Question about Archos AV 700 160-Hours Video Recorder
Display shows very very faint image. Can't turn device off.
  • 691 Answers
Sounds as though your back light for the LCD may have gone. It is not a job the DIY repairer can easily complete therefor you should return it to Archos or a certified repair center for an estimate. If it is in warranty Archos MAY cover it, though if they deem it has been dropped will likely charge you.
Posted on Jul 26, 2007
Have power but no Display
Bonnin, Can you see a faint image on the screen? Have you tried to hookup an external monitor?
IF you can see a faint image on the screen, and a normal image on the external monitor, you have a bad power inverter (for the lcd screen) or a bad back light (in the lcd screen).
Take laptop to a shop to have them verify.
Hope this helps.
Nov 24, 2013 | MSI Computers & Internet
Black screen on laptop
When it is in that state, try hooking it up to an external display. Also look for a extremely faint image on the screen. If it's really faint you have a bad back light, if you see nothing but you get a display on an external monitor it's probably the display going bad.
Jun 05, 2013 | Computers & Internet
Screen on my compact laptop went black and I can only turn it on but have nothing but black
If the laptop comes on normally otherwise and is booting to Windows (you hear the normal startup sounds), look closely at the display and see if you can make out a faint image. It often helps to shine a flashlight on the display.
If the display is faint but present, you probably have a bad inverter board in the display. The inverter provides power for the display's backlight, and without the light the display still works but you can't see it. Inverter boards are available for most brands, they're not usually very expensive, and changing one isn't too difficult. A Web search for your brand and model and "replacement inverter" should turn up several sources. There are also YouTube videos showing how to replace the inverter in many kinds of laptops.
It's also possible the backlight itself is bad. If so, replacing the display is usually preferable to trying to replace the light. The light is built into the display and it's very difficult to replace without damaging the part or the display in the process. The display can be expensive, though.
If you're not sure that the computer is working, try starting it with an external monitor connected. If there's no display then, there's something wrong with the system board that's preventing the machine from starting up. Get that fixed, and it will probably fix the display trouble as well.
Mar 10, 2010 | Computers & Internet
My 2 year old Syncmaster 740N often has multiple faint images behind text in any program and multiple faint desktop icons making it look "smeared"; some days worse than others; resolution is correct at...
Well in monitor you can do one thing - disconnect the monitor cable*(VGA Cable) from the tower and chk still if u have the same faint screen that means monitor gone bad if not than uninstall the Grapics Driver and shut down computer... if u have internet than restart and go to device manager ( Run - devmgmt.msc) under display adapter right click on grapics name and update driver.
Oct 14, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
I turn the computer on and the monitor will stay dark even though it is turned on. Then I turn the monitor on and off a few (10) times and eventualy the poicture comes through. I have the monitor hooked to...
It may be caused by 2 reasons:
1. The notebook is not correctly configured for an external display - you may need to install the display drivers or update it.
2. The backlight inverter on the display may have problems and need repairs. Check if you can see a faint image in the screen.
Oct 10, 2009 | Samsung SyncMaster 203B LCD Monitor
I have a FPD 1830 flat screen monitor not displaying picture
Send the monitor. It's a power supply problem. My 15.4" LCD has the problem, too, whenever I move the monitor down, it powers off, and the menu disappears as well, but I'm going to fix the screen.
Jul 08, 2009 | Gateway Computers & Internet
LCD screen is faint XPS M140
You backlight is failing. That is the bulb that provides the brightness to the screen. You need to replace bulb which is very tricky to do unlesss you have experience or replace the screen.
Please rate this if helpful.
Thanks
May 05, 2009 | Dell Inspiron XPS M140 Notebook
Compaq presario 900 lcd not working, shows faint image
out put connection from the video card to the LCD monitor is loose or malfunctioning. check the connection that leaves the video card to the monitor, ensure its secure and clean, if still not working then its either the video card or the cable connecting to the LCD.
Dec 11, 2007 | Computers & Internet
Archos AV 700 160-Hours Video Recorder Logo
121 people viewed this question
Top Archos Televison & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Jaime Hernandez
JonSnell Electronic
JonSnell Electronic
Are you an Archos Televison and Video Expert? Answer questions, earn points and help others
