Question about Dryers
6" of water in basement due to sump pump failure during electrical outtage (Super Storm Sandy). Appliances in water for 48 hours, both unplugged and gas shut off to dryer. What damage can I expect?
  • Kathy DeFilippo Nov 09, 2012
    The above appliances are a LG HE Washer Model#WM1832CW and a LG HE Gas Dryer Model#DLE2532W Both appliances were unplugged when the water came into the basement. Have not tried to run appliances since. Will have a technician in tomorrow morning to look at both appliances. Anything I should be aware of?
    Top Expert:
  • Dryers Master
  • 9,472 Answers
Just make sure they are dry.
Posted on Nov 10, 2012
Illeagle
  • 525 Answers
SOURCE: Our dryer, described below, takes
Your complaint is:"Our dryer, described below, takes between 4 and 6 hours to dry, though it's advertised as "heavy duty" and "extra large capacity.""
White Kenmore 5.8 cu. ft. Super Capacity Gas Dryer
Sears item# 02690412000 Mfr. model# 90412
Based on the information provided above, I am unable to provide a positive solution to your issue. Your model number is incomplete! I have provided some common solutions to help guide you in your search. This information is for a non-specific brand model, gas dryer.
This link, http://www.repairclinic.com/SmartSearch/SmartSearch.aspx, provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Just follow the links to navigate through the site.
You will need to enter the model number stamped on the manufacturers product information data tag, located on the unit, and not in the User’s Manual. to access your product information.
It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these:
Vent
Flame sensor/gas valve
Internal ductwork
Cycling thermostat
Lint Filter Vent: Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance. Also note that, to maximize drying efficiency, the vent should be as short as possible.
Flame sensor or gas valve coils: This is the most likely cause. Click links below. http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=3449&PPStack=1 http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=3229&PPStack=1 There's a flame sensor near the igniter. If it's defective, the gas may shut off prematurely. Another common problem occurs when one of the electrical coils on the gas valve fails intermittently. If this happens, the flame shuts off before the thermostat sends a signal, which can greatly prolong the drying time. If the sensor or the coils are causing the flame to shut off, replace them.
Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 14, 2008
rickzilla
  • 706 Answers
SOURCE: MAYTAG GAS DRYER TUMBLES BUT NO HEAT (FRONT LOADER 6 YRS. OLD)
Hello maryfitgera,
It certainly sounds like you are not getting a flame established in your dryer. That can be one of several components such as a non-resettable thermal fuse, gas valve assembly or control relay to that gas valve assembly. Unless you are well versed on how to work on these kinds of components, I suggest you just call in an appliance tech or.. let me know if you want to attempt diagnosing and repairing it yourself. Be advised that there are elements of danger in so doing. Let me know how you want to procede on this and I'd be happy to walk you thru it..
Regards,
Rick
Posted on Nov 24, 2008
  • 833 Answers
SOURCE: dryer won't run.
First, there is an excellent chance you have some kind of flood damage insurance.  It may pay for part of the repair.  You did not tell us what is not working but I'll guess it is the motor.  On many models, there is a switch on the motor which will not allow the elements to heat unless the motor is powered and running.
Posted on Dec 19, 2008
kachbibi1
  • 979 Answers
SOURCE: dryer won't start when timer button is pushed in
Hopefully, the moisture in the air didn't affect the timer. You may want to put some WD 40 on it. I would check all the wiring first. I assume you reset the breakers, checked the receptacle, especially if it is near the floor. Look under the top and near the drum and check the thermal overload.
Posted on Feb 06, 2009
  • 512 Answers
SOURCE: flooded and not heating now
There is no pilot light. You probably got water into gas jets, also all electronics to ignitor need to be dryed. Also blow out all gas parts. If dryer was plugged in at time of flood you could have shorted one of the thermal switches behind back cover. Check all of this I wrote.
Posted on Aug 17, 2009
Testimonial: "thanks for the wonderful and insightful help"
Kohler 3810 toilet wom't flush
Check and see if the handle or the chain inside the tank is broken. If it is, find out the make and model and get replacement. There are many different types of handles out there. Some universal handles won't work, so bring the handle with you when you buy a new one..
Mar 24, 2017 | Kohler Plumbing
Sump pump pumps fine but won't kick on when water in hole. I've installed new float switch to no avail.
what size is the sump? Is it for waste or seepage? What is the make and model of the unit and the float switch?
Feb 24, 2017 | Water Electrical Supplies
Frozen sump pump ejector
what part of the world do you live in
Jan 12, 2014 | Washing Machines
My pump won't turn off
If the sump (where you catch the water) was dry, your pump might be air bound.
You say it will not shut off but you dont say if it is pumping. My guess it is is not. You have a local switch, i.e. integral to the pump, right? Not a float switch.
Do this, fill the sump, make sure the switch opening is clear (it works on water pressure) and make sure there is no air trapped inthe pump housing.
I hope this helps.
In my bar situation, I use a float switch and I pump up about 2 feet where the water goes into a stand pipe equipped with a vent. The stand pipe feeds into a hose and leads to a sump elsewhere in the basement where the water is pumped over the side (sorry, that was the sailor in me coming out).
Feb 21, 2010 | Lincoln Lubrication 917 Heavy Duty...
Dryer wet due to flooded basement
if it was p[lugged in you might have to replace the circuit board,, they can conduit electricity from one circuit to the other in water
Apr 30, 2009 | Kenmore 62602 Electric Dryer
Sump pump drain
Storm sewer or rain water run off area. In other words , almost anywhere where it won't come back in.
Mar 12, 2009 | Genius Wayne Submersible Sump Pump With ...
Dehumidifer seems to run constantly
With that low of a setting it will most likely be kicking in alot more often. Most people run their dehumidifiers between 60-65%. It is a matter of preference. Also some basements hold out moisture more than others. There could be alot of variables affecting this. One thing you need to make sure is that you have the correct placement. Make sure you dont keep it near the sump pump or any other standing water because those areas have more humidity due to the water being there. Also make sure it is not in an area like a laundry room because when your washing machine despenses water it is despensing moisture into the air. I try to keep it at a central location if at all possible and away from areas that have water. If you found this solution helpful please rate it when you get a chance. Thanks - Tech101
Sep 06, 2006 | LG Goldstar LD65EL Dehumidifier
Dryers Logo
144 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
