Question about SanDisk Sansa e200 MP3 Player
How to reset my sansa
My sansa doesn't to laoding after a turn off
  • 161 Answers
The reset for this machine is to push and hold the poewr button for at least 50 seconds
Posted on Mar 24, 2009
    Problem Solver:
  • 6 Answers
Reset by holding the power button for 1min
Posted on Jun 03, 2009
Sansa pmp recovery tool
The Sansa Connect Recovery Tool can be used to reformat and install firmware version 1.2.0.53385 to a Sansa Connect. This version is used in the current selling Sansa Connect products.
If for some reason device becomes unstable and resetting and erasing content doesn't resolve the issue, the Sansa Connect Recovery Tool would clean up your device and restore it to factory settings
2 things to check before starting the Recovery Mode and to use the Recovery Tool:
- First, charge the Sansa Connect for at least 20 minutes using the AC charger to ensure this is not a battery depletion problem.
- Second, hold the power button for 8-10 seconds to ensure the device is turned OFF.
After these steps, you can put the Sansa Connect into Recovery Mode and use the Recovery Tool.
Sep 16, 2012 | SanDisk Sansa e260 MP3 Player
My sansa SanDisk 4gb player locked up and won't do anything
Slide the power switch up all the way and hold it there for fifteen seconds or so. This will reset the player.
If this doesn't, please reply to this post and we can go from there.
Dec 02, 2011 | SanDisk Sansa Fuse MP3 Player
Sandisk Samsung e200 Problem...?
Hello, first reset the player. If resetting doesn't help, please let me know for further assistance.
Click here: http://www.fixya.com/support/r6977146-reset_different_models_version_san_disk
Don't forget to get back to me if resetting doesn't help.
Regards.
Nov 12, 2011 | SanDisk Sansa e200 MP3 Player
When i turn on my sansa e260 and show the sandisk logo, it restart showing the logo over and over without going to the main menu, how do i fix it ?
Hi, welcome to fixya!
You need to reset your sansa for it to be in order again.
Learn how to reset the your various San Disk models;
Resetting a Sansa Fuze+, Clip+, c200, e200, or e200R player:
1. Press and hold the Power/Menu button for approximately 20 seconds.
2. Release the Power/Menu button.
3. Press the Power/Menu button again to turn on the player.
Resetting a Sansa View, Fuze, or Clip player:
1. Slide and hold the Power switch up for approximately 20 seconds.
2. Release the Power switch.
3. To turn the player on, slide the Power switch up then release instantly.
Resetting a Sansa Express player:
NOTE: The device can be either ON of OFF.
1. Press-and-hold the Volume Up (+) and Select buttons simultaneously for approximately 20 seconds.
2. Release the buttons.
If resetting doesn't solve the problem, please let me know for more assistance.
Good luck.
Nov 03, 2011 | SanDisk Sansa e260 MP3 Player
When i turn on my sansa clip, it says not enough space, please free 90 mb, and when i connect it to the computer, nothing shows in the sansa clip file, not even the songs i have. what should i do?
Try resetting the player.Hold down the Power/Reset button for about 15 seconds to perform a normal reset.
If it doesn't help then try the one below.
This will reset the player to its original factory settings.
1. Press Menu to return to the Main Menu.
2. Move to Reset All and select it.
3. Select Save to reset to factory settings or Cancel to stop
Aug 18, 2011 | SanDisk Sansa Clip MP3 Player
My sansa clip is frozen on the blue flower
One issue that people experience with the Sansa Fuze player is that the screen turns white when they are trying to use it. If you experience this common Sansa Fuze MP3 player repair issue, you need to reset your player. Hold down the "Play" and "Power" buttons for about 20 seconds. The player should automatically reset.
MP3 Player Freezes
Another issue is that the player freezes. You may see lights on the player, but it won't do anything. Follow the below steps to correct this issue:
1. Use the above steps to perform a hard reset.
2. Turn the player back on, and slide the "Power" button upward.
3. Use the USB cord that came with your player, and connect it to your computer. Only connect your player directly to the computer. Don't connect it to a USB hub.
4. See if your computer recognizes that a device was connected to it. Or, look in "Devices and Printers" folder, and see if the device shows up in it.
If your device doesn't reset, and the computer doesn't recognize it, contact SanDisk for additional assistance. Or, you can attempt to repair the device yourself.
Repairing Internal Components
If your Sansa Fuze player is out of warranty, you can attempt to repair internal components. This is an "enter at your own risk" solution, but you may be able to fix the issue. If it doesn't work, or if you damage another component, you will most likely need to get a new player.
1. Shut off the device.
2. If you don't have one, purchase a case opener tool. This is a tool with an extremely small head that is used specifically for opening up small devices.
3. Place the head of the tool in the seam of the device, and rise up the faceplate. Do not do this forcibly, or you'll break the ribbon cable connected to it.
4. Remove the ribbon cable from the faceplate.
5. Examine the battery cable. If this connection is loose, your Fuze player won't turn on. Plug the connection firmly into the port.
6. Check the LCD screen connection. A loose connection here means that you can't see anything on your screen. Disconnect the cable from the port, and reconnect it.
7. Reattach the cable to the faceplate, and reattach the faceplate. Turn the device back on.
These Sansa Fuze MP3 player repair suggestions may not fix all issues. If your player is still not working properly, either take it back to the place where you bought it, or contact SanDisk for additional help.
References
Fixya.com, http://www.fixya.com/support/t4267400-sandisk_fuze_4gb_locked_lights_will_not
SanDisk, http://www.sandisk.com/products/sansa-music-and-video-players/sandisk-sansa-fuze
Jul 18, 2011 | SanDisk Sansa Clip MP3 Player
PROBLEME OF MEMORY.
My Sandisk Sansa m240 lost all the songs and then I could not delete them. I was able to laod up new songs, but there was no spare memory. I was able to fix this issue by re-formating.
Using windows explorer right click on the "Sandisk sansa M240" and click "format".
Now working OK.
Feb 20, 2008 | SanDisk Sansa m240 MP3 Player
I have Sanso m250 2.0gb mobel. Logo screen is appearing when i power on after that i am unable to play the mp3 songs or play FM Radio etc..
Try doing a hard reset on a Sansa m250:
  1. Turn off the Sansa. Just pull the battery out for a second.
  2. Plug the Sansa into a computer4.gif, and open "My Documents" in the computer.
  3. Open the Sansa file as if it were a drive, then go to the "MUSIC4.gif Specific storage" file.
  4. Right click the "MUSIC Specific storage" file, and press "Format."
This should hard reset the Sansa m250. I do not know if this will work on other Sansa m200 type .mp3 players. You can start over with your playlists. This has worked for me.
Dec 23, 2007 | SanDisk Sansa m250 MP3 Player
Sansa e200 won't turn on
Load main image failed refers to a bad firmware file on the device. You can download and run this recovery tool from the SanDisk website. http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe Best of Luck.
Sep 07, 2007 | SanDisk Sansa e200 MP3 Player
My Sansa doesn´t work well,
If it is still on, hold down the power button for about 15 seconds; that should turn it off. Try turning it on again. If it still does not work, turn it off by holding power for 15 seconds, then on again like this: - Put hold on - Hold record - Press power on This will start recovery mode, follow on-screen instructions. Hope all goes well!!
Apr 29, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e200 MP3 Player Logo
108 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
