Question about Maytag Refrigerators
Ice maker #12685007 ice gets stuck and will not eject
watugot
  • 290 Answers
SOURCE: Bottom of ice maker/dispenser frosting over
Open the freezer door and look down the ice chute while you shine a flashlite up the dispenser cute from the outside. If you see light around the chute door, it needs to be replaced or something is wrong with the mechanism. The problem you describe is almost always air leakage around that flap.
Post back if you need more help.
Posted on Nov 18, 2007
  • 213 Answers
SOURCE: Ice sticking to ice maker
the water valve in the back where the water line conects is not letting the right amout of water pressure up to the ice maker. either valve is bad or if you have a filter it may need changing
Posted on Nov 20, 2007
bobicehouse
  • 1524 Answers
SOURCE: Roper Ice maker wont kick ice cubes out of tray.
Remove white plastic cover on ice maker. On bottom you will notice the heater connections, check for voltage. If good, heater is most likely bad.
Posted on Apr 27, 2009
SOURCE: ice maker not ejecting ice and then tries to fill tray and leaks
The Ice Maker Tray had a small plastic piece break off. This piece aids the tray in bending to dislodge the ice from the tray. Bosch does not just sell the tray, you will have to buy the whole ice maker assembly. You will need to order Part # 0422 from Bosch. I was not very happy about having to spend $112.00 for this whole assembly when all I really needed was a simple ice cube tray.
Save the $112 and remove the ice maker. Buy Ice at the grocery store.
Posted on Jul 24, 2009
SOURCE: Ice maker frozen on "crushed" ice mode
Check the bar below the icemaker bin. There is a gold color metal bar that goes from the front of the bin to the back and goes into a lever at the back of the freezer. If the bar gets on the wrong side of the lever it will be stuck in crushed mode.
Posted on Jul 28, 2009
How to remove plastic bag stuck in ice maker
Depends on where the bag is stuck at, just frozen or got wrapped around the cube eject mechanism....if its just frozen then get your hair dryer and melt the ice around it. If it's wound around the mechanism you'll have to remove it from the freezer and after you get it out defrost it and just try and pull the plastic out don't pry on it with anything. Most ice makers are really pretty easy to get out, they just plug into the back of the freezer
Jul 14, 2014 | Kitchen Appliances - Others
Our ice maker fills but
Defrost the fridge leaving it unpugget 48 hours, this may solve the problem
Apr 21, 2008 | Refrigerators
Ice maker not making ice
Check and see if a cubes or cubes are stuck in the ejection fingers. If the ice mold is full try cleaning the bottom coils. If the ice mold is empty check the water valve solenoid. Most times both the ice maker and water valve gets replaced at the same time. Nothing inside the ice box controls the ice maker. It does it all itself all it needs is for their to be 35f in the freezer or better.
Apr 06, 2014 | Amana ARSE66MB Side by Side Refrigerator
Sub zero 650 slow ice maker
Hi Maureen,
Your sub-zero 650 should produce about 8 cubes every 2 hours. It sounds like the heater beneath the ice maker may be wearing out. Ice makers use a heating mechanism to warm the cubes in the mold and force them to easily eject. If the heater is failing in the back slot, it could cause the ice cube to get stuck. If this is the case, you usually need to replace the part or the entire ice maker.
It is also possible the mechanism isn't properly aligned. You could try adjusting it.
You can find two manual on FixYa here: http://www.fixya.com/support/p24667-sub_zero_650_o_bottom_freezer
Otherwise, I suggest contacting their customer service or a technician: http://www.subzero-wolf.com/contact-and-support/index.aspx
Best of Luck!
Dec 09, 2013 | Refrigerators
Ice maker stopped making ice. Water line is hooked up and working. Just won't eject ice
Ice maker stopped making ice. For this problem you have check few things. First thing, is the water filling in the ice maker chamber and then ice maker not making ice? Or, the water is not filling in the ice maker chamber so it's not making ice. If the water is not filling in the ice maker chamber then it's clear that ice is not getting made due to no water in the chamber. For no water filling, the problem is either water supply valve turned off so water is not filling. Turn on the water supply and it will fill. But if the water supply is turned on then the other possibility is ice blockage in the water fill tube. There is a tube from which the water runs and enters the ice maker chamber. If this tube is blocked then water will not enter the chamber. The tube needs to be defrosted, by using hair dryer. This procedure melts the ice collected in the tube and water starts running again. But if water fill tube is completely clear and no ice blockage or any other blockage. Then other possibility is water valve at the back of ice maker unit. This water valve is for letting the water in the ice maker. The water valve open only for 7 seconds and in this time the water fills in the ice maker chamber and then water valve closes and the same procedure runs again in the next water filling cycle.------- For your information I will mention that there are two valves. One is the main valve the back of the fridge section. This main valve lets the water enter the refrigerator and other valve is at the back of ice-maker section. This other valve lets the water to enter the ice maker. In most of the cases the fault is water valve at the back of ice maker section. ------------- The other above possibilities which I gave you is water not filling in ice-maker chamber so it's not making ice. But now consider that water is filling in ice maker chamber but it's still not making ice. Then the problem is ice maker unit itself. This unit is controlled by main board. But in most cases if water is filling the ice maker but it's not making ice then its faulty ice maker unit. So see if the problem is water not entering the ice maker then the water fill tube is frosted by ice or the water valve at the back of ice maker is faulty. Replace the valve. ------------But if ice is getting made in the ice tray,but the ice is not ejecting out then there is blockage to the ice ejecting blade.May be some ice is got stuck below inside.Clear all ice frost collected under the ice chamber.And then see.---------------
You can get required parts from sears part direct online site or from repairclinic.com site.
This will help. Thanks. Helpmech.
Feb 21, 2011 | GE Refrigerators
AMANA ARB2257C ice maker makes noise/doesn't eject cubes into bin
Hi: First off make sure the fridge is level. Is It too high in front? Making the rear of the icemaker overflow and jam? Also make sure the freezer section is a zero degrees, not just frozen. Ice cream should be rock hard. I hope this helps you avoid calling service. Thank You, Jeff
Jun 13, 2009 | Amana ARB2257C Bottom Freezer Refrigerator
Ice Maker not working
Get me the model number. Put tap water in ice maker tray and make sure arm is down. Let it freeze. Wait and see if the ice will drop, this should allow water to come into the ice maker for another run. Let me know, Thanks, Sea Breeze
Apr 27, 2009 | Whirlpool GS6NBEXR Side by Side...
My GE ice maker has forzen up with too much ice & wont eject
Unplug refrigerator, remove frozen food and use a hair dryer on the ice to remove it. Thanks, Sea Breeze
Feb 08, 2009 | GE Profile Stainless Bottom-Freezer...
Refrigerators Logo
77 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
