Question about Tomtom ONE XL-S GPS
I have a tom tom xl. while tryin to update the map. my computer froze. it took off half the old map and when i look in the files on it. it says its is gone. so when i try to put the new map on it tells me i have no room on it. how do i master reset it ???? Thanks
  • ashrafhaydar Jan 06, 2009
    that didnt work. think my bro deleated everything off thr tom tom to try put the new maps on it. now it wont recgonise the tom tom and i dont even get the option to click yes to connect it to the comp. everything is gone on it and it wont connect to my comp. any ideas?????
    i have a tom tom xl. were is the reset button. i can not find it..
    President:
  • 846 Answers
How to format the internal memory, then you can just reinstall the software and maps.
  1. Click My Computer and right-click the Removable Disk for your TomTom device and then click Format.
  2. Make sure FAT32 is selected under File system.
  3. Do not tick Quick Format.
  4. Click Start.
  5. Click OK.
    Windows formats your device.
Posted on Jan 05, 2009
  • Quickfx PC Repair Jan 06, 2009
    Try the following:
    • Make sure your device is fully charged before connecting it to the computer.
    • Reset your device.
      To reset your TomTom device, do the following:
    • Check that the battery is charged properly.
      Charge your device for at least 2 hours before trying to turn it on again. Make sure the charging light on your device is on.
    • Remove the SD card
      If your device uses an SD card, remove it.
      Use a straightened paper clip, or something similar, to
      push the reset button for 15 seconds. See the pictures below for where to find the reset button.
    • Turn your device on.
      Press the On/off button for at least 5 seconds.
    • Insert the SD card
      If your device uses an SD card, insert the SD card.
    • First connect your device to the computer and then turn on the device using the On/Off button.
    • Try using a different USB port.
      Connection to your computer may not be successful if you use a USB hub
      or a USB port that is on the keyboard, on the front of a desktop
      computer or a USB port that is not supported by your computer vendor.
I want update my tom tom how could i update
Click here to visit the Tom Tom update page. They allow 1 free map update and afterwards it is paid. You get the map and software from that link. You connect your Tom Tom to your computer in order to update it.
Aug 22, 2011 | Tomtom One XL GPS Receiver
Download map update
the tom tom comes with a usb cable that plugs it to the usb port on the computer. When pluged in to the usb port it should automaticly take you to the tomtom web sight where you can download maps
Jun 12, 2010 | Tomtom ONE XL GPS
Xls 330s tom tom no map
Connect the GPS to the computer. Forget the Tom Tom home for a little while. Use the windows explorer or file manager. Check whether the TomTom is shown as a drive. If yes, Right click on it. Then click properties. Check how much is the used space and how much is the free space. If you see that there is only about 50MB free space, that could be the reason. Tomtom update do not seem to overwrite the map file. Now check the properties of the new map file. It may be approximately around 1.3 GB to 1.5 GB. Since I do not have a Europe map I do not have the correct size. If the new map size is anything bigger than the available space on your GPS drive, then the update will not complete and crash. Solution. Copy the existing map (North American map has a name something like USA_Canada_and_Mexico_P) folder to your computer. Once you have a secure copy, delete this map folder from your GPS drive. You will now see that you have approximately 1.7GB of free space. copy the map folder from your CD to your GPS drive. Once copying is complete, safely remove the GPS from USB port. Restart and try it out on a known route to check efficiency.
Apr 15, 2010 | Tomtom XL 330 Car GPS Receiver
Up date maps
To update maps you should run Tom Tom home on your computer and then connect the GPS
It will then ask you if you want to connect to the computer and you would tell your GPS yes.
Tom Tom home will once it finds your GPS then proceed to do any minor updates.
If your map is out of date it will offer you the option of purchasing a newer version.
don't be tempted to look for free / pirate maps !
These can cause problems in starting up your GPS (believe me)
Tom Tom map prices are not too bad and compared to many GPS are quite easy to install using Tom Tom home.
If you don't have Tom Tom home the latest version can be found here.
Sep 02, 2009 | Tomtom One XL GPS Receiver
Tomtom xl says no maps available after installing new update from tomtom home
when your registered it with tom tom they take note of your maps
check your online tom tom account and it should let you re-download your maps.
I you backed it up to your computer you can also restore the maps from there with the tomtom home software
Aug 22, 2009 | Tomtom One XL GPS Receiver
Downloading
Move old map from device to computer, then update with new map...
Mar 29, 2009 | Tomtom One XL GPS Receiver
Help, this is very frustrating! All I want to do is update my tomtom One XL with the latest maps. my computer has had a virus, and I just got it out of the shop.
Make sure you have Tom Tom Home:
http://www.tomtom.com/services/service.php?id=16&tab=87
Download and install. Use Tom Tom Home to find free maps and additional maps you can purchase.
Peter
Jan 29, 2009 | Tomtom One XL GPS Receiver
I need to update my tomtom 1xl maps. It is one year old.
if this is very new construction i would say with in the last couple of ears it will not be updated on the newest map for awhile and maybe longer if you are in a rural area
Dec 24, 2008 | Tomtom One XL GPS Receiver
One xl europe software
Software updates are free, maps are not.
To download software updates, you need to download Tomtom Home, and connect tomtom to a computer.
Download Tomtom home here: TomTom, portable GPS car navigation systems
To get maps click here.
Oct 02, 2008 | Tomtom ONE GPS Receiver
Tom tom GPS Map Updates
you go to tomtom.com and make sure you have website open before you connect your tomtom to the computer.
May 22, 2008 | Tomtom GO 910 GPS Receiver
Tomtom ONE XL-S GPS Logo
1,258 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Will Halftowaite
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
