Question about Dell Latitude D620 Laptop (Latitude-C620) PC Notebook
My Dell Latitude D620 is only allowing me to enter 8 numeric characters for a WEP password. My actual WEP key is 16 characters, consisting of letters and numbers. How can I enter this?
  • Dell Master
  • 7,627 Answers
I suppose you could always change the password/security key on you wireless.
Posted on Nov 10, 2012
Geekman
  • 32281 Answers
SOURCE: dell latitude d620 power on password can't remove
No need to short out any pins, shorting out pins allow you to reset the BIOS quickly. When you leave the BIOS/CMOS battery out overnight, this will reset the BIOS (you only need to leave the battery out for 1/2 + hour to do the same thing).
Posted on Mar 29, 2009
  • 3940 Answers
SOURCE: dell latitude d620 bios password removal
To remove a BIOS password will require the assistance of Dell Tech Support. 800-624-9896 You will have to be able to prove you are an authorized user and if out of warranty a Fee may be involved.
Posted on May 17, 2009
SOURCE: Forgot Admin Password for Dell Latitude D620
i have same problems in my same lattude d620
pls help to break admin password.
my id is rahul_par2001@yahoo.co.in
Posted on Aug 27, 2009
  • 6 Answers
SOURCE: need system unlock code for dell latitude
i can give master password
for any laptob dell or samsung or others
u can contact me on
ghost_unknown_0@hotmail.com
Posted on Jul 16, 2010
SOURCE: DELL E6400 Connect to wireless Modem problem
I have the EXACT same problem on the same computer.
I'm not an expert so I searched online but didn't really find a lot of responses to this Dell issue. One suggestion was to turn off Intel PROset and let Windows manage the wireless connection.
That worked for me.
When in the Intel PROset menu, click on Advanced, then click on "Let windows manage your wireless set-up."
Alternatively, you can toggle between the two software by pressing F10.
This solution worked for me.
Posted on Aug 07, 2010
How to set router password
Make sure that you are connected via ethernet cable or hard wired connection:
1. Open a browser ( internet explorer, mozilla firefox,google chrome or safari)2. Delete all of the characters in the address bar3. Type the numbers 192.168.1.14. Press enter.5. You will be able to view the modem settings page.6. Select Basic Setup or the second tab with the word interface.7. Select Wireless Setup8. Enter the SSID or (service set ID), this will be your wifi name.9. Select WEP or WPA for your router's wi-fi password.10. Select ASCII for the passworrd.11. Enter any password ( around 10 alpha numeric characters to make sure that it is a strong password)**alpha numeric means combination of letters and numbers.12. Select Save or Apply.13. Disconnect the network cable for you to test the Wireless password connection.14. Scan for new wireless network on the lower left hand of your computer's screen.15. Look for the wireless name that you entered for your SSID.16. Connect and it will ask you for the wireless / pre-shared key17. Enter the WPA password that you created ( the 10 letters and numbers that you entered for ASCII)18. Press connect.
there you go... you will be connected to your router via wireless with password protection. No one can connect to your router unless you gave them your PSK or wi-fi pre-shared key.
Dec 24, 2011 | Linksys Computers & Internet
My tag 25k483j i need password for dell d630
Go into a command-session (or DOS-box) in any OS you like.
Go to the directory with the LATITUDE.EXE program in it (size is only 5,467).
Type in latitude 12345 and hit enter.You have to substitute 12345 with your 5-character service tag number. The program then gives you the password.
Nov 19, 2011 | Dell Latitude D620 Notebook
I tried to change from WEP to WPA but the password will not go through. It makes it an unsecure line for wireless. What am I doing wrong?
The Short Answer:
Your password might not meet criteria. It also depends on whether you use a custom encryption key. If so, then you either need to create a 10-digit or 26-digit hexadecimal number (numbers 0-9 & letters a-f) depending on whether you use 64 or 128-bit encryption.
The Long Answer:
A WPA password must be between 8-63 characters long, and must only contain ASCII printable characters.
The 2Wire User Guide for the 2700 states the following:
"You can customize the following wireless settings in the Wireless Security panel.
1. From the Authentication pull-down menu, select an authentication setting: WEP-Open, WEP-Shared, or WPA-PSK.
Note: WPA-PSK authentication is supported only on HG model gateways.
Open authentication allows users to configure their wireless adapter as either Open or Shared; in either case an encryption key is required. Shared authentication allows users to configure their wireless adapter for Shared authentication, which requires an encryption key. WPA-PSK requires that users configure their wireless adapter using TKIP.
2. To use the encryption key that came with your gateway, click the Use default encryption key radio button.
To create a custom encryption key, click the Use custom encryption key radio button. If you select Use custom encryption key, you can define a 64-bit or 128-bit encryption key. For 64-bit encryption, enter a 10-digit hexadecimal number. For 128-bit encryption, enter a 26-digit hexadecimal number. A hexadecimal number uses the characters 0-9, a-f, or A-F.
