Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Error code f-01
Machine drains does not spin, but flashes error code f-01
  • dennispennan Jan 05, 2009
    thanks, already took, out motor, but motor seems to be sealed cannot see were, bruses go
  • Hotpoint Master
  • 3,463 Answers
Error code F01 indicates a short circuit moTor triac.
This is part of the electronics that control the motor, it can be caused by worn brushes in the motor or a faulty pcb .
to check the motor brushes, remove the rear panel,, remove the belt and undo 2 screws that secure motor, lever motor back with a screwdriver or similar, unplug the motor leads , and remove the motor.
You will see the brushes at the armature end.
remove and inspect, you should see if they have shorted by discolouration of the armature.
If you clean the armature with emery paper and it looks o/k, then you can try fitting new brushes, but there is no guarantee that it will work,as the pcb may have shorted.
This being the case then it could be quite expensive to put right.
Plz rate my solution.
Thanks.
Posted on Jan 05, 2009
My LG washing machine is showing OE fault what do it mean ?
OE means uneven load.
If you can open door, put a dry towel in with the washing and try spinning again ...
Nov 20, 2017 | LG Washing Machines
Replaced CCU, Sears washer still will not run
Suggestion: Unplug washer from mains. Open up the machine, disconnect and refit all connectors with wires one by one. Could be some loose connection somewhere. Also helps in the long run
Click if helped.
Mar 29, 2013 | Washing Machines
The waching machine won't do anything when turn to rinse or wash, it only starts to rotate when turned to spin? the machine is only 2 1/2 years old
Whats the exact brand and model.Is it front load or top load.Is it showing any error code on display or any flashing light error code.Is it draining properly or not draining.Also is it making any kind of noise when turned towards spin mode.------------------- Keep updated with the details.Thanks.Helpmech.
Jan 30, 2011 | Kenmore Kitchen Ranges
Kenmore Elite Oasis HE washer error code F2
The error code must be cleared first to make the machine back into operation. You have to press the PAUSE/CANCEL button twice to clear the error on the display.
The only filter the machine has is the one you removed to clean the pump. When the error is cleared, you can check the pump whether it is operating properly or not by running the diagnostic test.
Diagnostic Test Mode Procedure
  1. Close the door.
  2. Select the DRAIN/SPIN.
  3. Select NO SPIN by pressing the SPIN SELECT button.
  4. Press RINSE/HOLD or PREWASH OPTION button four times within five seconds.
  5. "C:00" will show on the display indicating that the door is locked and the diagnostic test starts.
  6. Press the button you pressed in step 4 above two times. "C:01" will show on the display and the machine starts to fill.
  7. Press PAUSE/CANCEL button two times when there's enough water inside the tub to stop the test.
  8. Observe the water level falls as the pump starts draining the water. Replace the pump if the water inside the tub does not drain. You have removed and cleaned the pump so you can easily replace it too.
Please inform me about the result of the diagnostic test and if you still need any assistance regarding this problem.
Jan 20, 2010 | Washing Machines
The machine wont spin when in spin cycle and
try cleaning out the coin trap/drain hose that is underneath the machine
this is also the error code E20 which sometimes the machine will start flashing
Jan 15, 2010 | Frigidaire Affinity ATF7000E Front Load...
Error code f-01 on hotpoint washer dryer aquarius model wd 640
f-01 means there is a motor problem.
may be the motor and/or the circuit board that controls it.
Jan 05, 2009 | Hotpoint Aquarius WD640 Front Load...
THE MODEL # IS WFW8300S WHIRLPOOL DUET SPORTS WASHING MACHINE
a power glitch can cause this promblem first push pause cancel twice to clear this error code then try the washer on drain spin and listen for the pump to come on if it does then clear the machine by pause cancle twice then try to start again if code resets then the promblem is most likely the ccu or the board but try clearing the error first if that dont work get back with me and we will run diagnostic mode
Dec 28, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
253 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
