Question about Hardware & Accessories
How to set the inner dial - Hardware & Accessories
  • 5,089 Answers
If this is analog timer, then copy following link for instructions:
http://waterheatertimer.org/How-to-set-timers.html
Posted on Nov 10, 2012
Function dial works intermittently on Nikon D100
The inner mechanism may be dirty, "and a professional cleaning may fix that, or the complete dial might need to be replaced.
Apr 02, 2012 | Nikon D100 Digital Camera
How do i set up the timer for a hb65r
Intermatic HB series timers have on-off trippers that push all the way down onto the dial.
Then you rotate dial until current time lines up with arrowhead located on inner dial.
Plug timer into outlet. Turn ON your lamp and make sure bulb is good, plug lamp into timer.
Open following link for step-by-step instructions with illustrations for setting analog timers:
Jul 16, 2011 | Hardware & Accessories
How do I set a plug in timer GE 24 hour Model 15075? There are tiny switches for every hour and can be pushed towards the inner circle or pushed outward. And there is a turning arow near the center and a...
Following link has a close-up photo of on-off pins on GE 15075 timer
http://waterheatertimer.org/GE-timers-and-manuals.html#15075
Pins are located around timer dial
The pins divide 24-hour day into 1/2 hour segments
Pins are out for ON
Pins are inward for OFF
Notice that numbered dial is divided into dark and light areas ... the dark areas are PM, light areas AM.
For example you are connecting chicken coop lamp to this timer.
Turn lamp on and make sure bulb is working.
Plug lamp into timer.
Set pins in and out as follows: all pins outward between 4:30 pm on light part of dial to 8:00 pm on dark part of dial. And then set all pins outward between 5:00am on dark part of dial to 7:00 am on light part of dial.
Move switch located on top to TIMER ON
Manually rotate timer dial clockwise to see lamp turn on and off.
Lastly, set current time: Manually rotate timer dial clockwise until current time lines up with arrowhead located on inner dial. So if current time is high noon, then rotate dial until 'sun' symbol located on light part of dial lines up with arrowhead.
As time passes, the timer dial rotates, and the pins click circuit on-off.
To override timer, move switch to outlet-on.
Jan 09, 2011 | General Electric GE 24-Hour Timer, 2-Pin...
How do I set the woods outdoor timer model #59730
Woods 59730 is24-hour 6-outlet yard stake with dial located on top
This timer is identical to GE15107 yard stake
Manual.
http://waterheatertimer.org/pdf/GE-15107-outdoor-timer-manual.pdf
If this is not your timer, look at following page to identify your timer
http://waterheatertimer.org/Woods-timers-and-manuals.html
Add a comment any time
Timer instructions.
Set current time by rotating dial until time lines up with arrowhead located on inner dial
There are segments located around dial.
Look at inner dial > segments are located just outside the inner dial.
Timer comes with segments pushed inward.
To set timer to turn ON, pull segments outward for hours you want timer ON.
All 6 outlets are controlled by timer.
Last step:
There is override switch located on inner dial.
Move switch to TIMER for timer to operate.
Dec 09, 2010 | Woods Outdoor Lighting Timer
How do you program a Tork 602A timer? I can't get mine to cycle on and off at a desired time.
The Tork 602A mechanical outdoor timer with 2 grounded outlets.
Tork 601A and 602A manual
http://waterheatertimer.org/pdf/Tork-601A-Manual.pdf
Manual has images of timer that will help.
Plug timer into outdoor outlet.
To set current time, rotate dial clockwise until current time lines up with arrowhead located on inner dial.
Dial is divided into light and dark sections that represent day or nighttime hours.
Reset time after power outage.
96 pins located around timer dial are used to set on-off times.
Each pin represents 15 minutes in 24 hour day
Move pins in-or-out with fingernail or ink pen to set timer on-off functions.
With Tork timers, usually when pins are out, timer is ON.
When pins are in, timer is OFF.
To double-check pin setting, manually rotate timer to watch when lights turn on-off.
Set multiple ON/OFFs each day.
Change on-off times by resetting a pin or two.
Timer repeats every 24-hours.
Manual ON/TIMER switch is located on inner dial.
Set Manual switch to TIMER for programs to operate.
To override time and turn on Load, move override to ON position.
Dec 09, 2010 | TORK 601A 24 Hr Mechanical Outdoor Timer ...
How to set a GE outdoor timer product ID 51587 ?
GE 51587 has same instructions as Tork 601A single-outlet outdoor 24-hour mechanical timer.
Move pins in-or-out with fingernail or pen to set timer on-off functions.
With GE timers, usually when pins are out, timer is ON.
Manual ON/TIMER switch located on inner dial.
Set override to timer for program to operate.
Dec 06, 2010 | GE 51587 MultiEvent Timer
How do you set the timer
You posted under mechanical outdoor timer with time dial located on face.
If you have different timer, add a comment.
Instructions:
Rotate dial clockwise until current time lines up with arrowhead located on inner dial.
There are segments or pins located around outer edge of dial.
If timer has segments.
Pull these segments outward, or leave them in place to set on-off times.
Pull out a few segments and then rotate dial clockwise to see if lights turn on or off with segments out.
Then pull out segments for the times you want timer to turn on-off.
If timer has pins.
Click pins outward, or leave them in place to set on-off times.
Click out a few pins and then rotate dial clockwise to see if lights turn on or off with pins out.
Then pull out pins for the times you want timer to turn on-off.
Some timers also have an override button located on inner dial or somewhere on body of timer.
Move this switch to TIMER or AUTO, depending on your timer
Dec 05, 2010 | Stanley 38445 TimeIt 24Hour Daily Outdoor...
I didn't get any instructions with my timer. It is a tork 601A I don't know how to set it. I think it looks great and just what I'm looking for. The case was sealed but no instructions. Thanks J Seel
Tork 601A outdoor timer manual:
Timer has 1 125Volt receptacle located on bottom of timer
96 captive tabs located around timer dial allow times to be set each 15 minutes.
Minimum time setting is 15 minutes.
Maximum time setting 23 ¾ hours.
Dial is divided into daylight and nighttime hours.
Nighttime PM hours are on dark background.
Daylight hours are on light background.
To set timer, rotate dial clockwise until current time lines up with arrowhead located on inner dial. Reset time after power outage.
To override time and turn on Load, move override to ON position. To use timer functions, move override to TIMER position
Dec 02, 2010 | TORK 601A 24 Hr Mechanical Outdoor Timer ...
Can't set inner dial on merona watch
You just remove one of the links. I don't think there's a way to set the inner dials. I think it's just for show.
Oct 04, 2009 | Watches
Hardware & Accessories Logo
16 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
