Question about Dryers
My speed queen model AGM499W does not dry clothes cycles off and on after 10mins
I cleaned out lint and checked vent to outside
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 70 Answers
Here is what I did. I went to the breaker box and reset the breaker for the dryer. Sometimes it will only pop 1/2 of the breaker, due to being too hot.
Hope this works
Posted on Nov 09, 2012
The dryer simply doesn't dry my clothes
Are the clothes warm after cycle? If not heater coils may be bad. Is lint trap cleaned out? Have you checked the vent that exhausts the air to the outside? make sure it is cleaned and kink free and the air is flowing freely. If you can get to the end of the vent outside you could try running the unit and check to see if you're getting good air flow outside from the vent.
May 27, 2011 | Amana Dryers
Tip
Saving money drying clothes
The biggest thing to remember about your clothes dryer is that it has to get the moisture out. If you keep your venting clean it will aid your dryer in shorter drying times. The more heated dry air it can pull through wet clothes while they are tumbling the faster clothes will dry.
If the venting is restricted by lint or kinked, or low quality venting, all end up costing more in drying times. Use good venting, preferably steel, and do use the proper vent cap on the outside wall.(check lint does not catch here also)Many service calls could be prevented by regular maintenance of venting.( thermal safety fuses which all dryers have are the reason for most service repair calls when the venting has not been cleaned) Also the shorter distance your dryer is vented, the better.
The second less obvious problem is not cleaning the lint screen. All the air or almost all passes through this screen before being exhausted outside. You need to clean the lint first. Second you need to wash the lint screen in the sink to clean off any build up of fabric softener that can also cause slow drying. Water should run straight through the metal mesh, if it ponds it is coated with softener, and water should wash this off.(I have been on service calls where dryers were not drying correctly and just washing off the lint screen of fabric softener fixed the problem)
Lastly wiping the two short parallel bars about three inches long found inside the dryer with alcohol to remove any fabric softener or other coating will keep the automatic cycle working right.Not all dryers use these........
Before thermistors, when thermostats were all that was out there.........
Hope this saves you some money and time.......
on Feb 23, 2010 | Dryers
Speed queen dryer takes twice as long to dry the clothes LGS27AWM3080 1003002387
disconnect vent tube and run a load of clothes, as it sounds like the vent tube is restricted. if that does not help then you will need to clean the dryer from the lint screen to the back of the dryers vent, where you hook up the vent tube. Hope this helped Tim
May 24, 2011 | Speed Queen AES17AWF Electric Dryer
My kenmore 400 dryer takes for ever to dry clothes, does it need a new heating element?
Have you ever cleaned it out? If not, that is the most common problem with dryers. It can't breathe and takes multiple cycles to dry the clothes. Unplug the dryer and pull it out. Disconnect the vent from the back of the dryer. Clean out lint from dryer and vent. Take the vent outside if you have to and blow it out with air compressor, if you can. Now check the other end of the vent outside at the vent cap. Clean it out and make sure the vent cap flap is not stuck closed. After reassembling vent, turn on dryer and check for heat at outside vent. You also may need to clean it out more if lint has traveled down the vent. Also, clean out your lint filter religiously for more efficient drying. Those are the easy things to look for and fix on your own. If it still does not improve drying, you made need a repairman to trouble shoot it. Good luck!
May 15, 2010 | Kenmore 400 6942 Dryer
Speed Queen dryer burner lights but does not dry clothes
This is a symptom of a severely clogged up vent or dryer passages.
Remove the vent duct hose from the back of the dryer and see if the problem persists. If it workes normally clean out the ducting and the through the wall flapper vent.
If the problem persists then remove the lint filter and inspect the air passages inside the dryer. Also check the exit hole where the vent duct connects for lint buildup. Use a crevice tool / vacuum to clear all dryer passages. If necessary use a folded coat metal hanger to assist in removing lint build up.
Wash the lint filter with whie wine vinegar and then soap and water to remove the dryer sheet particulate matter that builds up on the lint filter.
If the burner lights but goes out after 30 seconds then the flame sensor on the top of the burner assy ducting is bad.
Thanks for using FixYa.
