Question about Scotch Thermal Document And Photo Laminator Tl901
My gbc model 4250 laminator will not warm up it turns on and thats it
My gbc heatseal laminator is rolling back and foward continuosly .even when reverse botton is not press. why
Can be for two reasons.
The synchronous motor in it is faulty, or there is something wrapped against the roller and it is lifting the spring or throwing it into reverse.
Contact GBC direct
GBC heatseal laminator Google Search
Sep 01, 2017 | Gbc Office Equipment & Supplies
Why is my GBC Ultima laminator beeping?
It will beep when you turn it on to acknowledge power. It will also beep when it reaches ready condition. Your laminator has safety switches for the lower feed tray and upper heat shield. Any time the upper shield is lifted the power is shut off. When you lower it down the power is turned back on, causing a beep. The same is true for the lower feed table. When it is removed and then re installed the machine beeps. These are safety features so that the laminator doesn't turn on when you are reloading it or unjamming it. Check that the safety switches are fully engaged if you get unnecessary beeping.
Oct 25, 2016 | Gbc Office Equipment & Supplies
My GBC ultima 65 laminator is making loud noises. How do i fix this?
You probably have 1 or more heat roller bearings seizing up. This is a common problem. There are 2 on the left and 2 on the right. I would recommend changing both of the bearings on the side that is noisy. They can eventually stop turning and then your laminator will probably stop also.
Aug 10, 2015 | Gbc Office Equipment & Supplies
GBC Ultima 65 laminator rolls very fast on lowest speed setting and doesn't roll at all on fastest speed setting. Can this be fixed?
sounds like the yellow and the orange wire connectors on the main board from the transformer are reversed. If not, then your main board needs replaced. I have them available, 405-324-6092, Scott,
Westco Laminating service
Feb 24, 2015 | Gbc HeatSeal Ultima 65 Roll Laminator
How do I remove the back of my GBC laminator to remove paper that is stuck inside the unit?
First, you must take out 4 screws out of the cover on each side of the laminator , then you will see the screws that hold the back panel onto the laminator. West Laminating secs 405-324-6092
Oct 14, 2014 | Gbc HeatSeal Ultima 65 Laminating System
Laminate did not come out it just went back inside on roller
warm the machine back up, get the glue sticky again, then work it off, either by going in forward or reverse, whichever works best for the given situation. Don't use anything sharp as the rollers damage easily....very expensive
Sep 09, 2014 | Gbc Heat Seal Ultima 65 Laminator 1710740
I have a card that I cannot get out of the laminator. It is wound tight around the insice roll. I need a repair man to come here and take the machine apart to remove the wound up card and film. It is an...
Here we do not provide repair mans.We help you to sort out your problems.To get the repair man you need to contact the nearest service centre.
http://images.mybinding.com/www.mybinding.com/GBC_4250_Manual.pdf
This is the manual for your GBC heat rollers 4250.Try as per the procedure given in this manual to clear it.If not possible contact the nearest service centre
Thank you
Oct 21, 2010 | Office Equipment & Supplies
Scotch Thermal Document And Photo Laminator Tl901 Logo
62 people viewed this question
Top Scotch Office Equipment & Supplies Experts
ka4iup
ka4iup
Andrew Taylor
Andrew Taylor
Mark Andrews
Mark Andrews
Level 1 Expert
Are you a Scotch Office Equipment and Supply Expert? Answer questions, earn points and help others
