Question about Fossil Abacus AU4002 wristwatch
My Abacus Fossil AU4005 110504 wont charge any more,wen i put it on the charger nothing happen,it does not light up any more,do i need a new battery and where do i get it?
MY WRIST NET ABACUS AU 4005 110504 IS NEC /TOKIN MR11-2695 3.7V-115MAH
    New Friend:
I had the same problem but easy fix.
first make sure you put the watch on charger for a few hours first-- the problem is not the battery not taking charge it is the watch that is not turning on probably.
After a few hours on the charger, remove the four screws on the back cover-- WARNING- remove cover carefully. there are two thin copper wires attached to the cover to the charing coil. set the cover aside. remove battery back (unplug tiny connector). WAIT a10 minutes-- this is to discharge any remaining charge that may be held by capacitor in the watch. plug the battery back in. Voila! working now. This is my way of resetting the watch to factory setting. Isn't it almost always work when you remove power to electronic device to reset it?
Posted on May 30, 2013
4 Suggested Answers
SOURCE:
Cool_dud 09
  • 206 Answers
SOURCE: I cant find a battery for my Fossill Abacus Wristnet AU 4005
Hai,
It has a Powerful rechargeable Li-ion battery so there is no need to purchase extra battery kits!
Posted on Aug 25, 2009
SOURCE: I purchased a abacus wrist net on line with msn
Your issue may not be that the watch is not recharging, it may just need to be reset. This will work on most, but not all of the abacus watches. You need to press all but the top left button at the same time. Do this 20x if successful, your watch will magically power up. I have this issue from time to time, usually right after a static shock. Hope this helps!
Posted on Jan 31, 2010
SOURCE: I have a abacus
au4005 not change no power,phone #313-729-7370 name delton
Posted on Mar 26, 2011
How to recharge or change battery in ABACUS WRIST NET for MNS Direct AU-4004.
Try support at: http://support.radioshack.com/support_tutorials/computer/63-5315.htm
May 08, 2015 | Fossil Watches
How do i set time on fossil abacus analog watch
Google (fossil)(model)(manual) without parens for instructions.
Apr 06, 2015 | Fossil Watches
How to set a abacus au8002 watch
Google (fossil)(au8002)(manual) without parens for instructions.
Dec 25, 2014 | Fossil Abacus Watches
I lost the Wrist Net power supply but I do have the charger base. What voltage is the power supply?
Wow, I haven't used my SPOT watch in years--but I found it!
The charging base for my Abacus AU4000 uses an adapter rated at 12 volts, .11 amps, center positive. I believe that all the charging cradles for the Abacus Wrist Net series watches were the same--the different model numbers referred to different case and band options.
Good luck, and don't hesitate to follow up if you have any additional questions.
May 26, 2011 | Fossil Abacus AU4002 wristwatch
I have a abacus au-4005, how does it work.how do i test the batteries ?
Dec 06, 2010 | Fossil AU4003 Wristwatch
I have an Abacus wrist net and the battery is dead. Where do I send it to get the battery replaced?
Most watch shops will replace batteries but you might need a Fossil dealer to replace yours, as it might need a special tool.
Try your local dealer first.
If you do need a Fossil dealer, go to "fossil.com"; at the bottom of the screen is a menu which includes "store locator". This will tell you where your nearest store is.
Jan 16, 2010 | Fossil Abacus AU4002 wristwatch
I purchased a abacus wrist net on line with msn direct , and my battery isn't charging with my charger.
Dec 15, 2009 | Fossil Abacus AU4002 wristwatch
Hai,
Aug 25, 2009 | Fossil AU4003 Wristwatch
Fossil Abacus AU4002 wristwatch Logo
536 people viewed this question
Top Fossil Watches Experts
Arturs Kalnins
Arturs Kalnins
Janelle Schoonover
Janelle Schoonover
Are you a Fossil Watch Expert? Answer questions, earn points and help others
