Question about Riso RZ220 Duplicator
Risograph 4200 RA - code E-61
Had a small paper jam while running, and now I'm getting an error code E-61 which says I'm installing the wrong drum unit. Are there any clear codes or ways to bypass this?
Also, what might the problem be?
Thanks for any help you can give!
  • 1 more comment
  • JFSPrograms Jan 05, 2009
    It's the same drum unit that we've always used. I just slid the drum out to pull out the paper jam, and when I put it back in I got the error code E-61. I tried switching over to two different color drums thinking it might be a drum problem ... but it's not. They all come up with the same E-61 code.
    The plastic white sensor switch on the right side (that moves up and down when you move the drum handle up and down) is toggling between the E-61 code and an E-52 code (drum unit not installed properly) when I move the handle up and down. It does this with all 3 drums I've tried so it's got to be an internal problem or maybe a bad switch / sensor?
    I'm trying to find out if anyone knows an easy fix, or a clear code that will allow me to keep printing.
    Thanks again! - Mike
  • JFSPrograms Jan 06, 2009
    Somehow this is being incorrectly posted under RISO laser copiers, I guess? As the last person mentioned toner. Anyway, this is a Risograph RA4200, a large digital duplicator that uses ink and masters and prints more like a printing press. I was hoping to find a tech on here or maybe someone that had acess to a tech manuel for the machine. I'm certain it's not dust, or paper, or the wrong drum, or any screws loose, etc ... I'm fairly sure that the sensor or switch has gone bad. It will take a couple of days to get a tech out there, then they'll want to order the part and that will be a few more days, etc. I've seen techs key in codes that can bypass or turn off certain sensors and switches on the machine. That's what I'm really looking for, if anyone knows a specific code to disable that sensor as the machine will not run because it thinks I have the wrong drum in there. Thanks again in advance if anyone knows a code.
  • 15,935 Answers
Look up this fixya expert. I believe he has a PDF file he can send you...
eddy6363
Posted on Jan 06, 2009
    Sergeant:
  • 378 Answers
To clear this error you will have to insert 1 more drum unit as when it will detect the new.u can remove the new and again insert old and it will work.as the printer has detected that this drum unit is rejected so its just telling to replace or not installed properly still after u install it properly.this is very much trouble thing in this machines.u have to go through this procedures.
Posted on Jan 05, 2009
    Sergeant:
  • 367 Answers
Also make sure there are no small pieces of paper in the unit this can cause issues as well. Can of compressed air will help with clearing some of these. Some will need to be removed by hand.
  • Riso Master
  • 13,433 Answers
I would suggest to use the original drum or matching model. Does the current installed drum match the original drum or recommened model?
  • Riso Master
  • 19,396 Answers
Unplug the printer from power, remove the drum unit , put it back in place. This should fix the problem, unless the drum is really faulty.
  • Ginko
    Ginko Jan 05, 2009
    There are also sensors to which the drum connects, they look like metal plate contacts, ensure that they are not dirty with toner, a dirty contact may cause the drum not being recognized.
    Try first unplugging from power for ten minutes, and refitting the drum.
    If that does not work do a complete cleanup of the printer, see: Clean your laser printer safely with these tips
Hp laserjet 4200 will print a 50 page paper path test, print an extra page and then jam.
The paper feed solenoid is sticking. There is a foam material that deteriates over time and becomes sticky. I remove what's left and put masking tape in its place.
Oct 03, 2012 | HP LaserJet 4200 Printer
Risograph pressure roller isnt coming up
Dust on paper exit sensor? (small hole between the exit belts)Sensor blocked or defective?
Sep 12, 2012 | Riso Office Equipment & Supplies
Risograph 3770 Drum problem
Seems the 'synchronisation' between paper feed and drum ist lost. Maybe you have heard a ripple sound? This means the toothed belt has jumped one or more teeth.Remove back cover loose paper feed clutch to readjust the belt accordingly ...
Sep 03, 2012 | Riso RP 3700
A risograph 3770 doesn't print when I say 'test print' and says there is a jam
Maybe it is just some dust at the sensor in the exit path! Clean the sensor in the small hole between the exit belts with a brush ...
Aug 23, 2012 | Riso RZ220 Duplicator
ML 2010 Laser Printer: I HAVE A SAMSUNG 4200 IT IS SHOWING PAPER JAM, BUT...
you may want to check again on the printer.if it show paper jam.
open up the fron door and bnack door. remove the toner and check if there is any small pices of paper still jam in the printer.
if not try and see if the fuser flag is not sitting properly. you might need to do small adjustment.
May 18, 2010 | Samsung ML 2010 Laser Printer
I have a samsung scx 4200 am getting the papaer jam error even when theres no paper jamed up there
Good Day Sir,
when paper jam occurs, Paper jam appears on the display.
Message Location of Jam
[Paper Jam 0] - In the paper input tray
[Paper Jam 1] - In the fuser area or around the toner cartridge
In the manual feeder
[Paper Jam 2] - In the paper exit area
hope this will help you. god bless
Nov 06, 2009 | Samsung SCX 4200 All-In-One Laser Printer
Reset RISOGRAPH GR3750
Check the Power PCB ,maybe some fusies' ve blown
Aug 27, 2009 | Eagle Signal Br1 30min Reset Timer
Paper Jams
clean with a soft cloth and alcool the Paper Sensors, specialy the paper sensor (one under the drum), and also the clean the stripper pad, Pickup roller, Scraper roller, Gide roller, Timing roller in the firts paper feed drive mechanism
If you need the manual instructions post a mail at: Salasidis@sch.gr
Feb 25, 2009 | Riso RZ220 Duplicator
RZ 220 Risograph error code A-16-525 after paper jam indication. No jam was present.
The master is stucked on the print drum,open print drum remove master and try again.
Let me know for futher help.
Jan 26, 2009 | Riso RZ220 Duplicator
78 people viewed this question
Top Riso Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Marius Chiriac
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
