Question about Dell Dimension E521 (D10E16) PC Desktop
Cannot connect to internet thru ethernet jack on computer
Can connect to internet thru usb port on computer.
also can connect to internet on an alternate computer
using thr ethernet cable
is the ethernet jack in the dell e521 bad ???
how do i correct ??
jc
Help my px dint came wit a Ethernet jack on phone jack the lil 1 wat to do is there a 3 way Ethernet tha hold phone and Ethernet jack in 1 help me dboi39@yahoo
Posted on Jun 05, 2009
  • 43 Answers
It could be. Check your Device Manager and make sure the device isn't disabled. Also each adapter has its own TCP/IP settings so make sure yours on your ethernet adapter are set the same as your USB adapter that is working. If it does turn out to be bad you can always add a new ethernet card for cheap.
Posted on Jan 06, 2009
Can I disable wireless and connect with ethernet cord and modem, for work do not want remove wireless cord, in the day want to be able to use my wireless.
Are you talking about direct-connecting via Ethernet to a cable or DSL modem? You shouldn't have to disable wireless to do that. If the cable modem has an open Ethernet port, you should be able to run a straight-thru Ethernet Cat-5 cable between that port and the Ethernet port on your laptop. The laptop should recognize that it is connected to the modem through the direct connection. Check the manual for the cable modem or information supplied by your ISP for connection details. You may have to do some setup on the modem to get an Internet connection, like having your ISP 'activate' the modem. Just be sure your Ethernet cable is a straight-thru, standard Ethernet cable, and not a 'cross-over' cable such as is used to transfer data between two computers.
Jul 24, 2014 | Dell Inspiron Computers & Internet
Computer does not recognise speedstream 6300
you try form USB or LAN interface \\Ethernet connection (recommended)
  1. Plug one end of the RJ-11 telephone cable into an unfiltered telephone wall jack (enabled for Sympatico High Speed Internet service).
  2. Plug the other end of the RJ-11 telephone cable into the DSL port on the back of the modem.
  3. Plug one end of the RJ-45 Ethernet cable into your computer's Ethernet port.
  4. Plug the other end of the RJ-45 Ethernet cable into the Ethernet Port 1 on the back of the modem.
  5. Insert the rounded end of the power adapter into the Power port and the dual-pronged plug end into your power outlet.
  6. Press the power button to turn on the modem.
USB connection
  3. Plug the small, square end of the USB cable into your computer's USB port.
  4. Plug the wide, flat end of the USB cable into the USB port on the back of the modem.
May 28, 2012 | Efficient Networks Speedstream 6300...
How can I connect the router to my laptop if I don't have any internet. I mean I do have internet connection available on my landline but I need to set it all up on the laptop. how can I do this? I...
Use a 2-wire or 4-wire cable to connect from the telephone-jack to the telephone-port on your DSL modem/router combination device.
Use an 8-wire Ethernet cable to connect from one of the 'LAN' ports on the router to the network-port on your laptop.
Then, you will have Internet access, and, if this router also has a "wireless" capability, you can configure it to provide wireless access to your computer(s).
Mar 30, 2011 | D-Link ADSL 2+ Ethernet/USB Annex A Modem...
Sir what purpose usb port and what purpose ethernet port are in zxdsl 831aii modem.
You can connect it to the computer either thorough USB or Ethernet depending on which connection you would like to use Ethernet is a better choice.
Mar 02, 2011 | Computers & Internet
I cannot connect to internet because my computer was remastered and trhe computer does not recognise my router and is telling me to install a driver
I Figure your using a USB lead from your router to your computer. You will need to download the USB interface driver from the Belkin web site. Otherwise, if the router has a ethernet jack, then use a patch cable to your computer (ethernet port) eliminating the need for a driver
Feb 15, 2011 | Belkin (F5D7132)
I can't get my router to connect to the phone jack
Connect ethernet lan cable to computer and router end.
In router there is LAN port connect lan cable to that port and connect other end of that cable to your computer ethenet lan card.
Then connect phone line jack to router's ADSL Port.
Let me know if you need further assistance.
Thanks for using FixYa.
May 07, 2010 | Linksys Wireless-G WRT54G Router
HPNA setup
all you need is the longitus eterneth cable needed to connect to / from the Dynex 4 port Hub ethernet cable plus a host pc on Dynex 4 port ethernet hub, the host pc you need to specify that you are sharing the connection of internet connection through the eterneth, and ready
luck
Jan 11, 2010 | 2wire PC Port Phoneline HomePNA 10Mbps USB...
Why my modem dsl isn't recognized by my computer
It does *NOT* need to be "recognized".
Connect a telephone-cable from the modem's telephone-port to a telephone wall-jack.
Connect the AC power to the modem.
Connect an Ethernet cable from the Ethernet-port on the modem to the Ethernet-port on your computer.
If you don't get an Internet connection, contact your ISP, and ask for Technical Support, and get them to trouble-shoot.
Jan 02, 2010 | Vtech Computers & Internet
Can the modem's ethernet port connect to a video game console?
Most modems that have both usb & ethernet connectors are either/or, not both. I recommend using
the ethernet connection to your computer than the usb - the ethernet connection is faster & more
reliable. It also frees up your usb port for other use. If you want both your computer & game console on
the internet, then you need to buy a router which will allow you to share the modem.
Jul 08, 2009 | Computers & Internet
Actiontec gt701-wg Installation
You can use USB instead of Ethernet port but its not a common practise. Leave it empty then.
Dec 03, 2007 | Actiontec GT701WG Router (actiongt701wg)
Dell Dimension E521 (D10E16) PC Desktop Logo
714 people viewed this question
Alun Cox
