Question about Aiwa AV-D55
I own a aiwa av-d55 and when i plug it in all it does is click and the red light blinks everytime it clicks i think power supply is shot what u think
Plug it in u get red light then u here a click then red light will blink everytime u here a click
  • barrell319
    barrell319 Nov 11, 2012
    IF I COULD EXPLANE IT IN SCIENTIFIC I WOULD BUT BASICALY THE POWER PACK IS SHOT IT NEEDS A NEW INNER POWER SUPLY THANK FOR UR SEMI RIGHT HELP BUT IF I CAN FIGURE IT OUT IN TWENTY MINUTS YOU GUYS SHOULD HAVE KNOWN THAT LAST NIGHT NOT TWO DAYS LATER
  • barrell319
    I PUT NEW SUPPLY IN AND PRESTO IT WORKS NEXTTIME GO WITH THE FEELING IN UR GUT NOT A HALF *** TEC THAT REALLY DONT KNOW **** FROM A BLADE OF GRASS
SOURCE: Aiwa AV-dv75 powers on and off
Its the power relay switch which is no longer made.
I have been looking to see if there is a class action suit on this receiver
Posted on Mar 11, 2008
SOURCE: Power on but no display
must to resoldering 4 resistens of 470 ohms
Posted on Mar 26, 2008
  • 4234 Answers
SOURCE: Aiwa AV-D97 Power Issue. Just clcks when you hit the power button
The unit is most likely in protect mode. This means that the output section has a problem and the protection circuitry is preventing it from being turned on. This is to prevent further damage. The typical defective parts are the output transistors. Figure on $20-$40 for parts plus the local labor rate for repair.
Dan
Posted on Jun 10, 2008
dunnbiker
  • 8546 Answers
SOURCE: Will not turn on
Page 23...
There may be a short circuit in the speaker terminals.
Disconnect all speakers and try it. If it works troubleshoot each speaker one at a time. Shorted wires are indicated.
© Disconnect the AC cord, then correct the speaker connections.
Posted on May 05, 2009
SOURCE: AIWA Stereo AV Receiver AXR-005
did you ever get an answer?? i'm having the same issue
Posted on May 18, 2010
Plug in and red light flashes and makes a click sound
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
Nov 30, 2013 | JVC AV-32850 TV
My aiwa av-x200 click right off when I turn it on, Im thinking it is a blown fuse or something, anybody fixed any receiver with this problem?
The unit is going into protection mode. There is a fault detected in either the power supply or an overload on the output circuitry. Remove all connections to the amp (ie speakers, dvd players etc etc) Turn the unit on. If it still turns off the problem is internal and should be looked at by a qualified technician.
Feb 09, 2010 | Aiwa AV-X200
Cannot get the receiver to go off red to green/ from stand-by to on. I plugged it in after i hooked it up and it worked for a few minutes then shut off and now it will not go on again. It just stays in...
Do u have a user's manual? Does the clock show when first come on? If does adjust the time then hit enter, and the clock will go off and the system will go off, then u turn back on then is programmed. U can download a manual on www.aiwausa.com.
Dec 22, 2008 | Aiwa AV-D55
No power
Does AV-D97 sounds click of relay when pressed power button?
Nov 03, 2008 | Aiwa AV-D97 Receiver
Aiwa AV-D58 wont power on
this happened with mine two. all i did was press powert and enter at the same time and it clicked for like 2 hours or so and then it turned on. it was cool
Dec 09, 2007 | Aiwa AV-D58 Receiver
Red blinking power light
Check horiz output xistor,check all electrolytic capacitors in
power supply,esp. those numbered in the 900's.For instance,
C923 ? may be swollen on top(pooched)  1000mf/35v......
Let me know.......T.
Oct 29, 2007 | JVC AV-20920 20" TV
Set won't turn on
leaky caps in the power supply
Dec 04, 2006 | JVC AV-27230 27" TV
Hello Coach T, Reset Instructions: 1. If pressing the power button does not turn the unit off, unplug the unit, then plug it back in. 2. Press the power button while pressing the ENTER button. This will bring the unit back to factory defaults. Please let us know if you need any additional help. Best regards, nightdiver
Aug 21, 2006 | Aiwa AV-D57 Receiver
Aiwa AV-D55 Logo
48 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
