Question about Samsung HTDM150 System
Samsung dvd player ht-dm150 (watching movies)
I can watch part of the dvd on my dvd player, mostly the previews, but once that is over, my dvd player stops, and when I also press the menu button. This happens on numerous dvd movies. When playing the movie, If I put it on pause for a long time, the dvd player would freeze up on me. Could the problem be the optic laser or the tracking system motor?
  • Anonymous Mar 25, 2014
    When I want to watch a movie, the source keep jumping from dvd to aux, to iPod, to am and so on. It use to work fine but then that problem started. I changed the battery in the remote then I watch a movie, it worked fine but then the problem started again
    Scholar:
  • 125 Answers
It is most likely that the laser is not a problem because it can read the first part of the disk. If the laser is defective, it willn ot recognize the disk. The problem is probably the seek mechanism. It can only access the inner tracks but cannot read the tracks further from the center.
Posted on May 24, 2007
My Toshiba SD 1600 dvd player will play previews and allow me to skip to the menu, however the play feature does not seem to be working. It will not allow me to play the movie. I can watch the previews and...
download a player called. VLC i have a thinking that the DVD player application you are using is failing to activate all DVD options for that CD. regards
Jan 23, 2011 | Toshiba Televison & Video
My samsung HT TQ22 dvd player doesn't play dvd's."DISC ERROR" appears each time I try to watch a movie. Any info on how to fix this problem would be greatly appreciated.
Take the top case off the unit, power on, and place a dvd into disc tray. Press the play button and see what happens. It should find the dvd, clamp it in the reader and then spin it at high speed. If it does this and still says disc error, then the read head is bad. If it does not spin at high speed, then the epindle motor is bad. This is the more common error with Samsungs. Repair shop time.
Mar 09, 2010 | Samsung HT-X20 Home Cinema 600W Theater...
Samsung HT Q20 dvd player saying No DISK
1. Try cleaning the drive laser lens with a CD lens cleaner.
2. You need to check servo parts, spindle motor and pick up flat cable.
3. Clean laser lens manually.
Success!
Oct 25, 2009 | Samsung HT-Q20 Theater System
Speakers work only on DVD
You might have connected your TV/Stereo Receiver up to the wrong audio outputs of the DVD player. Make sure you are coming out of the FRONT left/right audio outputs and not the CENTER?REAR left/right audio outputs.
Mar 13, 2009 | Panasonic SB-TP55 System
Samsung ht-tx72 Issue
GEnerally speaking that behavior suggests that the video signal is being lost for a second and returns. The easiest thing to try is to replace the connection cable (video). A bad connection there could cause this although moving the cable should make this happen at will. Check the DVd player on another TV if possible. If hte player is the cause, the "new" TV should show the same symptoms.
The only other possibility is that the DVD player is having a problem generating the video signal. This could be because the disc is not being read correctly (I would expect the sound to be effected as well) or the video processing section of hte DVD player is defective. This wil be a bit more difficult to find.
Can you try the cable and other TV and update this?
Thanks,
Dan
Jul 27, 2008 | Samsung 1200W 5.1-Ch. XM-Ready Home...
Cant use dvd player, the word lock keeps coming up, dont know how to remove it, the model is a samsung digital home theater system HT-DM150
i have a samsung dvd theater system ht dm150 it will sometimes read the dvds dut majority of the time it wont read any dvd i even used a cd cleaner on it. 80% of the time it will play music cds.
Apr 21, 2008 | Televison & Video
Samsung ht q100
No it does not. It will upscale regular DVD's to HD resolution, but that's an electronic trick. You'll need to buy a BluRay player to watch high definition discs.
The HD-DVD standard has been abandoned by Toshiba, so the Sony players are the one's to look for.
Dec 08, 2007 | Samsung HT-Q100 System
Dvd multiregion unlock code
use the procedure for unlocking the Samsung HT-DM150 .
Oct 28, 2007 | Audio Players & Recorders
DVD Player Problems
Me three, same thing, reads 'no disc' or just won't play it. I have found that it happens more frequently on rental DVD's and that running a cleaner cd through several times helps but eventually that will even stop working. No idea what the problem is
Sep 30, 2007 | JVC TH-C5 System
Samsung HTDM150 System Logo
445 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