Kelly
May 12, 2010 | Speed Queen AGS28AWF Gas Dryer
Whirlpool dryer model #GEW9250PT1 not drying properly
when was the last time you cleaned your dryer?all a dryer does is move air around and if it can't cycle through the dryer the clothes won't dry. unplug the dryer and then you need to clean the duct that the lint filter slides into,vac out the inside of dryer where the motor is and clean out the vent line,if the vent line is a long run from the back of dryer to the outside vent i use a leaf blower to clean it out,make sure the outside vent is clear first then blow it out,if it's a short run vac it out,most problems start just from lint buildup,the clothes don't dry the dryer runs hot and parts start messin up,also vac out under your fridge,take the bottom kick plate off and vac it out,you can kill the compreesor if you don't,good luck
Apr 05, 2010 | Whirlpool Dryers
Dryer is slow dryng takes two cycles compared to regular dryer
As the model number you provided indicates this is a gas dryer, you need to open up the access panel, above the washer compartment, to clean out the dryer compartment.
It is likely that either the gas burner components have been covered in lint and dust and are getting shut off sooner than they should because of overheating of the thermocouple safety device, etc.
First, make sure that the power is turned off to the washer/dryer unit and turn off the gas supply valve, so you don't have any issues with getting a electric shock or getting a gas leak/build up.
Once you've done that, you can remove the two (2) access screws that will let you get into the lower dryer compartment where the gas burner and control devices are located (this is the panel just above the washer lid, the angled section).
Now vaccum out all the lint and dust buildup you can see and check that everything is free of dust and lint inside this area. Pay special attention to the gas burner and gas inlet orifices, as anything in there can and will cause the dryer to shut off and thus, not operate properly in getting your clothes dry in a normal drying cycle.
Also, check to see that the dryness sensors inside the dryer drum (silver bars up near the top left or right of the dryer drum) are clean and don't have any residue or buildup on them. This can also cause the dryer to register erraticly when using the automatic drying cycles versus the timed drying cycle. Use a good glass cleaner and wipe these sensors with a clean cloth rubbing them briskly to remove any residue or contaminent that might be deposited on the sensors.
Now completely clean out the exhaust vent all the way from the dryer to the outside location of the vent. Having any blockage of the vent can and will cause the thermal overload protective device to function and turn off the gas burner that provides the heat to dry your clothes. So be absolutely certain that the entire vent exhaust is clean and free of any lint buildup from the dryer all the way to the outside vent (yes I mean't to repeat that!) You'll have to remove the outside vent grate/cover to check for any buildup/obstructions there.
Now you can run a load to see if you've gotten the problem solved, if not, it could be a control module, but 80% of the time, it is nothing more than a "housekeeping" issue that causes loads not to completely dry on the first cycle. So please do some cleaning and checking and you should be back getting your clothes dry on the first cycle!
Hope you find this Very Helpful and best regards!
Oct 20, 2009 | Whirlpool WGT3300SQ Dryer
Will not dry clothes fully. the machine heats fine but it takes two or more cycles to fully dry a little load. someone told me about a part that may need repaced around the lint trap.. Any ideas?
Your lint exhaust is blocking the heat flow.
Remove the vent from the rear of the dryer and run a timed cycle load for 40 minutes.
If laundry is dry, repair the outside vent.
If not dry,open the dryer cabinet and clean the inside lint and heat vent.
Mar 05, 2009 | Kenmore Dryers
Clothes not drying even after 4 cycles
you have to check your dyer vent hose and vent pipe to outside for any restrictions. #1 problem for extented drying time. it like having a backed up sink
Dec 13, 2008 | Maytag PYE2200 Dryer
Dryer takes more than one cycle to dry clothes
Did you clean the entire length of the vent ducting? Or, did you only clean the lint trap on the dryer and the exhaust vent outside? If you didn't clean the ducting as well, you may still have a clog somewhere causing your dryer to be "starved" for air. A dryer needs proper air flow to dry properly. One way to check is to turn the dryer on and go outside to the exhaust vent opening. Feel to see if you have sufficient air flow. If the air flow is weak, you have a clog. If not, you may have a high limit thermostat cutting off prematurely, not allowing the heating element to heat long enough. Check your ducting first and let me know if this helps.
Jul 28, 2007 | GE DBSR453EBWW Electric Dryer
Dryers Logo
43 people viewed this question
Top Dryers Experts
