Question about Kenmore 65924 Electric Dryer
LG HE gas dryer and washer 8 - Kenmore 65924 Electric Dryer
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
Could you please describe the problem you are having a little better?
Posted on Nov 10, 2012
Hello my dryer doesnt work properly it runs
The valve resistance is 1995 ohms and the ignitor is 185.
Inspect the dryer venting from the rear of the dryer to the outside vent hood of the home.
If there's a restriction in the vent--the clothing in the dryer takes longer to dry.
When the dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
When laundry is near dry--any Time Remaining on the control panel that is *not* needed will be eliminated---except for the last 6 minutes.
The final 6 minutes of any automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a dryer *counts down* to the last 6 minutes but the laundry is still not dry--the computer will allow the dryer to run until the laundry has dried or defaults (not drying within the additional time allowed).
Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dryability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry.
LG gas dryers are more sensitive to venting length and air flow resistance. The gas burner can cause a rapid increase in temperature compared to an electric burner.
Rapid temperature rise in a gas dryer leads to premature burner shutdown (longer time required to dry laundry).
The gradual temperature increase of an electric element is more "forgiving" in homes where the dryer venting is less than ideal.
Problem:
The dryer has an auto dry feature which never fully dries the clothes so we wind up manually setting the dry time to an hour
Solution:
LG gas dryers are VERY temperamental in long vent set-ups. If fabric softener sheets are used in the dryer--clean the two stainless steel strips of metal on the lint filter housing with a SCOTCHBRITE PAD--scrub back & forth several times to remove the waxy residue from the fabric softener sheets. Most,if not all manufacturers do *not* recommend using sheets in dryers that have a moisture sensor (electrodes).
However--using a SCOTCHBRITE pad keeps the wax off those sensors which can be seen if looking *into* the dryer drum and at the lint filter housing.
If only *liquid* fabric softener is used in the washer--clean the dryer sensors once a month. Liquid softener also contains wax which can slowly accumulate on the dryer sensors from the laundry washed in the washer.
LG dryer manual
Dec 13, 2010 | LG D2526 Gas Dryer
My lg tromm DLG69885 gas dryer is not heating; otherwise it works fine. Dry light flashes cooling light stays on solid
I am using LG Tromm DLE2514 washer dryer. It 's running but didn't dried the clothes. I clean it's lint but still it's not working. The one thing i notice now is it's drying light is blinking and cooling light is turn on all the time during the cycle. So what's the problem with my dryer?
May 20, 2010 | LG DLG5932W Gas Dryer
Not enough heat
You may need to adjust the air flow on your dryer vent.
When an LG dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
The final 6 minutes of any LG automatic cycle is for cooling down the laundry before the dryer ends the cycle.
Problem:
Solution:
LG DRYER SERVICE MANUAL
LG PARTS
May 11, 2010 | LG DLG5988 Stainless Steel Gas Dryer
Lp conversion for LG dryer
After removing the three screws which pass through the L bracket into the back of the dryer:
Stand in front of the dryer and (using the palms of your hands) give the top a sharp push back on the dryer top at the left and right side of the top. The top should slide back 1 to 2 inches. Now lift the top off.
If you post again with further questions, make sure to post under the model number you have. (you posted using a combo washer / dryer, and stated you are converting to LP, which combo units are not gas.)
Apr 18, 2009 | LG WD-3243RHD Front Load Washer / Dryer
LG gas dryer model # DLG5988B won't heat
turn the gas on or you might have air in the line.
if that dont work check out the ignitor
Dec 09, 2008 | LG DLG5988 Stainless Steel Gas Dryer
Natural gas to propane conversion LG dryer
You posted under a combo washer / dryer WD-4343RHD.
For a gas dryer, conversion is to replace Nat gas orifice with LP one (the LP orifice has a air hole going cross ways through it) plus screwing the regulator blocker (brass slot head screw on top of the gas valve) all the way down (if you missed that step, I would expect your symptoms). Also, make sure you have a good vent with strong air flow at the outdoor outlet. If poor vent, short cycling may occur.
Nov 22, 2008 | LG WD-3243RHD Front Load Washer / Dryer
Stakcing Issue
   Front load washers require a rock solid floor.  Anything less will add to vibration and noise.  If you feel the washer spinning when standing in the room the floor is not solid enough.
   Make sure all 4 legs are solid on the ground and that they have the lock nuts tightened.  When unit is spinning try running a front leg up and down a little and see if this changes the sound.
Oct 23, 2007 | LG DLG2524 Gas Dryer
HOW TO INSTALL THE BELT ONTO A LG DRYER MODEL DLG2532w
Connect Gas Supply Pipe
(Gas Dryer ONLY)
For further assistance, refer to section on Gas
Requirements.
1. Make certain your dryer is equipped for use with the
type of gas in your laundry room. Dryer is equipped at
the factory for Natural Gas with a 3/8” N.P.T. gas
connection.
2. Remove the shipping cap from the gas connection at
the rear of the dryer. Make sure you do not damage the
pipe thread when removing the cap.
3. Connect to gas supply pipe using a new flexible
stainless steel connector.
4. Tighten all connections securely. Turn on gas and
check all pipe connections (internal & external) for
gas leaks with a non-corrosive leak detection fluid.
5. For L.P. (Liquefied Petroleum) gas connection, refer
to section on Gas Requirements.
Oct 15, 2007 | Kenmore 63932 Electric Dryer
Kenmore 65924 Electric Dryer Logo
19 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
