For the past month my Kenmore HE2 frontload washer has been completely shutting off in the middle of the cycles. Once in a while it would complete a cycle, but very few times. When I push the power button it comes back on, but not on the wash cycle that it had been on. So I have been running it as long as it would go,and if it stopped in the wash cycle, I would turn it back on , set it on rinse,spin drain. I would turn of the 2nd rinse if I just needed to spin it out and I would do this until the load had been washed. But whatever cycle it was in, wash, rinse spin,etc. it would stop... never at the amount of time just whenever. Last nite when It turned off, I went to turn the power back on and nothing happened. So now, my clothes are locked insided until I can get up behind the door and release th lock. ANY idea what is causing the shutting off during the cycles? Ive cleaned out the pump (not the hose tho) I've checked the inlet valves, and the faucets. Just recently it would flash F20 or F21 and even Sd for too many suds which I know thats not the problem. Please help! I would like to be able to repair this myself.
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Nov 10, 2012
  • 188 Answers
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
cbrown801
  • 3 Answers
SOURCE: washer wil not spin or drain out after cycle completed
sounds like drain is plugged. this is a fairly easy fix,and you actually get paid to do it. unscrew the bottom panel of your washer should be 3 screws on the very bottom then you will see a white plug that is about 2 1/2" unscrew it (make sure you have a bowl under it water will leak ) and pull it out. this is where you get paid you will find all kinds of change and junk just clean it out reinstall and your clothes will be a lot drier after the spin cycle
Posted on Mar 30, 2009
wheelshot
  • 102 Answers
SOURCE: Kenmore HE2 Frontload Washer will Not go into spin cycle
Could be that you have something in the pump. Remove the bottom panel by removing 3 screws and you will see a round cap facing you in the center of the washer at the bottom. there will be alot of excess water behind this cap so get ready with plenty of towels. Unscrew the cap as you would the gas cap on your car and all the water in the lines and in the machine will come out here. Inside here you may find a number of things. Some of the things I have pulled from them are ...coins, socks, pencils, underwear, underwires to bras. The list goes on and on. Or you may not be using "he" detergent. Use only "he" powder detergent. Use vegetable oil to remove excessive sudds build up then use 2 cups of vinegar to clean the machine on whitest whites seting.
Posted on Apr 02, 2009
  • 3 Answers
SOURCE: Clothes remain dripping wet after the wash cycle is complete.
I assume you have removed the lint filter at the bottom of the machine and cleaned it out to make sure the pump is not stalled on a 1 pence or bra clip. Can you hear the motor start to spin? If not its probably because the water level switch is gunged up at the bottom of its rubber tube where it comes from the drum. Remove the top of the machine and locate the pressure switch - usually a round black or white device about 80 to 100mm across with a rubber pipe on a small spout 8mm diameter. Take the pipe clip off using pliers to compress it and move it back down the pipe. Remove the pipe and blow hard down the pipe to try and clear the blockage - you will hear bubbles blowing in the bottom of the drum water. Also you could very very gently blow into the switch stub pipe and listen for it changing over - clicks usually twice each way - blow - two clicks, release - two clicks. Restore swtch pipe and try the machine again. Good luck.
Posted on Apr 03, 2009
  • 6 Answers
SOURCE: Kenmore HE2 won't finish spin cycle
you have blockage in you drain plug. to solve this problem you'll have to remove the lower front panel of your machine by removing the 3 (1/4") screws on the vary bottom of the machine. once the panel is removed you'll see a 1 1/2" white PVC drainage plug. turn the inner plug to the left in till open. (WARNING ALL THE WATER IN THE DRUM WILL DRAIN THOUGH THIS PLUG) remove debris likes socks or everything that's there replace the panel and your all set.
Posted on Jan 19, 2010
Lights keep flashing and door locks without finishing cycle
Kenmore HE2 Plus Front Load Washer Keeps unlocking ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
flashing prewash and add garment lights My HE2 Plus will fill with water, but when ...Kenmore HE3 2plus wont finish cycle Washer wont finish the last1 minute of cycle. ...We ran a load twice and it still did not unlock. du is the code for cannot ... Why does the door keep unlocking and locking in between the drum rotating?
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
https://www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your Admiral Top Load Washer that has these following symptoms: Not Completing all Cycles ...
Washing machines - Ariston
Jan 05, 2016 | Washing Machines
Why does a Kenmore washer not finish the cycle?
Washer Repair - Not Advancing -Repair & Diagnostic ...
? 8:30
https://www.youtube.com/watch?v=IEr9A7uhdN8
Repair your Kenmore Top Load Washer suffering from these following issues: Will Not Advance Past Rinse ...
