Please identify the blown off IC in this power board of HCL. 15.6 inch LCD monitor. HCMDLWBT 11 , details not found in web
  • 3 Answers
The power boards from mine looked similar to one another and looked almost the same as yours , I would look at acer or view sonic or other 15.6 monitors and try to match the power board .
Posted on Nov 21, 2012
5 Suggested Answers
firesnake09
  • 2923 Answers
SOURCE: LCD Monitor Acer AL1717 shtting down problem
Aside from the capacitor and IC, there's a relay that you need to change. You need to locate that defective relay on the PCB and replace it.
It would be best to consult the manufacturer of the LCD and get the exact part number of it.
Have a great day!
Regards,
Firesnake09
Posted on Apr 26, 2009
mgroomsn002
  • 76 Answers
SOURCE: HCL LCD Monitor display problem
f54188a.jpeg Bad Capacitors on the power board
Posted on Jul 05, 2009
SOURCE: HCL HCM780M CIRCUIT DIAGRAM
SIR..., regarding monitor...display block characteristics which is operated manually by buttons situated bottom of monitor is anytime coming at the centre of monitor display... The settings block comes on suddenly and we are unable to exit from the same sometimes the block goes off without any action and everything is fine till it is back again and it is come again and again.....by all this i did'nt work on my PC...all result it's useles......please sir giving your suggestion as soon as possible....... This has been happening for the last 1 year and is a real pain Please send some solution
Posted on Jul 27, 2010
electrotech1
  • 1126 Answers
SOURCE: Hannstar IH252HPB 25" LCD monitor has 2 burned
Go to www.partstore.com to get new parts for your set.
Posted on May 26, 2011
Won't turn ON. Found F601 fuse blown on power supply/inverter board. What's the most likely culprit?
Emerson BA17F1F0102 Power Supply Repair Kit LC320EM2
www.shopjimmy.com/emerson-a17f1mpw-power-supply-co...
ShopJimmy
$19.94 - ‎In stock
This Emerson BA17F1F0102 Power Supply Repair Kit LC320EM2 ... board. If the TVhas no power it is most likely because of a blown fuse and failure of other preceding components. ... I tested F601, Q600, R602, 608 and 611, and found them to be bad. ...Power Supply / Inverter Board - Joseph A. on March 4th, 2015.
Common TV Repair for Emerson, Sylvania, Philips ...
? 5:35
https://www.youtube.com/watch?v=nQHWrJJg4Mc
Oct 11, 2013 - Uploaded by Tampatec
... LCD TV repairs for Emerson, Sylvania, Philips, Magnavox,blowing fuses "no power" i recommend a TV service LCD repair kit at ... powersupply power-supply "power supply" powerboard "power board" part2 part 2 pt2 ...
What Causes a Blown Fuse in TV Sylvania LCD - YouTube
? 15:31
https://www.youtube.com/watch?v=4P_0aLDZgBY
Jan 01, 2016 | Televison & Video
Monitor dispaly picture for 3 to 5 second then display gone
From the description one of the inverter transformers have failed, located on the power supply/inverter board.
May 21, 2012 | Samsung SyncMaster 510N (Silver) 15 inch...
Display problam
On the monitor power board you find an IC called push pull transistors,it is usually paired get to read this IC with your miter a pair of this IC must have gone bad.If dictected replace it, then power the power board and it will display normal.Thank you Jesus.
Apr 21, 2011 | BenQ FP51G 15" LCD Monitor
Power light flashes on and off; no image on screen
that only an standby power, you system still not power on, you need to open back cover to check if power supply section work. monitor secondary output. in none you need to replace power regulator IC.
Apr 05, 2010 | Dell E152FP 15" Flat Panel LCD Monitor
NO Bad Capacitors on the power board i have some problem in my HCL lcd monitor, my monitor display is on but at a time the display is gone. when i swicth off and on monitor power the monitor display is on ofter 2 sec the display is gone so that is the problem.
Jul 05, 2009 | ViewSonic VA702b 17" LCD Monitor
Samsung lcd monitor 153V has no display power indicator (green) is ok found 1 ic AE3U1T burnt. is this ic available or has the psu and backlight panel pcb to be changed.. dtgandhi@gmail.com
Samsung 153V LCD Monitor Power Supply Repair Tips
Troubleshooting Samsung 153V LCD power supply is just like troubleshooting those CRT type. This monitor came in with no power symptom. If you are first time repairing this type of power supply, I recommend you to first remove the switch mode power transformer. Then test every single component in the primary section, before you continue to check the secondary section.
You have to be good in testing basic electronic components in order to detect the fault. You can always browse through my website just in case you do not know how to test basic electronic components. If you do not know the right way to check, you might miss out a bad component and this will lead you not able to solve the problem. After carefully checking all the components in the power supply section, I found the filter capacitor do not have any reading using digital capacitance meter (open) , the two round type fuse also open circuit, 1N4744 15 Volt zener diode short circuit and lastly the power IC TOP247F blown!.
Testing the SMPS (switch mode power supply) primary winding with a **** smith fly-back tester, shows green bar which indicates good winding. What we left here were the secondary diode and filter capacitor. Upon checking them with analog meter and ESR meter, found all of them to be good condition. Other area like main board and inverter board also looks okay (Power failure rarely affect these two circuit). Now we have confirmed that only five components found to be faulty.
One by one the components were replaced (except one fuse) and just before you switch on the power supply, make sure you connect a 100 watt light bulb across the live ac line. Once it is done you can then proceed to switch on the LCD monitor to look at the brightness of the bulb.
If it very bright, this suggests that there are still short circuit somewhere in the power section. If it dim or totally goes off, you can now place your red probe to the secondary side to check if any dc present at their respective line. If there are DC voltages present at the output, you can switch off the power, discharge the filter capacitor (for safety purposes), remove the light bulb and connect back the new fuse to its original location.
You are now hundred percent sure that the LCD power supply won
Mar 23, 2009 | Samsung SyncMaster 153V 15" Flat Panel LCD...
Jan 23, 2009 | Computers & Internet
Ccfl inverter board
The most prevalent failure on these boards are the transformers and or the ic that controls the frequency of the lamp drive. More times than not you will find a bad transformer.
srich
May 19, 2008 | Gateway FPD2275W LCD Monitor
Computers & Internet Logo
443 people viewed this question
David Payne
David Payne
