Question about Latte Communications Latte Ice Smart 8 Gb Smart Media Tablet
Reset ice smart - Latte Communications Latte Ice Smart 8 Gb Smart Media Tablet
The android process in my smart tv has stopped - how can i fix this problem
Try going into TV settings and reset to factory state.
Oct 17, 2017 | Tablets & eReaders
Won't turn on- we bought a new battery and charger and no luck
you need to plug it in for 5 seconds,,take out charger and replug repeating this for about 10 mins.keep repeating,it will charge eventually
Feb 04, 2016 | Samsung Ativ Smart Pc 500t Tablet With...
Having trouble uploading manual
My suggestion is to do a factory reset it should solve your major issue.
May 30, 2015 | inDigi 7.0-inch Android 4.0 Smart Phone...
How can I get my Samsung Galaxy Tablet to turn on. The battery is fully charged.
There is usually a method such as holding the on button for a longer period of time. If it is easy to do the other thing that I've found with all sorts of "smart" devices which turn "not-so-smart" is to remove the battery for a minute or so, then put it back in. Many times the unit will turn on as soon as the battery is reinstalled and work correctly again after that. Last ditch effort, unless someone knows about the Galaxy, is a hard reset, there may be a reset button somewhere on the unit, I don't think the Galaxy has a reset button. If the unit still does not turn on it may need servicing.
1. Try the on button for 15 - 20 seconds if you know it is charged
2. Try charging for an hour or two then the 15-20 second hold on button, #1 above.
3. Removed battery (I'd measure the battery voltage while I have it out) wait ~1 - 2 minutes & reinstall the battery. If it doesn't turn on by itself try #1.
4. Nothing works start a service ticket with Samsung, URL:
http://support-us.samsung.com
You might try searching there as well for an answer to see if there's anything I missed.
Jan 31, 2015 | Samsung Galaxy Tab Tablet PC
I forget my pattern lock?so how will get return my password
You will need to do a factory reset:
1. With the device off, press and hold Volume Up and Power.
2. Release the Power button when you see the Samsung logo, but continue to hold Volume Up until the recovery screen appears.
3. Use the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection.
4. Press Volume Up continue.
Nov 02, 2013 | ASUS MeMo Pad Smart 10
I forgot my password for my hisense smart tablet how do i reset it or open it again?
Have a hisense tablet and forgot the passcode how do I reset it I tried the reset button but it just turns it off want get past the passcode
Oct 20, 2013 | Tablets & eReaders
Forgot pattern for my konka t640s smart phone
i for got my partten password to my konka phone T640s need help to unlock it or reset it
Aug 06, 2013 | Tablets & eReaders
Hi, I bought Smart Epad 7" I had error of The
You can restore your epad to factory settings by going to the settings menu > privacy > Factory data reset. and then your epad should be running normally again.
Mar 04, 2011 | Tablets & eReaders
Latte Communications Latte Ice Smart 8 Gb Smart Media Tablet Logo
71 people viewed this question
Top Latte Communications Tablets & eReaders Experts
Are you a Latte Communications Tablet and eReader Expert? Answer questions, earn points and help others
