Question about Boating
25 mariner outboard has no fire?
25 mariner has no fire. plugs look ok. was told may be trigger switch? how do i find and check this switch?
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 227 Answers
Id start with checking my stater under the flywheel then coil pack
Posted on Dec 20, 2013
2 Suggested Answers
  • 12 Answers
SOURCE: 1984 150hp yamaha outboard is not firing in #5
Stator delivery to the coils.
Posted on Oct 08, 2009
How to winterize 175 mariner outboard motor
Take a look at these instruction videos.
How to Winterize an Outboard boat, step by step guide in ...
9k=? 11:25 https://www.youtube.com/watch?v=x217iM77Qjc Oct 30, 2012 - Uploaded by Warren Hardy A detailed step by step guide to winterizing your outboard boat motor for ... most 2-stroke outboards ...
Winterizing Your Boat: Step 2 The Engine & Lower Unit ...
9k=? 10:01 https://www.youtube.com/watch?v=5kiOms2f4gg Oct 6, 2009 - Uploaded by West Marine How to Prepare Your Boat for Winter - Step 2 in the five step process on How to Winterize Your Boat: The ...
How to Winterize a Four Stroke Outboard Motor - YouTube
9k=? 2:44 https://www.youtube.com/watch?v=PRBnwYk8_Yk Nov 7, 2012 - Uploaded by boats.com Four stroke outboard motors are by far the most popular on the market. But there's a lot of confusion about ...
How to winterize your outboard
www.classicglastron.com/gl-outboard-winterizing.htm For smaller outboards, the simplest way to flush your outboard is by using a large ... water or purchase a set of "ear muffs" (available at your local marine dealer).
How to Winterize an Outboard Motor - Adventure
adventure.howstuffworks.com/outdoor.../how-to-maintain-a-boat4.htm ... the winter and prolong its. Learn how to properly winterize an outboard motor. ... Buy lubricant, oil, and fuel conditioner at a marine store. Time: about 2 hours.
Jan 09, 2016 | Boating
Why wont my 50 hp mariner start ?
renew spark plugs,mix up some fresh fuel,put choke on,throttle set at just above idle,pump up fuel bulb by hand till tight,put outboard in a water drum,try pulling or turning on starter till it fires,then push choke in and restart
Jul 25, 2014 | Mercury Gear Set, Complete, Mariner, Force...
How do i fix a mariner 60 outboard motor that has fuel starvation?
have you checked the fuel pump diaphrams are ok and are the connections on the fuel tank and line ok ? primer bulb not sticking ? carbs clean ? fuel pump connection to crankcase ok ?
Apr 26, 2014 | Clymer Mercury/mariner 2.5-60 Hp...
1995 200hp evinrude oceanpro only getting fire to one spark plug
check the trigger it is doubtful that both power packs are bad move trigger around the stator and see if another plug fires if it does the trigger or optic eye is bad most likely the eye
Apr 12, 2014 | Boating
115hp 1985 yamaha outboard 6e5 AETO running at low revs as if on 3 cylinders,on low revs only when i accelerate it goes well and fast without issues,when i slow to trolling speeds it runs a bit rough...
sounds like a bad coil or trigger. Find the offending cylinder with a timing light and physically move the coil to a good firing cylinder. If the problem follows the coil, you have it, if not you need a trigger,
Nov 09, 2012 | Clymer Marine Maintenance and Repair...
25 hp mariner outboard runs ok for 2klm then drops power down to half hard to start afterwards and erratic tick over ...had new coils, nrw plugs,new advance thing under crank case all gaskets have been...
does it have the old type timming advance (non adjustable) get it timming through the cd switch. if so could be this but o/b man should have ched this change your gas hose and pump bulb if you sure no electrical problems
Dec 15, 2010 | Mercury Boating
I have a 1977 85 hp johnson outboard it started and idiled for about a minute and now i cant get it to fire at all its got good spark possibly not getting fuel but is there anything else i should check
i have a 1977 85 hp johnson outboard it started and idiled for about a minute and now i cant get it to fire at all its got good spark possibly not getting fuel but is there anything else i should check
May 06, 2010 | Johnson Minn Kota Mk 25 & Mk 35 On Board...
Sep 20, 2009 | Boating
1993 40 HP 4 cyl. Mercury outboard: Running along
I solved it with no help from the professional assistant team. Thanks for no help till I send money...DON'T THINK SO!!! Thanks for wasting my time.
Sep 03, 2009 | Boating
Merc outboard 115HP 1996 fuel primer/Choke
Hello there
here is a good place to start ok Outboard (wiring A Tachometer To An Outboard, Mercury Outboard Float) safe.gif
merc outboard motors mercury outboard ... diagram of mariner outboard motors johnson outboard fuel problems ... johnson outboard motors ebay 1996 115 hp mariner outboard
  • tipsterdatabase.com/mods.php?id=outboard
  • · Cached page
Aug 27, 2009 | Boating
Boating Logo
66 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
