Question about Bernina Sewing Machines
Bernina 1000 special bobbin case broke - Bernina Sewing Machines
  • 6 Answers
SOURCE: Bobbin Carriage clanking noise, yet the machine sews fine??
If your bobbin area is making a noise, then do NOT sew with the machine until a reputable technician looks at it. You may have thrown something just a little off line - not enough to affect sewing NOW, but it could easily cause troubles down the line.
I suggest you call ahead and talk directly to the repair person - not to the sales person. Ask if you can bring in the machine while he/she is in the shop so they can listen while you run it.
You aren't trying to cheat the store out of the repair charge, just ensuring that the problem is diagnosed correctly.
You paid lots of money for this machine - it deserves good care.
Posted on Dec 30, 2007
Trifect7
  • 57 Answers
SOURCE: Bobbin thread not being picked up
This unfortunately sounds dismally like a timing problem. When a sewing machine makes a sudden mechanical stop as when a needle is bent slightly and hits the needle plate, sometimes the other machine bits revolve along further causing the needle to be introduced into the hook either to early or to late to catch the thread.
To test this, remove the thread, the needle plate and and the bobbin case. Replace the needle with a brand new one. Yes, again. Revolve the machine by hand via the balance wheel and watch closely as the needle goes into the hook region allow it to it move down and then just start to move up. If the tip of the hook is not pretty close to right behind the needle than it is more than likely a timing problem.
If the tip of the hook is behind the needle in the scarf (the slight hollow on the back of the needle) than it is not timing. Thread the machine normally like it is and watch what happens as you manually turn the machine via the balance wheel. The thread should catch and be pulled around the hook and let go.
Try this and then either you figured it out the problem or contact me again. Either way please vote. Thanks
Posted on Mar 02, 2008
RickE1
  • 202 Answers
SOURCE: Bernina 180 Bobbin case spinning
Its called the bobbin stopper. Pop off your needle plate by pressing on the marked corner. In the back on the left you will see a small allen screw which must have come loose. Position the bobbin stopper in place and tighten that screw. If it already is tight, loosen it and reposition the bobbin stopper in the notch and tighten it back up.
Good luck.
Posted on Oct 18, 2008
SOURCE: i need a bernina sewing machine manual
Sewing Educational Warehouse provided a very similar manual. Thanks for trying
Posted on Mar 23, 2009
RickE1
  • 202 Answers
SOURCE: Machine not working after bobbin installation
Hi, it may be possible that you put the bobbin in the case upside down and its turning the wrong way. Flip it over and try it. When looking at the bobbin in the case from the back and you pull the thread, it should turn clockwise.
Hope this helped as anything else may take a tech to diagnose.
Rick
Posted on Mar 25, 2009
I have a Bernina 153 virtuoso the part where the bobbin case goes into the plastic protrusion broke. Do I need to buy oscillating hook or shuttle hook thanks
I would suggest calling Bernina, but I bet you already thought of that. I think you really need a technician to determine what needs repairing or replacing. Sorry can't be of more help
Jun 02, 2017 | Bernina Sewing Machines
Could a missing bobbin case keep a Bernina 1000 from running? It turns on, and the hand dial works, but foot pedal doesn't run the machine
no a bobbin case won't keep it from running, there may be a problem with the foot control, or the plug that you plug the foot pedal into may have a problem, may need to have the machine check along with the foot pedal
Mar 18, 2016 | Bernina Sewing Machines
Bernina 830 Bobbin case does not swing out
Bernina 830 / 880 Bobbin Error and Bobbin Sensor ...
? 2:53
https://www.youtube.com/watch?v=RzpprWzYEJY
Dec 17, 2014 - Uploaded by Bernina Boys
What to do when your Bernina 830 or 880 bobbin shows a question mark. It also shows you how to ...
[PDF]Dear BERNINA 830 customer, Congratulation
Jan 01, 2016 | Bernina Sewing Machines
Bernina 1000 Special sewing machine won't pick up bobbin thread
try tuning the bobbin the opposite way in the bobbin case.
Apr 03, 2013 | Sewing Machines
I have a faithful 730 Bernina and currently the bobbin thread keeps breaking. Please advise what may be causing this. Thanking you.
Bobbin thread breaks
1. There is a right way & wrong way to insert the bobbin in the case --when you insert the bobbin in if it doesn't stitch correctly turn the bobbin over see if that helps or bobbin case is not inserted correctly
2. Lint has collected in the bobbin holder
3. The bobbin is damaged & doesn't turn smoothly
4. Lower thread tension is two tight
here's a free manual
http://www.bernina.com/getdoc/48e8d09f-98f7-40ab-8663-a23663df4fae/Bernette_715_730_740E_manual
Sep 17, 2012 | Bernina Sewing Machines
Thread jams starting with 1st stitch on Bernina 160
since a needle broke, & a new needle was put in, was the needle inserted correctly, normally flat side to the back of the machine, & pushed all the way into the needle holder
rethread the machine top & bobbin
make sure the bobbin is inserted correctly into the bobbin case.
if none of these suggestions help, then it's possible that when the needle broke it could have caused the machine to jump time & would have to be checked at a sewing machine shop
May 21, 2012 | Bernina Virtuosa 160
I used the embroidery bobbin sewing and now it's not functioning
I do not believe the bobbin thread is the reason for the problem.
Refer to your manual for maintenance, especially cleaning the bobbin area.
When you replace the bobbin case be sure the needle is in it's highest position and this will also set the shuttle in position to properly accept the case.
If the problem continues, then machine will need to go into the shop. If the timing needs to be adjusted, this is best done by a Bernina tech.
Apr 28, 2010 | Sewing Machines
Help I need some bobbin cases
If you need bobbin cases you must buy the Bernina bobbin case, if you need bobbins you can buy them anywhere even on ebay
Feb 26, 2010 | Bernina Activa 140
Using a bernina gold latch bobbin case on the Bernina 435 machine
There isn't a Bernina 435. If you are referring to the 430 than the gold latch bobbin case will not work in that machine. If you are talking about the Bernina 450 the gold latch will work in that machine, with or without the embroidery module.
Apr 06, 2009 | Bernina Sewing Machines
Sewing Machines Logo
42 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
