Question about Parsons QuickVerse 7 Essentials (fe11044) for PC
During the install I get the message: "The STEP language module could not load the file C:Windows\language\latin.lng for the language English. The program cannot continue. Please reinstall the program to correct the problem." This problem consists on both my laptop and desktop. One has Windows XP the other Vista. Can you help.
  • Jarish Castañeda
    Jarish Castañeda May 11, 2010
    It may be dirty. Try to clean the disc with smooth cloth. Reinstall it again. If still persists, it is on your OS copy problem.
Noticed in the install.log the file ILI.exe was originally loaded during install, but not on my computer. Looked on another computer I had and the file was there. It normally resides in C:\Windows\System32 but will work if you put it in the Qvlib folder or where ever you have Quickverse Library.
I also needed another fix in the registry. I did a search on qvlib which is my folder name where Quickverse Library resides. In
one instance the data pointed to a wrong location so I corrected it and got my Quickverse Library working again.
How the registry got changed is anyones guess, but it wasn't changed by me. Hope this helps some who obviously have the same problem. It really is a great piece of software that I have been using for years. Best
Posted on Feb 20, 2012
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 7 Answers
This error message also appears when trying to install Navpress' WORDSearch 5.0. Since my WORDSearch 5.0 application was running fine for more than 10 years, and it is no longer supported by its manufacturer, it is my humble opinion that Microsoft Updates has downloaded and installed "something" that has rendered an otherwise productive application... at this point useless. I am currently striving to understand the dynamic of why this occurred and/or how it can be "fixed". I will be intouch relative to "our" chanllenge. Lastly, I previously used a "CD/DVD electric-run cleaning machine" to no avail. Typically these kins of errors are due to "CALLS" within programs within the application that either point to a non-existant or corrupted location, or as I believe in this case since it now obvious to me that this is a global issue, somewhere someplace some of our DLLs or EXEs have been modified via Microsoft Updates.
Posted on Dec 19, 2009
Vmfusion emulation of windows 7 language change
How to change the Windows 7 Display Language:
1. Go to Start -> Control Panel -> Clock, Language, and Region / Change the display language
2. Switch the display language in the Choose a display language dropdown menu.
3. Click OK
4. Log off for the changes to take effect (This will affect only the user profile under which you are currently logged on).
May 05, 2012 | Apple iMac Computers & Internet
Quickverse library
Feb 19, 2012 | Parsons QuickVerse 7 Essentials (fe11044)...
My netbook is in a differant launge
Changing Computer Language to English in Windows XP If you bought your computer with Windows XP in some other language set as default, you need not worry. You can always change it using the Control Panel. English, along with several widely used languages, is present in almost all Windows XP installations. You only need to set it up so that your copy of Windows XP works with English.
The following steps explain how to change computer language to English in Windows XP.
1. Open Control Panel and double click on the Regional and Language Options icon.
2. In the first tab, Regional Options, select English (US), English (UK), or any other English (there are many versions of English pre-loaded) as per your wish. The option is available in the first drop down list under Standards and Formats (see Fig 1). You may also click the Customize button next to the drop down to customize the format of date, time, currency etc.
3. Click on the next tab, Languages and then click the button labeled Details. In the Text Services and Input Languages dialog box, you can see all the installed languages. Select English in the list of available languages under Default Language Settings (Fig 2).
4. To create a keyboard shortcut for switching among installed languages, use the Key Settings under Preferences (Fig 3). Please note that you can also use the Language bar to switch among languages. Click OK to close the dialog box.
5. To set English as the default language for the particular user account, click on the Advanced tab of Regional and Language Options dialog box. Make sure English is being displayed in the drop down box and check the last option in the dialog box (See Fig 4).
6. Click OK to close the dialog box and logoff for the settings to take effect.
Though this is the most common method used to change the computer language to English in Windows XP, it only changes the GUI and sometimes creates problems with few applications such as Internet Explorer and Outlook Express. If you are facing such problems, you can download MUI patches from MS download center.
