Question about MSI K7N2 (MS-6570) Motherboard
Drivers for MSI K7N2 (MS-6570) Motherboard
dutchman05
  • 487 Answers
SOURCE: audio sound
install the AC97 drivers from Realtek and than go to your sound mixer and open the volume
start
control panel
sounds
advanced settings in left corner
unmute all
move all levers up
and you will have sound
Posted on Apr 26, 2008
map9966
  • 2351 Answers
SOURCE: dutchman05 has offered a new Solution for the K7N2 Delta-ILSR (MS-6570-030) Motherboard
Hello Damaco, let’s check in side of windows. Bare with me on this. (For you, some of this may be a repeat of checks).
Click the start button & slide up to & left click on control panel.
It should open. Double left click on the icon, Sound and audio devices. Click on the Audio tab. Listed under default device should be the name of you're sound device. Now click on the Voice tab, again under default device should read the same device. If not than you're sound driver software did not install correctly. (Not you're fault!). Close the sound window. Next double left click the System icon. System Properties window will open. Click the hardware tab, than click the device manager button. Scroll down to Sound, video and game controller. You should see a yellow ! point or an X, which means no software has been installed or you're sound controller is bad. You're MSI board uses a bundled set of software which install more than just you're audio software & driver.
MSI's web site link is listed below. (Click on the link).
http://global.msi.com.tw/index.php?func=downloaddetail&type=driver&maincat_no=1&prod_no=546
You're MSI board uses Realtek ALC650 6-channel audio.
Realtek's home page does not hold drivers for you're ACL650.
Mike
Go to, (NVIDIA nForce2 System Drivers for MCP2 of SB).
Please create a folder on you're desktop & give the folder a name, like (Driver NVIDIA nForce2).
Download the software for you're current operating system & save it in that folder. You will have to uncompress the .zip file.
This download is more than just the audio software. (You should be able to install all without a problem).
This nForce Win2K/XP driver package contains the below components:......
Audio driver 4.08 (WHQL)
Audio utilities 4.08
Ethernet driver 3.13 (WHQL)
GART driver 3.34 (WHQL)
Memory controller driver 3.38 (WHQL)
SMBus driver - (Known as chipset drivers) 3.38 (WHQL)
IDE In-the-box 2.70
If during install you receive a screen where you can uncheck drivers that will be installed, do so. Uncheck Ethernet driver, memory driver, SMBus driver & IDE driver.
Since most of the drivers above are all ready installed. It should not hurt you're OS re-installing all the drivers. If this download & install fails to give you sound, than you're intergrated onboard Realtek ALC650 6-channel audio controller is defective. You can disable it from within you're bios & buy a PCI sound card.
Suggested PCI sound card. Any of these will work for you.
http://www.zipzoomfly.com/jsp/ProductList3.jsp
& the next link.
http://www.tigerdirect.com/applications/SearchTools/search.asp?cat=2771&keywords=PCI%20sound%20card&mnf=
Posted on May 07, 2008
  • 15 Answers
SOURCE: need drivers for the motherboard
Go to http://www.msicomputer.com/product/p_search.asp , and then up top in the search box, specify what electronic device you are looking for,( click on motherboard) then type in your motherboard model.
P.S. I tried to do that for your motherboard, but it seems that there there were several models within the MS 6570 range, so i wasnt exactly sure of your motherboard model. but it will give you a list of all the K7N2 6570's just click on the appropriate model
Posted on Mar 17, 2009
marketex
  • 371 Answers
SOURCE: Original hard drive crashed last year and I lost
Drive-Pro.com
Download your usb 2.0 driver here.
Posted on Mar 29, 2009
lorenzo_most
  • 60 Answers
SOURCE: msi ms 7071 motherboard driver
try here:
Product page: http://www.msicomputer.com/product/p...?model=pm8m2-v
Realtek ALC Series AC97 Audio Driver:
http://global.msi.com.tw/index.php?f...e&dno=2344&i=0
If you need other drivers for this MB., you can download them here: http://global.msi.com.tw/index.php?f...=1&prod_no=180
Posted on Mar 31, 2009
Internacional zvucna dolawad
this is the 5 Driver Finder (Online) :
1. http://www.all-driver.com
- Search for all aviable Driver
2. http://devid.info
- Search Driver From Hardware ID (you can See Hardware ID from Computer Management > Device Manager > Propeties hardware you've Need the driver > Details
3. http://www.driverguide.com
- Search Driver by Model Name or number
4. http://www.driverstock.com
- Search Driver by type and the producer
5. http://www.nodevice.com
-Seacrh driver from Categories or Companies
try it,and don't forget to rate me if this post helpfull.
thanks be4
Jan 17, 2012 | MSI K7N2 (MS-6570) Motherboard
Bios reset on ms 6570 k7n2 delta ilsr with jumper
Hi, you can download a manual here:
http://www.msi.com/product/mb/K7N2-Delta2-Platinum.html#/?div=Manual
Unzip the file before you can read it.
The bios can also be resetet by removing the cmos battery:
The manual shows how to do it with the jumper settings.
Sep 25, 2011 | MSI K7N2 (MS-6570) Motherboard
How to download ms-6575e?
What is it that you are looking for? a driver? which drivers are you looking for?
May 29, 2010 | MSI K7N2 (MS-6570) Motherboard
Need drivers for the motherboard
Here you go:
http://www.msi.com/index.php?func=proddesc&maincat_no=1&prod_no=519
If this isn't it just search MSI.com and leave off the MS 6570. There were a couple of different ones.
Let me know if that helps you.
Mar 17, 2009 | MSI K7N2 (MS-6570) Motherboard
Drajveri za maticnu plocu
i found disc with 50000 universal xp drivers and i solve the pooblem                                         thanks anuway
Aug 27, 2008 | MSI K7N2 (MS-6570) Motherboard
Audio sound
start
control panel
sounds
unmute all
move all levers up
Apr 25, 2008 | MSI K7N2 Delta-ILSR (MS-6570-030)...
K7 mainboard
Here's where you can download all of the drivers for your motherboard in one place, from the Vendors site:
or here:
http://tinyurl.com/2w296m
If you load all of these drivers and the problem persists, it may be a configuration problem instead of a driver issue. Let us know.
Feb 22, 2008 | MSI K7N2 Delta-ILSR (MS-6570-030)...
MSI K7N2 (MS-6570) Motherboard Logo
53 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
