Question about Dell Dimension E310 PC Desktop
F1 floppy diskette faliure
I went into F 2 to check out about floppy diskette faliure i have no floppy dissette on my cumputer so have no ideal what to do now?
to get this off .it has a F 12 but i donot know what that is for either? can you help me on this matter.
Thank You
angeleyes4u5682@cox.net
  • Frank
    Frank May 11, 2010
    start up the macine, press f2 when you see the DOS screen, go to the floppy disk, and diable it or remove it. save and restart the machine.
    did you by this machine or some one gave it to you?
    F12 is network startup. you need a network server to startup the machine.
  • 37 Answers
On booting your PC, hold down F12... this will give you a list of devices from which the PC can boot. Make sure you have them in the correct order.... it will tell you how to move them up and down
1. CD-ROM optical drive
2. HDD hard drive
After this it doesn't matter the order.
If this doesn't sort out the problem, you may have to disable FDD (floppy disk boot)
Posted on Jan 05, 2009
Diskette Failure F1 to continue or F2 to run setup??
Your computer is looking for a Floppy diskette drive. If you entered the BIOS ( setup menu ) and selected default settings to be applied it selects the first boot-table drive as the floppy diskette drive. You have to disable the floppy drive if you don't have one.
Sep 06, 2011 | Dell Dimension 3100 PC Desktop
"Floppy Diskette seek Failure Strike F1 key to
maybe the floppy disk drive is defective or maybe the IDE cable is deffective, or maybe the cable on the floppy drive is not properly inserted , try to replace IDE cable of the floppy drive if still the symptoms happens replace the floppy drive
Jul 20, 2011 | Dell OptiPlex GX520n PC Desktop
Receive message on startup: Floppy Diskette seek failure press F1 to continue
Just remove the diskette located in the floppy disk by pressing the appropriate button next to it. Reboot and check the results.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Dec 05, 2010 | Dell Dimension E510 PC Desktop
Hi, When I try to start my Dimemsion 5150C in Windows XP computer, I received one of the following error messages "Floppy diskette seek failure Strike the F1 key to continue, F2 to run the setup...
The "floppy" disk-drive (3.5-inch diskette) on your computer is broken.
Press F1 to ignore the error, and to boot from your C: drive.
Or, press F2 to enter BIOS SETUP, and then navigate through those "setup" screens to tell the computer to "disable floppy seek", or change the setting from "3.5 1.44Mb drive" to "none".
Or, take the computer to a technician, and buy a replacement disk-drive, and get it installed.
Sep 12, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
I have a dell c521, and I'm getting a diskette 0 seek faliure ?
Restart the computer and when you see the Dell logo.Tap on the F2 key a couple of times. You would enter the system setup.
1. Use your down arrow key on the keyboard and select the option Drives
2. Hit enter to expand the same
3. using the down arrow key again select diskette drive
4. Tap the right arrow key to switch it off.
Save the same changes by tapping on the ESC key on the top left of the keyboard.
PS. In case you have a floppy drive on the computer check if the drive is empty.
Thanks for using Fixya
Proton
Jun 17, 2010 | Dell Dimension C521 PC Desktop
Hi! my computer doesn't start normally it goes back to the same error every time. Errors: Floppy diskette seek failure Drive 3 not found: Parallel ATA,PATA-1 (PRI IDE Slave) Strike the F1 key to conti
Sounds like you have a bad/disconnected Hard Drive and the system is looking for a second boot device (ie: Floppy with a disk) or your primary IDE channel on your motherboard is bad
Apr 16, 2009 | Dell Dimension 3100 PC Desktop
F1 floopy diskette faliure seek faliure
Make sure it is not disabled in the boot order, there is also an option for the drive itself (Diskette Drive) that must be disabled
Jan 05, 2009 | Dell Dimension E310 PC Desktop
try to go to bios set up..then change the boot order..in the boot tab,,change the "first boot" label with hard disk..then it wont seek for floppy again..
Jan 03, 2009 | Dell Dimension E310 PC Desktop
Diskette drive 0 seek failure
Does the PC have a floppy drive? If it doesn't It appears that your BIOS (Basic PC setup) thinks that there is one! I think that pressing f2 on boot will bring you into the BIOS setup.
In there, see can you locate any reference to 3.5 inch floppy and amend it to the setting which suits the config of your PC.
Please take care as to what other settings you change in the BIOS
If you find this sugestion helps please take time to rate it
Aug 30, 2008 | Computers & Internet
Dell Dimension E310 PC Desktop Logo
106 people viewed this question
Alun Cox