NOTE: The above method is often considered as a temporary solution when you have to use different languages. To change the computer language to English in Windows XP so that it has a system wide affect, it is recommended that you perform a fresh install of Windows XP and select English when prompted for language during installation. Later, you may install other languages as required.
Image References3b24b8d07e02676bd16c4088ded3a97bb2eff7d1_small.jpg78a625bbb1315370e604f68633c3d5fd7d474297_small.jpg604b8abac5682117ebde3c5fcd7495cf3dc5d4b1_small.jpg83bab98caffbca82c86f3d54a6e823fe5ed527e8_small.jpg
Read more: http://www.brighthub.com/computing/windows-platform/articles/46362.aspx#ixzz1BFXeeYOl
Jan 17, 2011 | CTX EzBook V92C266 Notebook
Can you give me a baby's names that start with FEL
For boys;
Fela lucky, happy, successful ... largely used in the Czech language and ... variant of Felix ...
Felan descendent of Fallamhan; ...The origin of Felan is the Celtic language ... variant form of Fallon ...
Felder person living by a clearing ... used mostly in English and it is of ... not commonly used as a baby boy name ...
Felex lucky, happy, successful ... mainly used in Spanish and its language ... variation of Felix ...
Felic lucky, happy, successful ... of Latin origin and it is used mainly in ... form of Felix ...
Felice lucky, happy, successful ... used predominantly in the Italian ... variant of Felix ...
Felician lucky, happy, successful ... language of origin is Latin and it is used ... variant of Felicianus ...
Feliciano lucky, happy, successful ... used mostly in the Italian, ... Its language of origin is Latin ...
Felicianus lucky, happy, successful ... largely used in the German language ... an unusual baby name for boys ...
Felicien lucky, happy, successful ... used mostly in French and its ... variant form of Felicianus ...
Felicjan lucky, happy, successful ... used mostly in Polish and it is of ... variation of Felicianus ...
Feliks lucky, happy, successful ... largely used in Polish, Russian, and ... variation of Felix ...
Felim beauty, forever good ...The origin of Felim is the Celtic language ... form of Phelim ...
Felio God has healed ... used mostly in Spanish and it is of ... form of Raphael ... not in the top 1000 names ...
Felip lover of horses, friend ... of Old Greek origin and it is used ... form of Philip ...
Felipe 563 lover of horses, friend ... mainly used in Spanish and it is of Old ... form of Philip ... a classic favorite ...
Felipino lover of horses, friend ... of Old Greek origin and it is used ... variant form of Philip ...
Felipo lover of horses, friend ... used mostly in the Spanish language and ... variation of Philip ...
Feliu lucky, happy, successful ... origin is Latin, and its use, Catalan ... form of Felix ...
Felix 339 lucky, happy, successful ... used predominantly in the Dutch, ... first name is derived from a Roman nickname ...
Felixiano lucky, happy, successful ... of Latin origin and it is used ... variant of Felix ...
Feliz lucky, happy, successful ...The origin of Feliz is Latin ... variant of Felix ...
Felizano lucky, happy, successful ... a Spanish name of Latin origin ... form of Felix ... rare as a baby boy name ...
Felizian lucky, happy, successful ... of Latin origin and it is used mainly ... form of Felicianus ...
Feliziano lucky, happy, successful ... language of origin is Latin and it is used ... form of Felix ...
Fell lives by a crag ... origin is English ... not popular as a baby boy name ... not in the top 1000 names ...
Fellim beauty, forever good ... of Celtic origin ... variant form of Phelim ... uncommon as a baby boy name ...
Felton field settlement ... of Old English origin and it is used ... unusual as a baby name for boys ...
For Girls;
Fela lucky, happy, successful ... of Latin origin and it is used mainly in ... form of Felicia ...
Felda from the field ... derived from Germanic origins ... not often used as a baby girl name ...
