It says troubleshooting and routine maintanance and its not taking the paper aswell
    Scholar:
  • 76 Answers
If this is your printer malfunctioning, most have a toolbox that will allow you to troubleshoot any problems.
If your printer is suddenly not taking paper correctly I would check for any obstructions within the printer such as a torn piece of paper, ink cartridge not correctly inserted etc.
Let me know if this helps, if not give me a bit more information on what kind or printer, computer etc. and I'll do my best to help you.
Posted on Jan 06, 2009
Paper jam c
Unable to print troubleshooting and routine maintanance chapter in user's guide
Mar 23, 2013 | Ricoh Aficio SP-C210SF Printer
I have a Brother all-in-one printer MFC 420CN and it displays unable to clean...see troubleshooting and routine maintenance in user's guide. Itried turning off and back on but it does not reset...
Try this and see if it works... It works for my Brother MFC-6490CW and I am sure the same process probably will apply to your machine. If it doesn't contact customer service and let them know you need to know how to Power Purge your machine. Good Luck!
Hold down the menu key. While still holding the menu key, unplug the machine and plug it back in. Do not let go of the key until the machine reboots and the screen says "maintenence". Hit the following keys: 7, 6, 4,black start. The machine will then go into "power purge" or deep clean mode for about 5-7 minutes. When complete hit: 99 to get out of maintanence and reboot. Be sure to have extra ink cartidges on hand as it does use up a lot of ink but this process works the best every time when the printer wont print
Jun 04, 2011 | Brother MFC 420CN All-In-One InkJet...
TROUBLE SHOOTING AND ROUTINE MAINTENANCE
Click here to visit Brother Official Support & Download page for DCP-7030. User Guide, Troubleshooting information etc are available. You can also search for specific issues from the troubleshooting section. The most important point as far as routine mainenance is concerned is I think keeping the printer clean, using good quality paper and genuine supplies/toner.
Let me know if any further clarification/ assistance is required.
Hope this helps! Good Luck!
CreativeTECH
Jan 10, 2011 | Brother DCP-7030 Digital All-in-One Laser...
My printer is asking me to refer to troubleshooting and the routine maintanence chapter in users manuel for - print unable 36 Does anyone know how I go about fixing this? Nikki
Check for a paper jam. I just encountered this same error on my Brother MFC-290C, and that was the cause. I had to unplug the printer's power cable to clear the error message.
Sep 02, 2010 | Brother Office Equipment & Supplies
Clean unabale 46 routine maintanance
You could check for a paper Jam or foreign oblect in the machine, under the top cover and in the back cover.
If there isnt a Jam in the machine it means there is a mechanical problem. There is a sponge in this machine and once it is full it wont be able to absorbe any more ink from the cleanings. You will need to bring it in for services, they would replace the sponge and reset the cleaning counter.
Check the brother website to find a service center in youre area.
Apr 07, 2010 | Brother DCP 165C Compact Color Inkjet...
It will not clean causing not to print the message say see troubleshooting routine in your user guild
If there is no jam it is generally a mechanical issue such as...
1. The planetary arm assembly not engaged correctly
2. Ink cartridge/purge switch harness not connected correctly
3. Purge cam switch broken
4. Gear(s) on maintenance unit broken
5. Paper feed motor broken
6. Main PCB defective
I find that if there was a paper jam, and the user pulled the paper out, option 4 is most likely. It is the smallest of cracks but ruins everything!
You will need to take it to your local Brother ASC - find one here.
Thank you for using FixYa! - Don't forget to rate our service.
Feb 01, 2010 | Brother MFC-5840CN All-In-One InkJet...
Had a paper jam, took the paper out, now it will not let me print It Says ''unable to print, see troubleshooting and routine maintenance chapter in users guide. I don't have the guide. Can you tell me what...
its possible your encoder strip came off of the printhead assembly.
you will need to check by taking off the scanner assembly, then the upper cover.
look at the encoder strip and see if its in the groove of the printhead.
May 07, 2009 | Brother MFC-3240C All-In-One InkJet...
Ink Nozzles are plugged
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Jan 28, 2009 | 2003 Cannondale S 440
Fuser roll has big dents in it, says unable to print
Dear Computer_tea,
If the fuser is damaged as you say, you will need to replace it. The unit will not print correctly and the image quality will be very poor.
The fuser unit is part of the maintenance kit, and unless you replace the maintenance kit, it will still say the same. You will need to replace the kit and now for the bad news.
The maintenance kit is going to cost you over $500.
You will need to consider very carefully befor you go out to buy a kit as these printers can be purchased for around $900 new.
Gremlin11
Dec 03, 2008 | Brother MFC-9420CN All-In-One Laser...
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
