Question about Cajun Injector Electric Turkey Fryer
Cajun Injector Electric Turkey Fryer need replacement 28 qt inner pot
My inner pot has corroded to the point of leaking the oil out... Everything else is in good working condition... I simply need a new inner pot but cannot find where to purchase one.
I need a replacement lid for a 20100809 turkey oil free fryer
[PDF]Masterbuilt Manufacturing, Inc. - s3.amazonaws.com
s3.amazonaws.com/szmanuals/36c0fb04ceed2650509e23dc539e58ad
MODEL: 20100809 ... if service, repair, or replacement of the product is not commercially practical, ... Do not plug in oil free turkey fryer until fully assembled and ready for use. ... Do not place on or near a hot gas or electric burner, or in a heated oven. .... Clean lid, cooking rack, turkey stand, and basket with a damp cloth or ...
Masterbuilt 20100809 Butterball Oil-Free Electric Turkey ...
www.amazon.com > ... > Fryers
Amazon.com, Inc.
Rating: 4.2 - ‎287 reviews
Amazon.com : Masterbuilt 20100809 Butterball Oil-Free Electric Turkey Fryer ...Thermostat temperature control; Tempered glass lid & turkey stand; Roasting ...
Jan 27, 2016 | Masterbuilt 20100809 Oil Free Electric...
How big of turkey will a Morrone TKF 300 A turkey fryer cook.
Turkey Fryer is deep enough to fry a 12 to 14 pound turkey and wide enough to be used as a seafood boiler. Heating element is made of stainless steel. It comes with aluminum bailing basket with adjustable quick drain system, control with safety shut-off and a built in digital control with thermostat and timer. Swing out drain valve for easy draining and clean up. CSA certified.
Deep enough to fry a 12 to 14 pound turkey and wide enough to use as a seafood boiler, the Cajun Injector's Electric Turkey Fryer provides home fried cooking without the mess and hassle of stove top or outdoor methods. Equipped with a 30Qt. aluminum bailing-basket, you can submerge and fry a whole turkey or any other foods you'd like to cook fully covered. When the food is finished cooking, simply lift the basket up with the hanger hook, and allow it to drain over the pan with the adjustable quick drain system. A swing-out drain valve to empties the used oil when its time for clean up and a built-in digital control with a thermostat and timer ensures that the food cooks exactly as you intended. The CSA certified fryer features a clear lid so that you can check on the food without risk of burning and is equipped with a stainless steel heating element for long lasting quality.
Oct 21, 2014 | Grilling
Charmglow s/s electric turkey fryer 28 quart, how much oil is needed for 9lb turkey?
I just cooked 2 fourteen pound turkeys in the oven 3 days ago (just for me) Your turkey is just a baby :) 4 gallons should be fine... maybe less
Nov 26, 2013 | Grilling
How to do cheat
Not sure exactly what you're asking due to a type-O. But, I going to assume your meant "How to do heat".
Admittedly, this is not the easiest electric turkey fryer to start out with, but it does do the job pretty well.
To start heating the oil and setting the cooking temperature, you must do the following.
Press "ON"; then "Temp Heat"; then press the up arrow until it reaches 400 degrees (for frying a turkey). You may have to push a button more than once, because I think the first push is to light up the screen.
Hope this helps you solve your problem and gets you going.
Feb 18, 2011 | Cajun Injector Deluxe (30 Qt) Turkey Fryer
I have been trying to find the pot for the Masterbuilt Electric Turkey fryer since before Thanksgiving. Now with Christmas around the corner, I still can't use my fryer because I need to replace the pot...
Please click on the following link to obtain the part you need for your fryer:
http://www.appliancefactoryparts.com/gasgrillparts/helpcenter/breakdowns/masterbuilt/masterbuilt-20010306.html
The inner pot costs $49.98 but I always suggest contacting online suppliers to confirm they have stock and their shipping times before ordering. Their phone number is 1-800-955-7075, or complete the online help request here; http://www.appliancefactoryparts.com/support/open.php
If they are unable to help you, you should be able to get one direct from Masterbuilt:
Masterbuilt Customer Service:
Phone: 1-800-489-1581
Email: customerservice@masterbuilt.com
The part number you need to quote is 902060010.
These are the only suppliers I can find at present, but please post back if you need further assistance and I will try to find some more suppliers for you.
Regards,
BElectric
Dec 07, 2010 | Vacuums
Tried to use my turkey fryer and could only get a yellow flame. Never had a problem getting that nice blue flame before. Do I have a reg problem or a burner prob??
Check your propane tank first; is it getting close to being empty? Check where the hose connects to the burner, there should be an air adjustment there; it looks like a rotating disc with two big holes on either side, this is turned when the burner is lit to adjust the amount of air mixing with the gas. If it's all the way open, you have a yellow flame, if it's closed all the way you have a blue (but weak) flame. Try adjusting that and if that doesn't work, try a different regulator...it is rare a regulator could cause this but it could cause it; just use that as your last resort.
Dec 03, 2009 | Cajun Injector Deluxe (30 Qt) Turkey Fryer
Missing instruction manual for Charmglow Electric Turkey Fryer
Fry turkey 3 minutes per pound, then add 5 minutes to total cooking time
Nov 26, 2009 | Kitchen Appliances - Others
Cajun Injector Electric Turkey Fryer Logo
69 people viewed this question
Top Cajun Injector Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Cajun Injector Kitchen Appliances - Other Expert? Answer questions, earn points and help others
