Question about Echo Garden
How to replace the starter string on an HC-150 model hedge trimmer
boscia
  • 163 Answers
SOURCE: how-to repair the pull starter for the WEED EATER GHT220
remove the starter housing, usually only 3 or 4 bolts or screws. on the inside should be a large white or black wheel, hold the outer case with one hand and rotate the wheel counter-clockwise with the other as many times as can without force. on the inside of the wheel should be a small hole, rotate the wheel to line it up with rope guide hole on the outer case/housing. use a nail or small screwdriver to help hold in place. feed the start rope through the 2 holes and tie a knot at the end, single or double depending on the size of the hole. if the end of the rope is frayed, use lighter to melt and twist to a point to make it easier to handle. when reassembling you may need to jiggle the handle for realignment. it works on an inner spring coil tensioner system, so if the cable has no tension when rotated or doesn't recoil back, the starter assembly will need to be replaced.
Posted on Nov 28, 2008
  • 97 Answers
SOURCE: what would cause excess vibration in an Echo
Check for loose blade to case mounting bolts or cracked support bar.
Posted on Mar 19, 2009
  • 11 Answers
SOURCE: Wont coil back into its housing, so trimmer wont start. Has compression though
Hi, this a cut&paste from elswhere but it applies to your problem:
how to repair a recoil spring: whats missing is this, you should always wgear eye protection when dealing with springs of any kind.
remember safty first. :)
Remove the recoil shroud and take a look at the assembly.
You might have a broken spring or just a rope that has slipped out of the reel.
The spring usually breaks at one of the end tabs. If so, you will need to get a replacement spring and carefully wind that in, before re-assembling the rope reel. You might wish to replace the rope also, if it shows signs
of wear.
You will need to remove the entire cooling shroud. There should be 4 bolts on the sides. You might need to remove the fuel tank also. Pre-wind the recoil reel by hand [about 6 turns, to set the spring tension] and clamp it with Vise-Grip pliers. Remove the old rope. Thread
the new rope through the shroud housing eyelet and to the reel hub. Let the reel re-wind itself until it is full. If there is not enough spring tension you can wind it a couple of turns more by slipping the rope around
between the reel and shroud. Re-clamp the reel. Cut the rope to length and thread it though the handle. At all knots, burn and melt the rope with a
lighter to prevent untying. Re-assemble.
(special thanks to "Micheal"the author)
Posted on May 19, 2009
SOURCE: Looking for owners Manual for Echo HC 1500 Hedge
Go to this web site http://www.echo-usa.com/ and on the right hand side of the page click "TECHNICAL DOCUMENTS"
Then when the next page comes up type "HC-1500" and click search.
Now this is important: You have to keep track of your serial number, your model number and
your engine type.
Even when your looking for parts such as the ignition coil keep track of your serial number.
When you pull the side bar down you'll find the different manuals you can copy. I hope this helped.
Posted on Jul 27, 2009
SOURCE: sharpen hedge trimmer blade??
My trick is to make sure that I always lube the blades after each session with a 3/4 engine oil + 1/4 kerosene mix - making sure that every tooth gets a drops or 2, then run it for a seconds to spread the oil & leave the blades overlapping. Doing this allows the blades to self sharpen I've found. 2 stroke oil , unmixed is about the perfect viscosity aswell.
Posted on Feb 18, 2010
Starter rope is stuck, will not move when trying to start the trimmer
Smack the the f%%k out of the reel try to get some w/d oil on it then get a new coil reel when smacking watch for string whip
May 31, 2014 | Homelite Factory Reconditioned 26cc...
Replacement of starter cord on HC-150 hedger
You may have wrapped it the wrong way. If not, your spring is either broken, the bend on the end which slides into the plastic has straightened, or the plastic spool has broken where it holds the other bent end of the spring.
Nov 07, 2013 | Echo HC-150 COMMERCIAL SERIES HEDGE...
Husqvarna Trimmer 128LD starter card will not retract
Check the recoil spring in the starter housing, sometimes the rope rotor can jump out the hook on the spring.
Oct 22, 2012 | Husqvarna 128LD 28cc 2-Stroke Gas-Powered...
I have a echo HC-150 it won't stay on boggs down
Hi, either the carby is flooding and requires a carby kit or the spark arrestor or outlet in the muffler is blocked. Hope this helps, regards Phil.
Jul 18, 2011 | Echo Garden
HC-1500 hedge trimmer runs at high speed,but not at low
The first thing to do, is to clean the air filter, and remove the plug, and clean with a wire brush, if neccesary.
You should also bear in mind, that the timing may well, be in need of retarding, ever so slightly.
If problem still persists, you known where we are.
Jul 25, 2009 | Garden
Looking for owners Manual for Echo HC 1500 Hedge Trimmer.
your engine type.
Apr 02, 2009 | ECHO, Inc. 20 In. Double Sided Hedge...
Garden Logo
60 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
