Question about Celestron CG-5 Mount Telescope
Cg5 mount not slew manually - Celestron CG-5 Mount Telescope
2 Suggested Answers
SOURCE: CG5 is brand new-not 30days old yet. Mount slews
You should return the scope under warranty-- however a bad power supply-- and or a bad hand controller cable can cause these symptoms called a "runaway slew".
Get a separate 12 volt power supply and the proper cigarette lighter style power plug.
Posted on Feb 14, 2011
Cg5 gt dec motor broken
Can you hear the motor running even though the axis does not move? If it is, then all that is possibly needed is to realign the motor on its mounting with the driven gear of the axis. This situation is not uncommon in the CG5. Here is a site with a lot of links and information
http://www.astronomyboy.com/cg5/
If the motor is not running at all, it may be the motor has failed, or more likely, the motor controller circuit board has failed. There is a lot of stuff on the Net about that and it seems spare parts are getting hard to find. In that case you may have to return it to a Celestron dealer.
The problem has also arisen before here on Fixya, so you could examine those posts as well
http://www.fixya.com/support/t4329122-celestron_advanced_gt_declination_motor
Dec 31, 2011 | Celestron CG-5 Mount Telescope
Hello I need to know if my AR-6 refractor for my LXD55 mount is a direct replacement for mounting on an LDX75 mount and tripod? Also would a CG-5 GEM hold an AR-6?
No-- you need a CG6 to accurately hold that 6 inch refractor.
Recommend that you look at the Celestron 6 inch SCT-- or the Astro-Tech RC6, which can be mounted on that CG5.
www.telescopeman.org
www.telescopeman.us
www.telescopeman.info
Aug 17, 2011 | Meade LXD75AR-6 Telescope
Trying to overhaul/rebuild a Hardin STAR HOC 8-4 7.9" f/4 Newtonian reflector with equitorial mount. Has been sitting out in the desert for who knows how long and is covered with fine desert...
You will not find any instructions for this particular mount and tube.
However here is a video on Telescope mirror cleaning-- and a web site on disassembling an EQ5 mount which is similar to your moun.
http://www.youtube.com/watch?v=9Y8xFnXFVGQ
Jun 10, 2011 | Hardin Optical STAR HOC 8 (160 x 200mm)...
Meade LX90 GPS - When the telescope slews to a new location (tour or manual slew), the telescope then slews up a few degrees. I have to manually slew the scope down several degrees and hope I've...
Calibrate motors and then TRAIN the drives-- this sets the gear backlash.
You should Calibrate motors every time you take it outside and Train drives at least once every year. The symptom you describe is called "rubberbanding".
Train the drives.
Mar 03, 2011 | Meade 8" LX90 Schmidt-Cassegrain Telescope...
CG5 is brand new-not 30days old yet. Mount slews before a star is selected for alignment and continues to slew about the RA until power is cut. What is wrong. Tried 2 different power sources and factory...
Feb 12, 2011 | Celestron CG-5 Mount Telescope
CG5 mount- no power either with Celestron battery or with AC adapter. Indicator light not on either.
This is known issue with these mounts. The little on-off power switch breaks- you will either need to send it back to Celestron or open it up and have someone install a new switch.
Most of us never use the switch-- we just plug--- and unplug the power cable.
Sep 16, 2010 | Celestron CG-5 Mount Telescope
Polar alignment with cg5 mount in the tropics
Wait what? You just have to remove the front bracket for the alt screw and you can go lower than 30 degrees.
Feb 21, 2010 | Celestron CG-5 Mount Telescope
RA will not track on Orion Atlas mount
Are you sure it's not actually working (tracking)-- can you hear the motor running?
I would contact Orion and make sure you have a manual for the hand-controller-- it may have a setting that turns tracking on or off.
http://www.telescope.com/control/main/
Nov 14, 2008 | Orion Atlas Mount GoTo Upgrade Kit...
Celestron CG-5 Mount Telescope Logo
59 people viewed this question
Top Celestron Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Vernon Taylor
Lawrence Oravetz
Are you a Celestron Optic Expert? Answer questions, earn points and help others
