Question about HP LaserJet 5200 Printer
Hp laserjet 5200 is putting a crease in the paper
There is a very thin straight crease in the paper no matter how you feed it in.
Soulvisitor
  • 1113 Answers
SOURCE: printer is putting a crease in the middle of the paper
You need to have the fuser replaced, it comes out easy on these back cover just pulls off, and there is two tabs or long silver screws to undo fuser, remove it anf you will see that upper roller is worn, buy a maintence kit for this model which includes fuser and fit it yourself easy done instructions are included with kit.
Posted on Dec 01, 2007
SOURCE: HP Laserjet 3050 paper jam
software cd
Posted on Feb 18, 2008
  • 990 Answers
SOURCE: HP Laserjet 1300 paper creasing on printing
change toner cartridge will be OK!
Posted on Dec 16, 2008
SOURCE: My HP LASERJET P3005N Printer is creasing the
To fix this problem see that the paper is not damp. ie it should not be moist. i had the same problem and sorted out by letting the paper to dry.
Posted on Sep 10, 2009
  • 615 Answers
SOURCE: paper jam hp laserjet 5200
All printers after sometime the rollers start grapping more than one sheet that result in paper jam or dirt building up inside…make sure you open the printer and clean it good and see if you can locate any small papers that usually stuck inside…let me know
Please do not forget to rate the service for the site to continue helping everyone and improve on it.
Posted on Sep 16, 2009
Unable to pick up papaer on tray 2 error 13.00
common faults for poor feeding on lj5200
1, feed rollers are worn - replace
2, sep pad is worn ( cant seperate pages correctly)- replace
3, paper empty tray sensor actuator arm snapped - unable to raise cassettetray- replace arm
4. paper feed roller fail to turn- feed unit clutch assy faulty- replace feed asseembly
5.paper tray pass guide out of position (blocking feed path) - pin that holds in place has snapped- replace feed assembly
Dec 13, 2013 | HP LaserJet 5200 Printer
HP 2840 printing two thin black lines from top to the bottom of the center of the page is that a fuser kit problem?
It could be a fuser problem.
Put paper in the manual feed tray. Print a few pages. As the paper gets
1/2 way into the printer, open the cover. Look down at the paper in the printer.
If it has 2 thin black lines, the toner cartridge needs to be replaced. If there are no lines the fuser is probably bad.
Jul 22, 2011 | HP LaserJet 2840 All-In-One Printer
Paper comes out creased on one side
If the printed image is smudged, as well as creased, you might have a torn Fuser fixing film.
You will need a technician to fix that.
If it is just a crease, just check that
1. Your paper is not damp. Try a fresh packet of paper
2. The paper input tray guides are set to the width of the apaer, to prevent the paper skewing as it feeds.
Good luck.
Jun 21, 2010 | HP LaserJet 1012 Printer
Hp 3030 laserjet paper creasing when printing
if the print is also smudged the fuser needs replacing
Jan 12, 2010 | HP LaserJet 3030 All-In-One Printer
Paper jam hp laserjet 5200
Sep 16, 2009 | HP LaserJet 5200 Printer
Hp laserjet 1200 paper jam
Please Follow the instructions in an attempt to resolve the issue you are facing:
  • Turn off the printer and remove all paper from the paper tray & disconnect it from the computer.
  • With the printer off, check for any obstructions such as torn paper or foreign objects.
  • Turn on the printer (still disconnected from the computer) and check the lights / lcd screen.
Still getting the same error ? Go for Warranty or Service.
Else,
  • Place 20-30 sheets of paper in the printer, ensuring none of the paper is torn or creased.
  • Make sure that the paper is flush with the far right edge of paper tray, move the left edge paper guide over so that it touches the left side of the paper.
  • Try to feed paper manually (using the paper feed button).
If you still get the error let me know for further troubleshooting,
Dont vote till you find it is Helpful or FixYa.
Thanks,
Scott
Nov 14, 2008 | HP LaserJet 1200n Printer
Manual Feed Gets Jammed
There could be an obstruction in the paper path or the roller might need to be clean or replaced.
Jun 12, 2008 | HP LaserJet 5200tn Printer
The rollers may be worn so it is not getting picked up evenly. Also, be sure that your paper tray in aligned properlyand guides are keeping the paper straight. If both of these seems to be good then there may be something in the paper path.
Jan 16, 2008 | HP LaserJet 3050 All-In-One Printer
53 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
