Question about Dryers
I have a kenmore dryer model number 86810100, but can't seem to find any information on it. It is not heating up.
    Top Expert:
  • Dryers Master
  • 9,472 Answers
Take a look at this video.
Posted on Nov 10, 2012
dididsaythat
  • 291 Answers
SOURCE: kenmore heavy duty clothes dryer will not heat
You really need a volt / ohm meter to check for Continuity & Volts Its well worth the investment... $15.00 bucks give or take a few I would check to see if you have 220v to back of dryer where the cord mounts to dryer, If dryer is getting only 1 leg 110 volts instead of the 220 will it not heat. Check themostates & heater for Continuity... Most models, Now have a.. Hi-limit fuses that need to be checked for Continuity
Posted on Oct 08, 2007
SOURCE: Need schematic for Sears Kenmore Dryer model number 11063032102
Thanks, I will try that.
Posted on Mar 28, 2008
zeusfaber
  • 247 Answers
SOURCE: Kenmore clothes dryer model number
My instinct on this one is to look for a thermal cutout and to try to reset it.
Not familiar with the layout of the Kenmore 110's (they're not marketed in this part of the world), but a good place to start is probably inside the top of the machine.
Before fiddling, turn the power off and unplug the machine.
Look for a metal duct leading into the drum housing. This will probably have the blower mounted at one end, then the element embedded in it, then, before it leads into the drum housing, a collection of thermostats and safety cutouts (usually one or two of each) mounted on the outside of it.
Safety cutouts and thermostats are likely to look something like one of the pictures at http://www.tdspares.co.uk/products.asp?cat=68
Start by looking for cutouts with reset buttons - press the button on any you find and see if this fixes the problem. It's a good sign you've found the right one if it clicks when pressed.
If that doesn't work, use a multimeter to test across the contacts of each thermostat and cutout in turn. They should all have a very low resistance. reset or replace any that don't.
Once you've got the machine working again, you need to find out what made things trip and eliminate the underlying problem. This is usually a matter of cleaning all the accumulated lint out the machine.
Good luck.
A.
Posted on Sep 13, 2008
  • 1122 Answers
REMOVE THE BACK AND CHECK THE HEATER FUSE AND THE HEATING ELEMENT-MIKE
Posted on Feb 26, 2009
jumptrout51
  • 3361 Answers
SOURCE: KENMORE DRYER MODEL NUMBER 66912690 WONT HEAT
Check the voltage at the terminal block where the cord hooks up for 220 volts.
Remove the rear panel and check the thermal fuse located on the upper portion of the heat canister.
Check the Hi-limit thermostat on the bottom portion of the heat canister.
Check all the wires for a burned or loose wire.
Check continuity of the heating element.
Posted on Mar 08, 2009
Kenmore elite 110.7703 no heat
Hi there
From the model number it seems this machine was made by Whirlpool for Kenmore. The thermal fuse is on front bottom near the blower wheel.
a) Pop open the front panel.
b) Then remove front door panel by removing the two secrews
c) Remember to disengage the door switch wiring
d) you will see the thermal fuse near the blower compartment.
e) If thermal fuse is burned out then it should not have continuity on OHMS scale on a multimeter.
Dec 07, 2013 | Kenmore Dryers
Kenmore electric dryer won't dry clothes. The
What is the model number of your unit?
Nov 17, 2012 | Dryers
My Kenmore dryer does not get hot enough to dry a load
If your dryer IS still heating, but your clothes still won't dry, you may want to check the dryer interior cabinet and/or the entire exhaust duct run to ensure you have no kinks or clogs anywhere. The following link explains many of the problems that can cause poor drying efficiency and longer dry times:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
Before assuming you have a problem with the appliance, check your installation to ensure you are providing the dryer with proper exhaust and air flow. A dryer in a clogged state or having improper air flow will not dry efficiently and will cause the heating circuits to actually overheat. Eventually, this can lead to component failures and is the source of fire hazards.
If you have any questions, please post back with your complete MODEL NUMBER (located on a nameplate along the door opening) and let me know. I hope you find this information helpful.
May 31, 2010 | Kenmore 62802 Electric Dryer
CLOTHES DRYER HEATING ELEMENT
The heating element is SUPPOSED to cycle on and off. That is normal. There is an Internal Bias Thermostat and a Hi-Limit Thermostat that help regulate the internal operating temperature of the dryer. However, if you are experiencing longer dry times, or poor drying efficiency, the following link can give you some things to check before you assume there is a malfunction with your dryer:
The number one cause of dryer heat related problems is poor exhaust ventilation. If not vented properly, a dryer will not dry efficiently, will actually take longer than required to dry, and will cause the heating circuits to overheat to the point of failure. The dryer will actually seem hotter than usual in many cases and the heating element will appear to glow brighter as the heating circuits begin to overheat. This is also the source of many fire hazards if not resolved. Read through the link provided and review some of the potential causes.
If you have any questions, please post back with your MODEL NUMBER and let me know. I hope you find this information is helpful.
NOTE: If you thoroughly check everything and still have problems let me know. The problem could be related to a thermostat beginning to fail.
Mar 15, 2010 | Kenmore 64742 Electric Dryer
How to take off heating element. The fuses seems
do you have a meter?pull one of the wires off the heater and read it out,you could have a bad thermal fuse,a,bad high limit t stat or a couple of other problems,check to make sure you have 240 volts coming in at the back of dryer at the block where the cord connects to dryer,there are 2 house fuses that can go to dryer and one could be bad,next time send model number,if the filter is on top then go to the back of dryer,if the filter is inside,take off the bottom panel and check out the thermal fuse there,it's located on the blower wheel housing it's either 3392519 or 3390719 depending on model number,if you need more help let me know,good luck
Feb 18, 2010 | Kenmore Dryers
My kenmore dryer stopped heating.
yes the price of fixing it is less then a new unit most of the time.
you might need new heating element or cut-off switch only.
Jan 19, 2010 | Kenmore 94702 Front Load Stacked Washer /...
Dryer won't heat
Your issue is;
"I have an older model Kenmore dryer that won't heat up. Need to know what could be the problem."
Based on the information provided above, I am unable to access my database to provide you with exacting information. A valid model number was not provided. However, I have provided some common solutions to help guide you in your search.
This information is for an electric, generic model dryer only!
My Solution is:
Following this link, http://www.repairclinic.com/SmartSearch/SmartSearch.aspx, provides valuable D.I.Y. safety information on the make and model number of your appliance. In order to access your product information, you will need to enter the model number stamped on the manufacturers product information data tag, located on the unit, and not in the User’s Manual.
Note: A volt-ohm meter is beneficial in performing electrical tests.
This link provides diassembly procedures for a similar model.
http://www.repairclinic.com/0100_15.asp
Temperature Switch; make sure a positive heat selection has been made, still no heat, then check these:
Power from the house
Heating element
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Please show your appreciation by rating my solution.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jul 24, 2008 | Dryers
Dryers Logo
149 people viewed this question
Top Dryers Experts
