so it wont return. turn to the front of the printer then push the top edge gently while lifting the side one at a time. after the clip on the front unlocks, u could safely remove the cover...
Feb 12, 2010 | Canon PIXMA iP90 Mobile Printer
Acer 5310 how to install ram
These are generic instructions which will very likely work for your PC:
Flip the laptop over so that the bottom is up, facing you.
Look for a small, removable cover, usually held in place by one or at the most two screws. Use a jeweler's screwdriver (small phillip's head) to remove these screws, then gently lift up on the edge of the cover to remove it. in some cases, you may need to slide the cover just a little bit toward the hole(s) where the screw(s) came out so that the tabs holding the cover in place come free.
With the cover removed, you should be able to see the RAM stick(s) that you have in place from the factory. They're small, green in color.
To remove them, use your fingernails on both left and right sides of the RAM stick to gently pull back on the little spring clips that hold the RAM down. You're only going to pull them back about a 32nd of an inch or so, just enough to release the tension. The back end of the RAM stick should pop up slightly when both clips have been pulled back.
Take a good look at how the gold pins are seated into the socket, because when you install the new RAM stick, the finished appearance should be the same.
Now, grasp the RAM stick and lift it up just a little bit and pull it out of the socket.
Insert the new RAM stick into the socket, at an angle, roughly 45 degrees and push gently but firmly until it stops and is seated evenly across the width of the stick.
Push down gently on the back of the stick until it locks into place. The little spring clip retainers will click and hold it if you've inserted the chip properly.
The RAM chip should now be resting flat against the botton and you can put your cover back in place, power up and go forward.
Good luck. Jim
Dec 02, 2009 | Acer Aspire 5315 Notebook
Whines like a dentist's drill when the power is on.
...if all 3 lights are on...
This is a laser mirror motor problem.
If you are a little bit technician then...
Remove all cables, open front panel, remove the cartridge, remove the 2 screws on top and 3 on back side, remove a white latch from underside left (or right i don't remember ).
With a small screwdriver release 4 tabs that hold back cower and remove it.
Pull a little bit on under front edges for releasing two little tabs and remove the whole cover by lifting it..
Now you can see the laser scanner unit with a yellow label on it.
Remove the screw, release the tabs an remove laser cover after removing one or two little cables over it.
You can see now a rotating square mirror fixed over a little disc, secured with a little plastic black tab.
DO NOT TOUCH THE MIRROR WITH BARE HANDS or you will make it dirty .
Rotate the black tab to release the disc, remove the mirror with a clean cloth, and put a small drop of synthetic oil on its rod... that's all.
Hope you can do it.
Jun 29, 2009 | HP LaserJet 6L Printer
How to remove the front cover of my samsung front load gas dryer
take the top off first by removing the two screws in the back, then the five screws which hold down the door section. the door will lift off and then follow the instructions
Jun 08, 2009 | Samsung DV448AGE Gas Dryer
Whirlpool gas dryer model # lgr7646eq3
put back back on with top off remove screws in top corners of front panel remove bottom panel and screws holding blower/lint screen housing on remove door springs remove screws on bottom corners of front belt is probably lying in bottom
Sep 03, 2008 | Whirlpool LGR3624JQ Gas Dryer
Hot shoe loose
Canon typically hides the screws under the metal plate on the shoe itself. You have to free it at the front and slide it back to get access to the screws holding the shoe
Feb 23, 2008 | Canon EOS-1Ds Mark II Digital Camera
Replacing the Drive Belt
I am not an expert but I do have a Hotpoint 9334 Tumble Dryer which I guess is similar to the 9314.
To replace belt or heater element you must remove the front panel complete with door.
Screws are different sizes in different places so note where they belong as you remove them.
1. Remove 2 screws at rear top which go through the brackets holding the top panel, slide back the top panel a little and lift it off.
2. Pull off the rotary timer knob and remove 2 screws beneath.
3. This is the tricky bit! Remove the the plastic panel which covers the switches etc.. This panel has 5 plastic fingers which secure it to the metal plate behind, locate the ends of the fingers where they pass through the metal plate. Using a metal rod or punch and a hammer, tap the ends of the fingers to push them back through the holes easing each in turn a little at a time to avoid distorting the plastic unduly. (This is a bit scary as you have to hit them quite hard and the fingers look fragile)
4. Open the door and remove the 4 screws then remove 3 screws at the top and 3 screws at the bottom of the front panel. Lift and ease forward the front panel, unhook the door catch release wire, pull off the electrical connectors and put the front panel aside.
5. Lay the machine on its back and remove 1 screw holding the element housing to the top plate and pull off the electrical connectors.
6. Fit the belt around the drum, through the idler pulleys and over the motor spindle.
7. Put it all back together.
Sep 16, 2007 | Hotpoint TDL14 Electric Dryer
RCA RP8070 5-Disc CD Changer Logo
44 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