Kenmore washer doesn't complete final spin cycle - ApplianceBlog
www.applianceblog.com/.../31894-Kenmore-washer-doesn-t-complete-fi...
May 16, 2012 - 9 posts - ‎2 authors hello, my kenmore washer doesn't complete the final spin cycle. i ... Does it stop in the middle of the final spin cycle or does it not go into the ... FIXED Kenmore Washer - Not finishing the spin cycle
Dec 20, 2014
FIXED Washing Machine Does Not Complete Cycle ...
Mar 14, 2013
FIXED Kenmore washer won't spin out all water from ...
Jun 27, 2009
FIXED GE front load washer WCVH6260F0WW stops ...
Jul 2, 2007
More results from www.applianceblog.com
Nov 05, 2015 | Kenmore Washing Machines
HE2 Plus Washer starts then shuts off immediately.
Aren't microprocessor controlled appliances wonderful? Especially when the code is flawed! No wonder the space program bit the dust!
May 12, 2017 | Kenmore HE2 Plus Front Load Washer
How to clean drain pump on kenmore connect washer
Good morning I ampretty sure that I have answered this more that once.
Kolbrun
Nov 28, 2011 | Kenmore HE2 Plus Front Load Washer
I have the Kenmore front load washer HE2. How do I use the clean washer cycle.
Hello, welcome to FixYa.
In order to perform a "clean" on the HE2 is as follows...Read these instructions completely before beginning the cleaning process.
**If necessary, the cleaning cycle may be interrupted by pressing STOP. This will stop the cycle. A RINSE/SPIN cycle must then be run to thoroughly rinse the remaining bleach from the unit. Failure to do so will cause damage to the unit and clothing added to the next cycle.**
Begin procedure
1) Open the washer door and remove any clothing or items from the washer.
2) Be sure the door is closed.
3) Open the dispenser drawer and immediately add 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment.
NOTE: Do not add any detergent to this cycle. Use of more than 2/3 cup (160 mL) of bleach will cause product damage over time.
4) Be sure dispenser drawer is closed.
5) Select the CLEAN WASHER cycle.
6) Press START.
NOTE: The basket will rotate, then the door will unlock, lock again, and then the cycle will continue. The machine will not fill, but the basket will rotate while the washer runs a short sensing cycle. This will take approximately 3 minutes.
7) The cycle will determine if clothing or other items are in the washer. a) If no items are detected in the washer, it will proceed to step 8. b) If any items are detected in the washer, all cycle lights will flash and "rL" or "F/34" will be displayed. Associated LED status lights will remain lit. The door will then unlock. Press STOP to cancel the failure code. Then repeat steps 1, 2 and 6 to start the cycle again.
8) Once the cycle has begun, allow the cycle to be completed.
9) After the cycle is complete, leave the door open, slightly, to allow for better ventilation and drying of washer interior.
Good Luck and thank you for choosing FixYa. Please take a moment to rate the info I provided and a short testimony is appreciated.
Regards,
Macmarkus :)
Aug 14, 2011 | Kenmore HE2 Plus Front Load Washer
Kenmore HE2 washer stopped in teh middle of the washing, no power and can not open the door. Please help me in opening and fix it?
All frontload HE washers have a rip cord you can use to manually open the door but try to clean out your pump filter first. Your tech sheet is also there behind the service panel. Simply going by the diagnostics and cleaning out the filter could save you a bunch od money. Here is a nice video which shows how. H.E. PUMP FILTER CLEANUP
Dec 13, 2010 | Kenmore HE2 Plus Front Load Washer
My washer stops in the middle of the cycle and displays F-1 and after I have to set it on the rinse / drain cycle to complete. Today for the first time it also displayed 5d at the end of the cycle.
5d or Sd means too much detergent was used. Try the following
Run the unit through a RINSE/SPIN cycle.
Run a NORMAL cycle without adding any detergent.
This should clear the unit of the excess detergent.
Jun 29, 2010 | Kenmore HE2 Plus Front Load Washer
How do you clean the inside of your Front Loading washer?
This can be accomplished by running the washer empty for a quick rinse cycle. Add an entire cup of bleach at the start of the cycle. The bleach is effective at destroying organisms, such as mold and bacteria. However, running it once will not be completely effective. I suggest pouring another cup of bleach into the wash tub, after the cycle has completed. This will leave bleach as the standing pool and should prevent the growth of mold or bacteria. However, if you do this, before doing a load of laundry you should run an empty rinse cycle again, to avoid damage to the clothes from the bleach left standing in the wash tub.
Oct 09, 2009 | Kenmore HE2 Plus Front Load Washer
Washing Machines Logo
60 people viewed this question
Top Washing Machines Experts