3. Click SAVE"
May 04, 2011 | 2wire 2700HG-B Router (2700HGB)
Please help!! my dell latitude d620 fails to boot displaying: YVFXP is compressed press Ctrl+Alt+Del to restart. When i do this it jus does the same thing.
Ifyou have compressed the hard disk drive using the Compress drive to save disk space option under the Propertiesmenu for your hard disk drive and have performed a non-destructive recovery ora system recovery, the following error message may appear: NTLDR is compressed. Press CRTL-ALT-DEL to restart. This error message is resolved byfollowing these steps: 1. Insert the Windows XP CD drive onthe computer and restart the computer. 2. Press F12 when the computer firststarts, then select CD-ROM, click any key to boot into windows startup. 3. When you get to the install windowsXP screen: 4. Press Rto repair the Windows XP installation using Recovery Console. 5. Enter the appropriate number for theWINDOWS installation, for example, the WINDOWS installation could be listed as 3:C:\WINDOWS or 3: D:\WINDOWS . 6. If prompted, enter yourAdministrator password and press Enter . If there is no password, justpress Enter . 7. At the prompt, if the WINDOWSinstallation you selected in Step 4 was C:\WINDOWS, type: cdc:\ Or, if theWINDOWS installation you selected in Step 4 was D:\WINDOWS, type: cdd:\ 8. At the prompt, type: attrib-c ntldr and thenpress Enter . 9. At the prompt, type: exit 10.Press the Enter key and immediately remove all discs or diskettes from thecomputer to allow the computer to restart.
Mar 05, 2011 | Dell Latitude D620 Notebook
I cannot connect to the internet on wireless on my Dell precision M50. When I enter the WEP key I get the following message - 'The network password needs to be 40bits or 104bits depending on your network...
You are trying to connect to a wireless network that has a password (referred to as protection).
Dont worry about the "bits" or the network configuration parts. - thats all overkill.
The long and short of it is that you need a password to log onto your router.
It will either be 5, 10, 13, or 26 characters in length.
If you do not have the password, you can post the version of the router (model number and brand) up here, and someone can help you reset it so that you can put the password into your computer.
First I would check to make sure the "WEP" key is the right number of characters. 5-or-10-or-13-or-26
Feb 23, 2011 | Dell Precision M50 Notebook
I want to install my wii to my internet. I have a Belkin Router. I need a Security Key or password to get my wii onto my internet. What is the Security Key or password?
the security key is your wep key you can get this buy going on the router itself. Follow this trouble shooting guide and if you need help or it still doesnt work follow up with a comment and i will assist you further. Please try the following troubleshooting: Are you using WEP or WPA security on your router? Log into the router using the default IP (consult your router's manual for assistance) Locate the "wireless security" section of your router settings and find the WEP or WPA key. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters). If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot. If you are using WPA, the Wii console is compatible with the following types: WPA - PSK (TKIP) WPA - PSK (AES) WPA2 - PSK (AES)
If your WEP or WPA key is correct, then the problem might be related to MAC address filtering: From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model). If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings). If the Mac address filter was disabled, then continue troubleshooting.
Check Nintendo's router info for special notes, if available, for your router. Click here to go to our Wireless Router lookup page. Use the drop-down box to select, if available, your router manufacturer. Click on your router's model number, if available. Read any "special notes" at the top of the router's page. Many issues can be solved by changing settings described in the "special notes."
Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration settings. To access these settings: On your PC, click "Start" and then "Run." Type "CMD" into the field that appears to open a new window. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
Power cycle your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response. if you require further assistance please let me know and i will be glad to assist you. -Midwest-tek
Aug 24, 2010 | Belkin F5D7230-4 Kit (F5D7230V4SNPDQ)
Error code 52030 ,when trying to hook up to wireless internet
This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting:
  1. Are you using WEP or WPA security on your router?
    1. Log into the router using the default IP (consult your router's manual for assistance)
    2. Locate the "wireless security" section of your router settings and find the WEP or WPA key.
    3. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F.
    4. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F.
    5. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters).
    6. If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot.
    7. If you are using WPA, the Wii console is compatible with the following types:
      • WPA - PSK (TKIP)
      • WPA - PSK (AES)
      • WPA2 - PSK (AES)
Mar 11, 2010 | Nintendo Wii Console
Error code 51330 trying to conect to the internet get so far then get this
      • WPA - PSK (TKIP)
      • WPA - PSK (AES)
      • WPA2 - PSK (AES)
Feb 09, 2010 | Nintendo Video Game Consoles & Games
Error code 51330 on the wii.it will not except my
Error Code: 51330 This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting:
      • WPA - PSK (TKIP)
      • WPA - PSK (AES)
      • WPA2 - PSK (AES)
  2. If your WEP or WPA key is correct, then the problem might be related to MAC address filtering:
    1. From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model).
    2. If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings).
    3. If the Mac address filter was disabled, then continue troubleshooting.
Need further troubleshooting? Go straight to Nintendo's website at:
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51330&system=Wii&locale=en_US
Nov 19, 2009 | Nintendo Wii Console
Computers & Internet Logo
49 people viewed this question
Alun Cox