Felecia lucky, happy, successful; ... used predominantly in English and it ... variant of Felicia ...
Feleicia lucky, happy, successful ... largely used in the English and ... variation of Felicia ...
Felia daughter; help, profit; ... used mostly in the English language ... variant form of Filia ...
Felica lucky, happy, successful ... used predominantly in English and it is ... variant form of Felicia ...
Felice lucky, happy, successful ... of Latin origin ... used mainly in English and French ... form of Felicia ...
Felicia lucky, happy, successful; ... has its origins in the Latin language ... form of Felicity ...
Feliciana lucky, happy, successful; ... language of origin is Latin ... predominantly used in Italian and Spanish ...
Felicidad lucky, happy, successful; ... mainly used in the Spanish language ... variation of Felicia ...
Felicidade good luck, good fortune, ... a Portuguese name of Latin origin ... variant form of Felicity ...
Felicie lucky, happy, successful ... largely used in French and German, and ... variant form of Felicia ...
Felicienne lucky, happy, successful ... language of origin is Latin and it is ... form of Feliciana ...
Feliciona good luck, good fortune, ... of Latin origin ... variant of Felicity ... seldom used as a baby name for ...
Felicita lucky, happy, successful; ... origin is Latin, and its use, Italian ... variant of Felicia ...
Felicitas lucky, happy, successful; ... used chiefly in the English, German, ... variation of Felicia ...
Felicit?s good luck, good fortune, ... of Latin origin and it is used mainly in the ... variant form of Felicity ...
Felicite lucky, happy, successful ... a French name of Latin origin ... variant of Felicia ...
Felicitie good luck, good fortune, ... of Latin origin ... variant form of Felicity ... not commonly used as a baby girl ...
Felicity 782 good luck, good fortune, ... language of origin is Latin and it is ... saw a revival in the late 20th century, ...
Felicja lucky, happy, successful ... language of origin is Latin and it is ... variant of Felicia ...
Felicyta good luck, good fortune, ... used chiefly in the Polish language ... variant of Felicity ...
Feliece lucky, happy, successful ... largely used in the Dutch language and ... variant of Felicia ...
Felina lucky; cat-like ... of Latin origin, and it is used mainly ... name could be derived from the Latin felinus ...
Feline lucky; cat-like ... used predominantly in the German ... variation of Felina ...
Felipa lover of horses, friend ... has its origins in the Old Greek language ... form of Philippa ...
Felis lucky, happy, successful ...The origin of Felis is the Latin language ... variant form of Felicia ...
Felisa lucky, happy, successful ... of Latin origin and it is used largely ... variation of Felicia ...
Felise lucky, happy, successful; ... primarily used in French and its ... variation of Felicia ...
Felisha lucky, happy, successful; ... used mostly in the English language ... variant form of Felicia ...
Feliss lucky, happy, successful ... derived from Latin origins ... variant form of Felicia ...
Felita lucky, happy, successful; ... largely used in the English language ... form of Felicia ...
Felixa lucky, happy, successful ... mainly used in the Spanish language and ... variation of Felicia ...
Feliz lucky, happy, successful ... language of origin is Latin and it is ... form of Felicia ...
Feliza good luck, good fortune, ... of Latin origin ... variant of Felicity ... not popular as a baby name for girls ...
Felizia lucky, happy, successful ... primarily used in German and its ... variant form of Felicia ...
Felizitas good luck, good fortune, ... language of origin is Latin and it is used ... variation of Felicity ...
Fel?cita good luck, good fortune, ... of Latin origin and it is predominantly used ... variant form of Felicity ...
Fel?cia lucky, happy, successful ... its origins in the Latin language and it is ... variant form of Felicia ...
Felka lucky, happy, successful ... has its origins in the Latin language and ... variant of Felicia ...
Jan 07, 2011 | ArcMedia ABC of Baby Names
How we can change the default language in windows XP
support.microsoft.com/kb/177561
windows.microsoft.com/.../windows.../Change-the-display-language - United States -
There you go those links above will tell you/show you how to do it.
