I just hit a bouncing ball on my sony bravia 3d led. Nothing has happened yet but i just need to know if it will cause any problem in the future because it the same had happened to my last tv and it s
  • 933 Answers
As long as the screen isn't cracked, you should be fine
Posted on Nov 10, 2012
bob_computer
  • 3153 Answers
SOURCE: Airsoft gun hit Sony Bravia LCD screen, can this be repaired??
Yes but not cheaply
Posted on Aug 10, 2009
  • 1039 Answers
SOURCE: I have a sony bravia 46 inch flat panel tv
6 blinks indicates broblem with florecent backlighting. Check and tighten screws on the inverter boards. There are two boards on the upper left and right. Check that the connectors are in good. Check the pins in the connectors that the wires are attached good. This is a start. If this is under a year old or close to that have seviced under mfc warr. Call sony if expired they may help.
Posted on Nov 04, 2009
circuitworld
  • 335 Answers
SOURCE: A fine green vertical line displayed on the Sony Bravia 46.
Thats a pixel data problem, there's no data being sent to that row of pixels so they don't change color. This is a pixel address registry (PAR) issue and the PAR circuits need to be serviced its usually due to open or shorted SMT components on the PAR circuits. PAR also sends data, voltage, and control to each pixel, the green line you see are pixels that have voltage but because there's no data sent too them their all green because there's no control. If the pixels have voltage but no data or control they show up as green red, blue, yellow, or whit line vertically down the LCD panel. The vertical-horizontal section of PAR are controlled by 16 to 32 bit micro-controllers which may need replacing. If its under warranty take it back if not have your local repair center fix the tv for you...
Posted on Nov 09, 2009
eagle338
  • 4889 Answers
SOURCE: sony bravia l42" LCD TV. No power. Green light on
7 blinks in the this series(KLV) means there is a short in the power supply board. The easiest way to fix this would be to swap out the board. I can find you a replacement if you want to try fixing this yourself.
Sai.
Posted on Dec 24, 2010
  • 8457 Answers
SOURCE: My Sony Bravia TV won't
Tries tv unplug,replug it back like about an hour later.The tv will be resetting back to the factory setting.Now the tv should be working again.If it have the same result.The power supply board is the causes and the problems.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Posted on Jan 13, 2011
What does 4-blink error code indicate?
These may help - the first just tell what it is and which ICs maybe the problem (quite technical)
Solved Sony Bravia Blinking Code
Bravia KDL46EX720 Red LED blinks 4 times and TV wont turn on What is the...
or, in the last resort you could try Sony support, either to get a service manual, or to ask a technician. Don't be fobbed with an expensive answer as in one the examples above.
Support for LCD TV BRAVIA Sony
18.November.2015
Nov 14, 2015 | Sony KDL-46EX720 BRAVIA 46 Class LED 3D...
How can i register add Sony TDG-BR250 3d glasses to SONY KDL-70W850B 3d tv
Hi Mate
Press the Power Button of your 3D glass for 2 Seconds The Power Goes to Green LED ON now your 3D glass is ready for used. Play your 3D movie from Bluray player and Press the 3D Button on the remote. If there is no 3D button on the remote then press Option Button on the TV remote and choose the 3D option from the list. the video will changed to 3D video Now Enjoy your 3D experience. If you any difficultes then PM me.
Dec 11, 2014 | Sony Bravia XBR KDL-70XBR7 70 in. LCD HDTV
My sony bravia KDL-55HX800 SWITCHES OFF ITSELF
It appears to be a normal issue with this model, however there is an update on Sony's site that addresses that issue. If you look at the very bottom of the update details I'm about to post, you will see it
55 Class 54 6 diag BRAVIA HX800 LED Backlit LCD HDTV 3D
Click on Firmware and Read towards bottom of File Description.
The firmware update can be downloaded here
This is how to update by using a USB Storage Device
System Software Update 55 Class 54 6 diag BRAVIA HX800 LED Backlit LCD HDTV 3D
May 23, 2014 | Sony BRAVIA Televison & Video
1year 2months old Sony Bravia KDL46HX820 powers on for few seconds ; I see black clouds on the top left corner ; TV switches off and 4 red lights blink ; Please advice on what might be the issue
No Vertical Sync is the fault. This is a main board fault. The main board might need replacement. But before confirming, check all the voltages comes to the main board from the power regulator board. If you wish to know more about the voltages and their sources, check this link.
Jan 30, 2013 | Sony KDL-46HX820 - 46" BRAVIA 1080p LED...
Power button flashes twice but no picture
Two blinks indicates 'Over voltage protection'. Check its main power regulator board. In most cases, it might need replacement. To know more abut the blinking codes to Sony TVs check this link.
Jan 21, 2013 | Sony BRAVIA KDL55NX720 55" 1080P 3D LED...
My sony bravia model number kdl 46ex723 blinks four times what that mean
Solution for Sony Bravia KDL 46EX723 blinking red light 8 times. Information below is from Sony online support, it worked for me:
Please disconnect the Internet connection from the TV and your TV will work fine.
We are suspecting a network outage issue on Sony device, we are currently investigating this issue. I am really sorry for the inconvenience caused.Unfortunately we don't have any ETA on this,I request you to try at a later time.
Nov 18, 2012 | Sony " 46"" Class - LED - 1080p - 120Hz -...
Bravia NX720 55
I have the same problem, called sony up but they are not responding back. The tv is still under warranty and brought it from Amazon. My situation is same but my led error code is 4 or 5 flashes. Does any one knows what's wrong with it.?
Sep 09, 2012 | Sony KDL46NX720 - 46" BRAVIA NX720 Series...
Sony Bravia 3D Smart Tv
If your TV is a month old call sony and get the TV serviced or exchanged. You are covered under warranty.
Apr 11, 2012 | Sony Bravia KDL-42V4100 42 in. LCD TV
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
Electro Med Services...
