Question about Toys
When taking the crib side down the bottom edge slips out. It can be either side. How can I resolve this to where it doesn't fall of?
    Filmmaker:
    Uploaded 5 video answers.
  • 15 Answers
Looks like something missing, is the crib new?
Posted on Nov 15, 2012
How do I fold down the pack and play and put it back into the bag?
Generally with the Graco's and others I've used, you have to remove the bottom liner (that they lay on), then pull the bottom up, then push a button on the sides to fold up each one. This is a safety precaution so your child doesn't find a switch and break down one of the sides, either escaping or getting hurt.
Hope this helps!!
Comment or Thumbs up me if it does.
Jul 19, 2011 | Cosco Beatrix Potter Playard Crib
Is there a crib recall for the Delta Luv Crib, model 4750-1, 1-17-06?
Yes, please follow the link below for the replacement part order form.
http://www.cribrecallcenter.com/cinfo.asp?recall=2&co=1&m=4750-1&p=90002
If this information was helpful, please take a moment to provide a "thumbs up" rating. Thank you!
Jun 08, 2010 | Delta Luv Delta - Baby Products 5-in-1...
Side keeps falling down
check the hardware on the sides clip may be broken or missing also check to see if ur crib is made by stork craft there is a massive recall or cribs that the sides go down on call 877-274-0277 ur crib might be involved in the recall or u can log on to http://www.storkcraft.com
Nov 24, 2009 | Childesigns Savannah Crib
Crib slide track is broken
I would contact the manufacturer and they should have replacement parts. If it is a storkcraft, then go to Storkcraft.com and go to their parts page.
Feb 17, 2009 | Storkcraft Baby Aspen Stages Crib
My oven door shattered. i bought the glass and the outer trim. i need help installing it
This job is best done by two people, one to hold the glass in place, and the other to operate the screwdriver and position the handle and trim pieces.
The glass is held in place by the handle assembly at the top and a metal track at the bottom.  You remove the glass by removing the handle. Open the door part way until you have access to the back of the door.  The door handle is held in place by two screws on the back (the oven side).  Remove the screws, taking care to hold the handle in place.  Be sure to brace the glass, then slowly move the handle away from the door frame.  Remove the glass.  The side trim pieces will probably fall away from the door frame, although they will probably not fall all the way out.  My advice is to carefully remove them.  Be careful; they have tabs on the bottom edge that hold them in the door frame and these tabs are easily broken.  If yours are still in one piece you might just reuse them.
Remove the old glass panel and clear the bottom track of any debris.  Put the new glass panel in, beginning with the bottom track.  Set the oven handle on the top edge of the glass panel; there are tracks on the back of the handle assembly the top edge of the glass fits into.  Bring the handle toward the door frame, taking care not to let the glass panel slip out of the tracks.   The door handle has two collars that go through holes in the door frame.  Once you've got the collars through these holes, you can put the two screws back in that secure the handle to the door.
Take one of the side trim pieces.  Each trim piece has a narrow edge and a wide edge (like a capital "L"), The narrow edge faces the front and the wide edge faces the side of the door.  Each piece has a corner edge with a little tab sticking out.  These face down.  The opposite end of the trim piece has recessed edges. These slide under the edge of the door handle.  You want to insert this end first, then work your way along the length of the trim piece pushing the narrow edge between the door frame and the glass panel.
Here's the tricky part.  To get the bottom in, the best thing to do is to open (or better yet remove altogether) the drawer beneath the oven to gain access to the screws that hold the bottom track of the glass panel to the door.  Loosen the screw that holds the track in on the same side as the trim piece you're working on; the screws are on the bottom of the track about 1 inch in from the edge. Loosen the screw slightly and pull down on that edge of the trim as you push the trim piece in behind the glass.  Repeat until the trim piece tab slips through the hole for it on the track.  Tighten the screw back in place.
Repeat this process for the other trim piece. If you're patient and gentle, it shouldn't be too difficult.  I just did this myself today (2/7/09).
Good luck.
Jan 24, 2009 | Kitchen Ranges
Kinderkraft crib model 710
On the bottom of the front rail that drops (the drop rail), there are two plastic tension pieces (one at either end) that engage the two fixed, bottom rail slider hardware (the long, narrow pieces screwed top-and-bottom into the lower, inside portion of the tall, upright crib ends). These tension pieces are spring loaded, and the outer edge of each one rides along the outside (i.e., the parent's side) of the two bottom metal rail guides. Their purpose is to supply outward pressure against the lower part of the drop rail - that's what you push against when you press your lower leg upon the bottom of the drop side of the crib to lower it. They insure that when up, the drop side locks safely into place. I suspect these tension pieces are your problem. It sounds like they are improperly installed. Good luck.
Sep 10, 2008 | Kinderkraft Vermont Crib
Getting the canopy off to wash it
Remove/losen the velcro for the bottom of the bed . There are three screws on each side of the base were the music box and volume is. You want to remove the MIDDLE screw ONLY on each side. On each opposite end of the base is a large screw and on the other side is a smaller screw, unloosen the screws and the base of the bed fall off so that you can remove the lining. Remember you only need to remove the middle screw.
Jun 25, 2008 | Eddie Bauer Musical Rocking Bassinet...
The Dorel 3-1 convertible crib model # WM1633
Do not use this crib. This crib broke and caused my infant son of six months to get caught. He passed away on October 16th because of getting caught in this crib. I am trying to getting this crib recalled. Please Please do not use drop down cribs. They are entrappment devices for infants. 3 infants including my son have died in 2008 due to drop down side cribs. Please for your babies sake, take this crib back.
Jun 22, 2008 | Dorel Alexander
Crib assembly
i have a crib with the same model number, except it's not cosco..at least i don't think it is. it's dorel. anyway, i have the same crib i believe, and if you say all the parts and hardware is there, maybe you forgot to put on the stoppers at the bottom of the sliding rail. that's the only thing i can think of. hope it helps...if not..try see if you can contact dorel.
Nov 28, 2007 | Baby Gear
Bassett crib sides falling down
You likely are missing the lower track assemblies. Part # CC (right) and DD (left). These screw into the lower inside legs on the side with the drop down rail to secure the rail from dropping off. See instructions, Step 1 and Step 2.
Call Bassett 1-276-629-6000 to obtain instructions and a parts list for model # 5926-0504 (look on the inside headboard - not the gold label).
Parts can be ordered from Products America 1-800-772-1041
May 29, 2007 | Bassett Parson Ridge Crib
Toys Logo
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