Jun 25, 2010 | Acer Aspire 3610 Notebook
Rosetta stone problem installing language discs
I just had the same problem. Rosetta Stone TOTALe French Level 1. I just ran it in Windows XP Service Pack 2 and it installed right away.
Apr 07, 2010 | Rosetta Stone Spanish (Latin American) -...
Install problem
It sounds like the Windows installations are missing the language-library file LATIN.LNG that the STEP module is trying to load in order to work.
First. see IF the file is on your HDD via DOS commands:
From START search-bar, type CMD then click the CMD icon.
At the command prompt, enter
CD\
dir/a/s/b'find/i "latin.lng"
sit back... this takes awhile....
You can also redirect output to a text-file with >X:\phoundit.txt
X:\ being replaced with the drive-letter of your flash-drive.
If not found on HDD, check your Windows OEM install disks 2C if the file exists there, maybe stored in a cabinet file named Languages or similar.
If all else fails, the Microsoft website may have a download version of the missing file.
Nov 20, 2017 | Parsons QuickVerse 7 Essentials (fe11044)...
Searching drivers for sharp AR-5316 for windows Vista platform.
are you sure it is for a Vista or is it trying to load to a Windows based OS???
try this site
http://promosearch.sharpusa.com/search/?sp-q=ar%205316%20drivers&sp-a=sp10009e61&sp-k=
Personally I do not like their site it is not as user friendly as other sites. ( have to do a lot of research to find what you want)
Good luck
Aug 17, 2008 | Sharp AR-5316 Advanced Digital Imager...
Oki C5150 printer menu is part english part spanish. It comes up in english when you click print but all the other pages are in spanish(?)
How To:
Uninstall a Spanish or Portuguese driver and install the English version when Windows XP installs the incorrect language, where either a couple of the tabs are in the wrong language, or everything is incorrect.
Action:
IMPORTANT NOTE: THE PRINTER MUST BE TURNED OFF DURING THIS PROCEDURE OTHERWISE WINDOWS WILL AUTOMATICALLY INSTALL THE SPANISH OR PORTUGUESE DRIVER AGAIN. DO NOT USE PLUG 'N PLAY FOR DRIVER INSTALLATION.
1. Delete the Driver Icon from the Printers and Faxes Window.
IMPORTANT STEP:
2. Reboot the PC
3. Click on File --> Print Server Properties
0.2c6?openelement&fieldelemformat=gif
5. Click on the Drivers Tab.
6. Highlight the driver being deleted (C5200n shown as a reference below), and click on Remove.
0.347e?openelement&fieldelemformat=gif
IMPORTANT STEP:
7. Reboot the PC
8. Go back into the Server Properties Drivers Tab (as shown above), and click on the Add... button.
9. On the first screen click on Next.
10. On the Printer Driver Selection Screen, click on Have Disk.
4.7ce?openelement&fieldelemformat=gif
11. Browse to the location of the English driver that is to be installed and click on OK (Note, the C5200n printer is being used as a reference and the driver being installed is from the CD).
7.3852?openelement&fieldelemformat=gif
12. On the next screen the printer being installed should be highlighted, and click on Next.
9.628?openelement&fieldelemformat=gif
13. The next window Will show the version of the driver being installed, DO NOT click on any of the unchecked boxes and just click on Next.
12.6e6?openelement&fieldelemformat=gif
14. Click Finish on the last window.
15. Finally, turn on the printer. Windows XP will automatically find the printer and install the English version of the driver.
Feb 16, 2008 | OKI C5150n Led Printer
Parsons QuickVerse 7 Essentials (fe11044) for PC Logo
284 people viewed this question
Top Parsons Computers & Internet Experts
Neil
Level 1 Expert
tdk1988
Are you a Parsons Computer and Internet Expert? Answer questions, earn points and help others
